  3. DLMS.Push.Listener Python - Fails
DLMS.Push.Listener Python - fails
By bernhard , 10 November, 2022
My energy provider is telling me that the L+G E450 meter is sending data UNENCRYPTED.
As you can see below I am mostly getting the error 'Invalid Command'.
Sometimes I get the error 'Invalid Count'.
Any idea what is going wrong here?
Note: using another github package (which relies on gurux), I get an error 'Secure connection is not supported'. I think this may stem from the 'getdata' function.
The interesting bit there, is that the buffer clearly contains multiple messages (7E A0 seems to indicate the start).
pi@pi4:~/Gurux.DLMS.Python/Gurux.DLMS.Push.Listener.Example.python $ python3 main.py -t Verbose -S /dev/ttyUSB0:2400:8Even1
gurux_dlms version: 1.0.107
gurux_net version: 1.0.19
gurux_serial version: 1.0.20
[Hex trace removed]
Closing
Media state changed. MediaState.CLOSING
Media state changed. MediaState.CLOSED
Nov 09 11:01:28 pi4 smartmeter-datacollector[2412]: DEBUG:smartmeter:HDLC Buffer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
Nov 09 11:01:28 pi4 smartmeter-datacollector[2412]: WARNING:smartmeter:Failed to extract data from HDLC frame: 'Secure connection is not supported.' Some data got lost.
3 years 10 months ago
Data is sent encrypted. You need the encryption and authentication keys from the energy provider.
Without that information, you can't decrypt the data.
Data is coming in three frames. I'll remove your hex trace so it's easier to read.
7E A0 8B CE FF 03 13 EE E1 E6 E7 00 E0 40 00 01 00 00 77 DB 08 4C 47 5A 67 72 A4 8A 93 82 01 27 30 00 00 5A AE 6F A9 8B 1B F0 6B 22 C4 E4 24 89 3E F5 96 04 A7 26 AC 81 40 02 F0 91 F5 95 3F 07 F2 13 D6 34 E8 01 A0 D6 29 9A 9C 26 78 D4 C8 14 60 4C 3B F7 FA 47 80 5C 2B DA 39 BF 9E A8 32 86 44 8D 2B 3A F7 72 A7 DA 40 3B 0B C0 2A 55 C8 59 15 B8 BD 6C 8F AB A2 DA F6 1E 96 1C 65 D9 BA DB F3 60 61 6A 42 2C 78 3E 0D 9D C5 99 7E
7E A0 8B CE FF 03 13 EE E1 E0 40 00 02 00 00 7A AF 76 C9 3E 80 9F 82 AA C8 B5 25 16 B7 0D 42 79 6F 88 A6 5F 83 F6 38 54 8B C1 67 4B 78 D3 27 71 1A FB 50 48 36 7B AC CD B3 98 42 55 A4 D9 05 6A 9A 6C B1 BF D6 67 F5 9A 5D FC 34 21 B0 80 AF A9 FD 11 37 2F A4 D8 ED 4B 92 DD B0 66 18 06 86 70 C8 D7 0D 88 8F 0F 92 03 68 DE BF 75 3D 54 B9 D1 7E B8 F5 B9 9D 3C 21 81 57 E6 DE 12 24 FE 10 79 B1 31 0C D7 1C DC 95 D4 C7 59 28 18 7E
7E A0 54 CE FF 03 13 25 74 E0 C0 00 03 00 00 43 E9 E6 82 70 F5 48 6B 57 F3 20 A9 52 A0 0A BD EE 72 AF E3 4F 33 BD E6 81 08 B3 94 C7 6F 94 DE 29 9F A9 A6 5F AF 25 70 77 8D 81 A2 5C 29 24 0E 75 CD 59 30 27 F7 DA 1C B9 DC C5 F0 85 03 36 E7 54 16 49 36 36 E8 7E
<!-- IDIS system title:
Manufacturer Code: LGZ
Device type: IDIS package2 IP polyphase meter
Function type: Disconnector, Load Management, Multi Utility
Serial number: 44337811
<GeneralGloCiphering>
<SystemTitle Value="4C475A6772A48A93" />
<CipheredService Value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
</GeneralGloCiphering>
bernhard
Thanks. I will reach out to
Thanks. I will reach out to them.
You provide excellent and timely support as always.
Let me know if you have a donation page/address.
bernhard
Thanks Mikko.
Thanks Mikko.
I now have unencrypted data (below are five lines).
the smartmeter-datacollector package from github is partially parsing this. I will try and make sense of this now.
7ea08bceff0313eee1e6e700e0400001000077db084c475a6772a48a93820167300003b13dcf83dd687b5ef53c5b81bffbef1bcb55dccc9b5b3e5dec9afa40272cedb6eb59c6c878fed8f641fff6cdbed028707279d4b3788697bd4eac74b07c848273b1ff14365e868c472fe1a3c113db62b6a054aaea962088ea941756896a84370f650a5c757985a17d697e
7ea08bceff0313eee1e6e700e0400001000077db084c475a6772a48a93820167300003b14935ee2c0cfb090e2cf279ddad3c4769028b85ac0d00eef9dfb8554730f71fa27d293b07ae9825e806741d2f5a780441db21ee4bb153cfa49307d4aa1a4e70d5042ddfe79a1a7d057bf1b35af19852117682b229b69262941ffc1484433db38fecbef7ab944e306f7e
7ea08bceff0313eee1e6e700e0400001000077db084c475a6772a48a93820167300003b155d2f2f7be6598cdcc2e2f9c14a17423818fc88bbba6b20f0923332664d66c13d8d4808a41d263757c3161c0123cc2dcd536c141b3d7d72d3ceb266e58e763b45a0ad89bcc1013bede829310734c4561a3e43b0dd1573faa737edb56e386b58585c6da8cbb043a387e
7ea08bceff0313eee1e6e700e0400001000077db084c475a6772a48a93820167300003b1611cda0977307561bb06b9f62fdc9bf6b4746160b2e7a0c6a21446cd0fea618f04f445527b8c8050354a1bbf5c6d7095d0ddf9030d8ca7b66565d3f5ec5b202f070b8c32224cd60892413739f286e63378b78df7354afe44d1c4614787efbcbde840696632a14e457e
7ea08bceff0313eee1e6e700e0400001000077db084c475a6772a48a93820167300003b16d46bc2e379157e1b9532f9fea80ca9962c5f7e6c5d61281296d0e257d98219efacaef1db64cf616f514648f3e2f2983e69aa0e8c3240883157bb6e04552ae5e5cd5f259f69f7cdefe136f793f20af2b3335b8f79f9541e6a5cdf83981771893a0f70504caaf509c7e
Your meter is sending only the first block and the "Last block" value is false, so there should be more data coming, or then there is an issue on the meter and the Last block is not set. Do you know how many objects there should be on the push message?
bernhard
Actually, things are working fine now.
here is the log from the smartmeter-datacollector
https://gist.github.com/kafisatz/c347b19b5d0abac58345ddab880b1659
Maybe the hex data in my previous message was incomplete (sorry about that).
But can you please tell me how you know that there will be 'more data'?
clearly the smartmeter-datacollector is aware of this as well: there are always three messages which are concatenated (e.g. line 13).
Interestingly my meter is only sending the tariff information ("Active Energy + Tariff 1") once per minute. All other data is sent every 5 seconds though.
THANK YOU!
3 years 9 months ago
This is quite complicated, but HDLC framing will tell if there are more frames available. After all the frames are received the PDU will tell if there are more blocks left.
https://www.gurux.fi/GuruxDLMSTranslator?translate=7ea08bceff0313eee1e6…
