  3. Disconnect Smart Meter Passing Obis Code
Disconnect smart meter passing obis code
By kevin jose minj , 19 October, 2022
I want to disconnect smart using python dlms.how to pass the arguments
This is the arguments i passed
"args": ["-S", "COM5", "-c", "48", "-a", "High", "-P", "ISK_SECRET_ASSC3",
"-C", "AuthenticationEncryption", "-T" ,"49534B3030303031", "-A", "000102030405060708090A0B0C0D0E0F",
"-B", "000102030405060708090A0B0C0D0E0F", "-D", "6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B6B" ,"-w", "1", "-f", "128",
"-o", "device.xml", "-g" ,"0.0.96.3.10.255:1" ]
But it is not turning of the meter.Any solution
4 years 1 month ago
Command line application is only an example that is used to read values from the meter. If you want to disconnect you need to invoke disconnect control.
What you need to do is search for the disconnect control and then call remoteDisconnect or RemoteConnect methods.
https://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSDisconnectControl
  • Suria
  • pespinosaferrer777
  • Gabice William
  • ngewe
  • jojon15
