  3. Gurux.DLMS.Client.Example.python
By ravichandra99 , 9 August, 2022
Hi sir.. Im running -t Verbose and getting the hex trace as follows im getting the following error.. Pls help
-------- Reading 15 0.0.40.0.5.255 Ch. 0 Association #5
TX: 11:43:15 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 1A A4 FB 88 2C 0F 34 44 AE 83 E2 99 58 46 49 21 C1 13 A5 BB C8 0E 6C 38 34 06
RX: 11:43:16 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 1A 00 4A 55 4D A4 7F 93 16 6D 9B BB F3 4D 3B 31 15 FD 7E 9B 8E A0 D4 E2 13
Index: 1 Value: 0.0.40.0.5.255
TX: 11:43:16 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 1B DD D3 FE 23 6D 6B C3 E2 7F 2E E4 9C 21 5C 52 DB DF 02 B8 16 6D FC 2B FC 17
RX: 11:43:18 00 01 00 01 00 30 01 8F CC 82 01 8B 30 00 00 01 1B 70 B2 E7 67 FF 48 93 0E CE 87 31 07 D0 EF 02 6E 5C 62 B9 D7 0F 3C DB D4 B2 AF F0 E0 77 D5 2D 4C 6B A4 BA 87 04 48 A0 D4 93 8A F5 9B 64 E6 7B 36 70 31 92 75 0D 2B 83 4B 7A 5A F4 89 10 BC 53 0F E4 E2 72 24 59 DF 4B 61 C9 1A 95 22 5B 3A C2 C3 82 84 96 82 9E 6E 93 B1 83 F2 89 10 CB CC 9C CA 1A A4 87 84 FF 69 32 92 CA 43 20 54 49 5C 47 C5 9E 8C 4A 61 23 5A DB 35 C8 FC 1A CB 58 E3 6D 0A 1A 8B 68 8F 9F 13 39 AB C1 08 A2 EB E7 C6 A7 01 62 91 9C F3 09 CC BB FD DB E5 E7 E8 E8 16 9D D5 AA 15 76 6C 54 57 84 88 9A 69 0B 54 8D 09 DE 0D A0 09 9E F8 68 8D C5 8B 92 C5 7F 7C F1 E9 05 85 39 C3 A3 15 10 6D 9E 5F C4 FC 6F FB E9 A7 3A 0F D0 6B 79 51 A0 93 E5 58 95 2A CB 2A 33 7D 22 12 9A BC 26 7A 8E 60 9E BC 9F FB 30 E8 7F 11 18 CB 76 99 32 66 B8 48 49 B5 DA 40 77 6E AC 3C C6 20 95 1F D4 19 F1 44 98 2A 30 76 2F B4 73 8A 7C 67 D4 DE 30 36 7C C5 51 19 75 26 23 EB 7E 56 00 D1 E0 21 B8 4F 05 DD 73 28 F6 44 F9 66 ED E3 89 0D 5B D6 0C C8 DD BB 8F D4 73 A0 6C B6 0E 6C 6E 13 01 C8 78 7C 2A 5D D6 20 14 77 C1 60 FC E3 6A 81 57 DD F0 81 66 F9 A4 42 11 C3 88 17 9E 20 D8 26 10 8F 08 5D 6C F9 EE CA 90 1B 51 34 B3 C0 88 4D F8 54 04 60 26 49 94 FF 9F 4D BE 11 9E 9E B6 7A F8 E4 94 05 91 E9
Error! Index: 2 Invalid Block number. It is 28 and it should be 1.
File "/var/www/gurux_yash/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 437, in getReadOut
val = self.read(it, pos)
File "/var/www/gurux_yash/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 326, in read
self.readDataBlock(data, reply)
File "/var/www/gurux_yash/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 182, in readDataBlock
File "/var/www/gurux_yash/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 118, in readDLMSPacket
File "/var/www/gurux_yash/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 169, in readDLMSPacket2
raise e
File "/var/www/gurux_yash/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 149, in readDLMSPacket2
while not self.client.getData(rd, reply, notify):
File "/usr/local/lib/python3.8/dist-packages/gurux_dlms/GXDLMSClient.py", line 1190, in getData
raise ex
File "/usr/local/lib/python3.8/dist-packages/gurux_dlms/GXDLMSClient.py", line 1187, in getData
ret = GXDLMS.getData(self.settings, reply, data, notify)
File "/usr/local/lib/python3.8/dist-packages/gurux_dlms/GXDLMS.py", line 2297, in getData
GXDLMS.getPdu(settings, target)
File "/usr/local/lib/python3.8/dist-packages/gurux_dlms/GXDLMS.py", line 2032, in getPdu
GXDLMS.handleGloDedResponse(settings, data, index)
File "/usr/local/lib/python3.8/dist-packages/gurux_dlms/GXDLMS.py", line 2175, in handleGloDedResponse
GXDLMS.getPdu(settings, data)
File "/usr/local/lib/python3.8/dist-packages/gurux_dlms/GXDLMS.py", line 2001, in getPdu
if not GXDLMS.handleGetResponse(settings, data, index):
File "/usr/local/lib/python3.8/dist-packages/gurux_dlms/GXDLMS.py", line 1907, in handleGetResponse
GXDLMS.handleGetResponseNextDataBlock(settings, reply, index)
File "/usr/local/lib/python3.8/dist-packages/gurux_dlms/GXDLMS.py", line 1851, in handleGetResponseNextDataBlock
raise ValueError("Invalid Block number. It is " + str(number) + " and it should be " + str(expectedIndex) + ".")
ValueError: Invalid Block number. It is 28 and it should be 1.
TX: 11:43:18 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 1C D8 E9 C8 85 5F 2B 3B 59 DD 9A AA 90 69 D0 8D 27 EA BF BE 9C F5 A6 A7 71 11
RX: 11:43:19 00 01 00 01 00 30 00 24 CC 22 30 00 00 01 1C 02 5A AB D2 F7 5C 9B 03 B9 6D 5B 78 31 28 86 81 51 15 6E F8 2B AB 35 A1 17 A5 4B 7F 72
Error! Index: 3 Invalid Block number. It is 29 and it should be 1.
raise e
raise ex
ValueError: Invalid Block number. It is 29 and it should be 1.
TX: 11:43:19 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 1D F1 91 B3 1C 2C 0C B0 1A 06 A4 AE C7 C2 2A 43 36 5A 70 1A 69 B3 73 48 98 94
RX: 11:43:19 00 01 00 01 00 30 00 20 CC 1E 30 00 00 01 1D 09 FA 1F D4 78 23 90 28 88 57 D9 B9 FC D4 2A 51 83 63 5F 36 1C D2 16 AB 89
Index: 4 Value: 0 0 0 5 8 1 3
Index: 2 Value: <gurux_dlms.objects.GXDLMSScript.GXDLMSScript object at 0x7f346d185ac0>
-------- Reading 9 0.0.10.0.100.255 Ch. 0 Tariffication script table
TX: 11:42:36 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 F3 6F 27 C1 CE F6 1B 7B A5 13 6E 33 51 07 7A D9 F9 36 3E AF 4F D9 DC F0 DC A0
RX: 11:42:37 00 01 00 01 00 30 00 1F CC 1D 30 00 00 00 F3 58 F7 49 61 EB 25 C4 1B B3 87 83 B8 C3 B9 B0 4E A9 CD 5D 44 6F 10 52 56
Index: 1 Value: 0.0.10.0.100.255
TX: 11:42:37 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 F4 0B D3 4C 8A 5A E6 CA 5E 35 C0 38 CE A3 8C 9B D9 6A F4 41 99 C8 0B 23 89 4F
RX: 11:42:39 00 01 00 01 00 30 00 B6 CC 81 B3 30 00 00 00 F4 D5 66 3F 73 7B 6E D2 A3 F7 66 AB E7 ED 3B C3 C1 92 42 45 45 0F E8 1A 5C 8F A3 24 B3 AC F2 2D 20 BE AD C9 29 75 FE 3A 79 19 55 34 A2 F7 E2 34 9E EC 62 56 1B 0E DC 93 8F 11 38 2D A9 AD 09 7D 0B 36 95 8C 3B 56 22 42 DB 06 71 45 0D 45 59 D6 7E E1 13 7F BB 23 A1 A2 9B 46 E6 46 13 58 E2 40 6F 7A 56 A4 C0 D5 10 D2 EC EF 6C 9F 1B A2 B1 D1 D6 9E 3E E6 31 C4 BD 53 D1 12 E7 E6 1A 7B 52 7B F8 AA 40 0F C4 BB 8C 02 B8 95 F5 F7 DD 26 7B DF D1 4B D5 21 63 9A 62 E8 F2 A0 07 89 71 E6 E1 93 6F B9 3D 91 33 1C 6B 92 73 F4 F3 21 88 34 3B
Index: 2 Value: <gurux_dlms.objects.GXDLMSScript.GXDLMSScript object at 0x7f346d185af0>, <gurux_dlms.objects.GXDLMSScript.GXDLMSScript object at 0x7f346e257970>, <gurux_dlms.objects.GXDLMSScript.GXDLMSScript object at 0x7f346e257eb0>, <gurux_dlms.objects.GXDLMSScript.GXDLMSScript object at 0x7f346e257ee0>, <gurux_dlms.objects.GXDLMSScript.GXDLMSScript object at 0x7f346e257b50>, <gurux_dlms.objects.GXDLMSScript.GXDLMSScript object at 0x7f346e257fd0>
-------- Reading 9 0.0.10.0.107.255 Ch. 0 Image activation
TX: 11:42:39 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 F5 E4 C3 1B E0 7C 9E 14 3C 42 36 FE D0 EF DD 93 83 72 BA 69 D2 EA 17 76 17 C4
RX: 11:42:39 00 01 00 01 00 30 00 1F CC 1D 30 00 00 00 F5 C4 13 4A 44 8E A1 7D C4 A4 54 DF A1 CC E0 63 34 71 31 90 DB 9B 45 7D D4
Index: 1 Value: 0.0.10.0.107.255
TX: 11:42:39 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 F6 59 3F 82 7F 9E 45 45 5D C7 E7 4E FB F6 F1 51 EC D9 34 90 64 E9 50 CF C5 F2
RX: 11:42:40 00 01 00 01 00 30 00 33 CC 31 30 00 00 00 F6 BF 56 00 04 4F B8 3E D4 EA 99 49 BA 8D A7 E5 75 16 35 C3 46 83 5E FA F1 9B ED A7 38 F1 10 85 F8 A0 BE 33 13 1F 16 0B ED F8 BE F8 FA
Index: 2 Value: <gurux_dlms.objects.GXDLMSScript.GXDLMSScript object at 0x7f346d185850>
-------- Reading 9 0.0.10.0.108.255 Ch. 0 Push script table
TX: 11:42:40 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 F7 94 EF 3E B7 05 35 4A EC 16 09 64 3C AF 2E 9C 05 0E C3 1E 2E C3 6E 66 DD 84
RX: 11:42:41 00 01 00 01 00 30 00 1F CC 1D 30 00 00 00 F7 21 95 51 6F 49 3B 90 18 DE A9 57 C8 54 BC 2D EF E4 75 62 C2 96 8D 52 B8
Index: 1 Value: 0.0.10.0.108.255
TX: 11:42:41 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 F8 99 B5 C8 A9 2F 61 77 FD B3 C6 0E C0 CC 83 C1 B8 D5 DC EE 45 CF 3C CC 0E 6C
RX: 11:42:42 00 01 00 01 00 30 00 4D CC 4B 30 00 00 00 F8 CB C1 CE 59 B8 03 87 08 2E 88 A0 D6 81 FF 63 74 D6 A8 C1 86 64 6C 1F 6F C1 F6 36 E5 C8 9E 4F CF DB 5C 9A 17 12 34 34 D8 00 B3 30 7A 59 D8 C4 84 72 F0 E2 65 FF C4 A8 83 EC 16 E1 FA 50 1B 44 83 B5 E4 8B 22 B3 DF
Index: 2 Value: <gurux_dlms.objects.GXDLMSScript.GXDLMSScript object at 0x7f346e25e1c0>, <gurux_dlms.objects.GXDLMSScript.GXDLMSScript object at 0x7f346e25e100>
-------- Reading 15 0.0.40.0.1.255 Ch. 0 Association #1
TX: 11:42:42 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 F9 F2 71 13 E4 1B 8C 23 48 5D A9 DA BB 5B 91 B5 94 D6 05 E4 02 A7 C9 5A 7F 34
RX: 11:42:43 00 01 00 01 00 30 00 1F CC 1D 30 00 00 00 F9 E3 47 E5 48 7F 07 8B EC FC A5 8F 88 53 E4 78 70 E3 0C B0 D9 1C 45 15 95
Index: 1 Value: 0.0.40.0.1.255
TX: 11:42:43 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 FA 10 D4 3A 5E 50 D7 A7 67 95 33 24 A5 CA BB 87 D4 65 48 4B 1F 6D 40 38 5D DD
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
Index: 2 Value: 0.0.42.0.0.255 Ch. 0 COSEM Logical device name, 0.0.96.1.0.255 Ch. 0 Device ID 1, manufacturing number, 1.0.0.2.0.255 Ch. 0 Active firmware identifier, 0.0.1.0.0.255 Ch. 0 Clock object #1, 0.0.40.0.1.255 Ch. 0 Association #1
TX: 11:42:45 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 FB 7C BA 71 CB F4 20 22 BE FA A7 68 1A D3 29 1B 95 A2 FB 39 AB 79 E6 EB 8F 5D
RX: 11:42:46 00 01 00 01 00 30 00 1E CC 1C 30 00 00 00 FB 71 D5 CB A5 7A 2D 7B 91 8C 67 20 64 BD CA A9 3B F5 BA 61 60 6F 84 CA
Index: 3 Value: 16, 1
TX: 11:42:46 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 FC AF 93 FE 7F 7E FB D7 D6 CB 7B B4 8E A4 DE 82 13 14 5C 00 34 A1 9B FF CE A6
RX: 11:42:46 00 01 00 01 00 30 00 20 CC 1E 30 00 00 00 FC 7D 2D 39 81 5F FA A0 82 A2 8D 7B AB 06 C7 F9 A0 3F F3 04 81 7E B9 0A 6C FE
Index: 4 Value: 0 0 0 5 8 1 1
TX: 11:42:46 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 FD F5 B3 56 84 12 F7 BB 0B E9 D5 D4 CF 60 A2 1E B4 A9 8D 5A D1 2E 3E 0C BE 40
RX: 11:42:47 00 01 00 01 00 30 00 2A CC 28 30 00 00 00 FD 37 6D 8E 4D 8A B1 59 29 B3 AC CE 35 8B C4 9C CD 97 44 C0 4E 97 A8 4E 52 2D 79 24 11 DD 4A 5C 68 AB 24 EC
Index: 5 Value: Conformance.GET 512 512 6 0
TX: 11:42:47 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 FE 06 14 B7 79 77 C0 EF 49 C5 86 CE 71 57 4A 63 FE E5 60 BA 6A 46 88 47 FD B7
RX: 11:42:48 00 01 00 01 00 30 00 20 CC 1E 30 00 00 00 FE 36 0F 05 65 54 1F 14 4B F5 3A 46 EE 66 29 86 FC D2 76 99 9C 20 13 E1 3C 13
Index: 6 Value: 0 0 0 5 8 2 0
Attribute7 is not readable.
TX: 11:42:48 00 01 00 30 00 01 00 20 C8 1E 30 00 00 00 FF E3 A1 04 C2 2B 75 03 26 6D 63 C8 5D 8E 49 2C 85 FB 41 CF 56 28 D0 1D EF 25
RX: 11:42:49 00 01 00 01 00 30 00 19 CC 17 30 00 00 00 FF 89 92 90 67 9D 66 B1 16 5A 76 83 FC AD 06 35 C4 18 8E
Index: 8 Value: 0
TX: 11:42:49 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 00 7D 7B E8 20 7D EA DF 6B 01 E6 88 58 B2 F1 DD 25 BD 70 03 12 43 90 CA 4C E2
RX: 11:42:50 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 00 A9 8C 45 99 5B 52 E1 20 FF 45 58 AA 11 88 A2 F2 1C 4A
Index: 9 Value: 0.0.0.0.0.0
-------- Reading 15 0.0.40.0.2.255 Ch. 0 Association #2
TX: 11:42:50 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 01 30 F1 B3 64 AA 64 43 84 7F F3 93 3B 74 E1 93 3D C8 DF 13 0F D0 20 AF 89 6D
RX: 11:42:51 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 01 2D D0 47 7F E6 3D BD 44 CB 83 84 19 21 2B FC 97 D9 40 14 EB 4D 77 3F DE
Index: 1 Value: 0.0.40.0.2.255
TX: 11:42:51 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 02 32 4B 6D 86 41 59 7D 45 DF D3 F2 E5 E5 62 0E DD 50 11 3F EA F2 CA 02 50 2B
RX: 11:42:53 00 01 00 01 00 30 01 BA CC 82 01 B6 30 00 00 01 02 48 0F 78 47 90 CA 0D D2 C3 DD 0A 02 4F 71 9D 2E DB CC 68 19 2F D4 79 1C 9A 8E A8 99 7E 45 98 FF 37 4A 12 D9 09 D1 62 28 E3 DF E6 80 07 84 34 F5 7D E4 EB 85 32 C1 DF 5D D5 E5 BB F7 AD 83 96 2C B2 68 45 0B D5 A3 70 CD 56 4E 9A F4 EF 90 DE B1 A7 16 34 CE BA 0D CB C2 5A EA CC 59 35 B8 37 CD 53 26 83 5A E8 D0 A2 02 1C 9E 86 F6 E7 4A 51 A5 B7 1F 72 DD 85 E8 44 10 AC 01 6D FB 82 D3 00 11 7B 73 4C 31 34 15 1B F1 E8 8B A0 C9 D6 0E 39 07 48 79 35 FB 18 13 F2 62 5D 5D 2D 80 5C B6 8A 33 01 AB 66 7A E3 B2 5E C6 FA 98 6E 41 9D F6 5E BE 36 BB 86 BA 98 A0 12 36 7B 8F 8B F5 0B B4 12 59 4F E4 DC 24 78 D7 71 9E F3 BA D6 BD C9 8E B2 68 7D F2 41 BD 19 5F 77 14 71 1F 28 33 08 13 43 5F E9 BB 1A 86 2C 00 C3 EE 11 AF BE A3 B3 FB BC EB 41 86 C4 63 5C 55 B0 AE 20 26 F1 B4 F1 CE 78 12 B3 FC 8F 59 7C 3D E9 53 51 7E 6B 54 80 59 71 91 5E AC 18 39 1F 9B 99 65 19 28 20 DD 39 DF 19 E2 6C 07 29 29 F5 63 49 08 1E 13 45 51 4C 78 D6 BF EF 63 90 A8 D6 8C 91 FC 4A E3 1A EB 43 80 0B 8D 2C 8F 66 BD C7 C7 2F 2B A6 5B 14 9E 17 67 4C B2 19 E2 F8 81 FC 85 D6 4A 7E A6 46 CF 5F 57 E0 EA 93 90 0C 20 48 82 2E C4 6C 47 F8 0E 6E 6B FA D7 BE 07 2C AC 4C 17 8C 9D 79 24 89 5A F5 59 8D 36 2E 5E AE 0B 45 D9 4A 96 00 51 01 32 B2 7B CC 8E A8 F5 CA 32 BF 40 CA C5 BB 3F AA 7B 93 77 03 B9 ED 7E 7B 07 F3 E0 40 B4 3A A9 A3 89 53 F2 DD C4 C5
Error! Index: 2 Invalid Block number. It is 22 and it should be 1.
raise e
raise ex
ValueError: Invalid Block number. It is 22 and it should be 1.
TX: 11:42:53 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 03 0F 78 6E F1 F4 35 97 14 FD 7B F4 B5 C5 D0 06 EA F1 21 7A D6 1E 78 40 49 C6
RX: 11:42:54 00 01 00 01 00 30 00 24 CC 22 30 00 00 01 03 6B 0D 7E F6 2C 06 29 A2 96 1B CB 5F DC 9C 56 B7 A4 E5 19 9B C6 6E 62 4E 2A 0B 0B C3 B2
Error! Index: 3 Invalid Block number. It is 23 and it should be 1.
raise e
raise ex
ValueError: Invalid Block number. It is 23 and it should be 1.
TX: 11:42:54 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 04 7C CE A3 82 11 71 BC 3B 2D E9 90 69 39 11 FE 24 A2 04 75 89 72 93 11 CD D3
RX: 11:42:54 00 01 00 01 00 30 00 20 CC 1E 30 00 00 01 04 D3 CC 43 77 4F D3 33 64 E7 A5 F7 15 FD FF AD EF 9D 70 ED DE 09 44 09 E0 08
TX: 11:42:54 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 05 9A C6 A6 24 BF C0 58 8D 0E 21 6A 7C FB 8C 67 7D D4 1C 13 F3 A9 12 57 78 52
RX: 11:42:55 00 01 00 01 00 30 00 2A CC 28 30 00 00 01 05 4E 9A 56 F1 EE D4 A6 7A 78 FB C3 75 B2 90 FA 84 7F EC 25 1B 8A AA 8E 27 F4 26 18 0E 34 E9 77 0D 38 0D 5B
Index: 5 Value: Conformance.SELECTIVE_ACCESS|GET|BLOCK_TRANSFER_WITH_GET_OR_READ 512 512 6 0
TX: 11:42:55 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 06 B6 C2 7B 3F 1A 2C BE 73 E7 F6 18 93 D4 FA 45 0A AC 85 F1 71 9A 8F 7B A0 1C
RX: 11:42:56 00 01 00 01 00 30 00 20 CC 1E 30 00 00 01 06 41 EF E7 25 FE 13 29 97 4C 59 38 E3 FF 5E 29 54 7B EB 3D EE 5F 32 64 50 41
Index: 6 Value: 0 0 0 5 8 2 1
TX: 11:42:56 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 07 9F 2E A0 F9 02 6B 24 CB 85 BD EC FB 9B 0F C6 0E 11 32 AB D8 E5 C0 4D 12 DD
RX: 11:42:57 00 01 00 01 00 30 00 18 CC 16 30 00 00 01 07 A9 33 B9 DF 91 4A FA 68 4C 15 4D D9 8B 35 15 00 92
Error! Index: 7 Access Error : Device reports scope of access violated.
TX: 11:42:57 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 08 7E 14 84 29 9A 16 11 D5 5B 85 04 B5 1E 70 C5 BE 5A 59 7D F8 2E 2C 2E 76 C9
RX: 11:42:58 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 08 EF 8A B8 E3 C9 3D 68 0D F5 84 D4 4D A8 46 CC 62 6A 90
Index: 8 Value: 0
TX: 11:42:58 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 09 35 2D 93 CF 5D 73 91 AD D3 6D 5B F4 82 B7 25 E9 99 0D 35 2E 34 4F 2F C4 92
RX: 11:42:59 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 09 12 83 B4 B4 27 1E 95 68 E6 4D 44 65 D4 E7 47 22 5F 56 AF B3 08 6B BD 89
Index: 9 Value: 0.0.43.0.2.255
-------- Reading 15 0.0.40.0.3.255 Ch. 0 Association #3
TX: 11:42:59 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 0A A7 3F F8 8B C4 CA 9C 8F 48 E4 39 37 09 BB D1 98 3A A4 A7 7C 06 F3 96 AF 41
RX: 11:43:00 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 0A 40 A8 D6 2E A1 8A 64 53 2A D2 42 B8 CB B1 50 1E AD 49 79 D4 54 5F B3 15
Index: 1 Value: 0.0.40.0.3.255
TX: 11:43:00 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 0B BD 14 59 C5 0E CC 2F C6 0A 75 F6 51 CA 2C 3D A9 1C 3D 85 EB 1E 4E 88 23 3F
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
Error! Index: 2 Invalid Block number. It is 24 and it should be 1.
raise e
raise ex
ValueError: Invalid Block number. It is 24 and it should be 1.
TX: 11:43:02 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 0C 2A 48 B0 83 AC ED CA F3 4F 7E 63 4F 7B 7B C0 71 25 9F FB 16 ED BD 7F C6 5C
RX: 11:43:03 00 01 00 01 00 30 00 24 CC 22 30 00 00 01 0C DE 2F BD E3 C3 45 9F C5 FB B9 A7 60 ED 2A AD A2 6F D3 AA 9C DE 02 69 EE 6B 6E A2 A8 B8
Error! Index: 3 Invalid Block number. It is 25 and it should be 1.
raise e
raise ex
ValueError: Invalid Block number. It is 25 and it should be 1.
TX: 11:43:03 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 0D 0C 86 FE BE 3C B3 62 5D D2 3C B2 06 28 69 F7 D1 6C 17 D5 6D 92 C2 80 2C B5
RX: 11:43:04 00 01 00 01 00 30 00 20 CC 1E 30 00 00 01 0D B0 77 32 3A D5 F0 24 4B FB 94 FB 12 49 18 75 3A 0C F1 FA 4E 2E 81 E8 69 C0
TX: 11:43:04 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 0E 65 80 A7 81 57 9D 18 7E 8B 0D 4E D4 36 B0 10 18 49 45 F7 4A 8B 7E 5A E6 D3
RX: 11:43:04 00 01 00 01 00 30 00 2A CC 28 30 00 00 01 0E 6E AE D9 AC 2A 30 B8 C9 35 E6 E4 7E 75 BD 18 26 9B 45 09 3E 24 16 03 BA 5C 32 C9 06 D0 07 6E CC 06 44 EF
Index: 5 Value: Conformance.ACTION|SELECTIVE_ACCESS|SET|GET|DATA_NOTIFICATION|BLOCK_TRANSFER_WITH_SET_OR_WRITE|BLOCK_TRANSFER_WITH_GET_OR_READ|GENERAL_BLOCK_TRANSFER 512 512 6 0
TX: 11:43:04 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 0F BD 09 94 09 18 9F 5E 4B 54 28 95 47 FC 59 5C 29 45 06 B2 96 C4 EC 00 87 F8
RX: 11:43:05 00 01 00 01 00 30 00 20 CC 1E 30 00 00 01 0F C6 EA 05 DF EB 79 EC 8B FC BB 20 A4 43 9D 5F A3 E7 CA 1F 1B 9E 49 AF D8 F2
Index: 6 Value: 0 0 0 5 8 2 2
TX: 11:43:05 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 10 94 E6 08 E2 BC E4 A9 FC 5D 51 59 C1 65 F4 B9 D8 78 EA 33 63 E1 23 0C 7B BE
RX: 11:43:06 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 10 92 3E 32 69 82 28 12 F9 57 E5 25 76 EA 66 93 EA 0C 13
Index: 8 Value: 2
TX: 11:43:06 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 11 FE 54 B1 62 95 AA AD 77 34 E4 4E 1C A7 89 AA BD FD 9B 91 AC B1 11 BA A0 90
RX: 11:43:07 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 11 38 82 40 BB D8 95 B3 4F EF 9A AA E8 67 29 14 1F 26 F8 45 A6 B6 F1 CD E5
Index: 9 Value: 0.0.43.0.3.255
-------- Reading 15 0.0.40.0.4.255 Ch. 0 Association #4
TX: 11:43:07 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 12 CA 3A D4 FB F1 1D 40 49 70 77 85 DC 6E 4E B6 67 E4 8A 28 23 19 EA D8 B9 61
RX: 11:43:08 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 12 08 21 AD 6F 2D 05 EC 0C 0C 41 75 17 3B 80 E4 9D 5C FD 45 80 1F 23 1E 64
Index: 1 Value: 0.0.40.0.4.255
TX: 11:43:08 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 13 8B BF 1B 0C BF F3 D9 75 BE 96 60 16 FD 95 4F AF 3B 07 4D 67 A8 15 21 49 9A
RX: 11:43:10 00 01 00 01 00 30 01 B6 CC 82 01 B2 30 00 00 01 13 5A 3E FE AB 43 FB 92 23 3B C6 04 D6 A0 7E CD EB 4C 95 9F 9E AF 34 B8 F1 8A 02 FB 8E 1B A3 FF 0B 35 59 A6 9F D7 87 32 E3 61 5A 07 9B 92 9D 99 50 6C 49 54 11 4A 63 A4 48 D5 0B 12 31 B7 50 A7 AC 98 98 DC BB DE 76 B8 C6 32 49 05 F8 EE FE F3 09 46 2F 72 EF 70 1F 56 C0 A6 45 3D 40 A3 2B F8 CC 62 46 7D 5D BA DC A4 21 6F 98 E2 91 D4 3A F3 82 F9 69 46 0B 3C 13 BA 73 48 D7 5B 29 BA AC 70 4E 30 05 86 25 2E 83 52 B8 F1 0D 7B 70 13 5A 87 42 31 6A B4 1C EE C9 1A 5A 1D 3F 19 B8 E4 34 91 8B 1B 76 F2 D8 2C BD 6C 89 AD 12 84 E2 4D 54 56 B6 81 86 1D A0 AD B0 9A D6 33 20 F1 AC AA 45 E1 E0 B9 B5 2A E6 A3 16 B1 0C 83 0C 9A 14 3B BB D0 8B 90 0E 32 F8 0A 03 8A 52 82 C6 96 E6 52 24 86 5B FF 16 95 2F C3 63 19 92 A5 2E 0A 20 AD CF A3 06 1D 43 AF 77 CF 70 4A AD 97 2C ED 39 0E 39 62 2A CF 62 40 37 FB DC F0 68 7B EC 09 1A 7F 08 18 99 B6 FC 95 24 A4 58 49 DE DB BF 86 2D CF 51 FB DC 3D F9 A1 34 FD 90 53 3E 82 9D 52 9A 9C 51 65 31 5E 00 89 D0 51 74 6A D2 12 9C EC 02 94 03 8F 83 C9 6E 66 0D 8B 32 3C 6E A8 8B 91 FB 45 A9 16 0E E4 01 B1 0B 33 36 89 D7 9E 36 AB EF CC 77 24 84 5C 79 EC 0B 30 B3 1B F5 86 3A 9D BA A8 2C 9D 4C 16 97 AC 2A DF DA A6 EB FC FF A9 22 26 29 E7 29 BF 0B 47 8B 33 D9 F9 62 DE 64 4C 50 36 6E 15 91 CA 32 83 A5 63 01 0E 98 45 2A EB 35 24 5B 7A FD 16 31 FC EF 75 E4 E1 34 15 91 51 75 3E
Error! Index: 2 Invalid Block number. It is 26 and it should be 1.
raise e
raise ex
ValueError: Invalid Block number. It is 26 and it should be 1.
TX: 11:43:10 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 14 77 FF 51 D5 E6 5E 6C 44 5C 8D 03 B5 F8 52 4C CE 40 FE 28 7E 1F B7 D5 41 EF
RX: 11:43:11 00 01 00 01 00 30 00 24 CC 22 30 00 00 01 14 C4 D4 AE 08 4C CC A1 36 23 CF 1F 18 58 F1 63 79 96 77 0B 68 E8 C4 5D FD 46 DB EE 2C 25
Error! Index: 3 Invalid Block number. It is 27 and it should be 1.
raise e
raise ex
ValueError: Invalid Block number. It is 27 and it should be 1.
TX: 11:43:11 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 15 C3 5C 3C 40 0B 72 E6 93 9F C3 F2 46 94 7D 2E 84 03 DE 44 37 D9 B6 A1 59 29
RX: 11:43:12 00 01 00 01 00 30 00 20 CC 1E 30 00 00 01 15 DE 4B 18 AD CA D7 E6 9F D5 53 3B 85 D2 26 41 0A F7 6B 51 F0 FC 93 5E 3B 0E
TX: 11:43:12 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 16 A3 D1 4C 04 2B 96 CA 5D C6 64 41 16 6D 73 1E A5 63 CE CA FC 9E A1 95 0F E7
RX: 11:43:12 00 01 00 01 00 30 00 2A CC 28 30 00 00 01 16 C0 89 60 CE B9 72 2E 9D D5 43 5C 10 63 9C E0 41 41 3F 79 28 D0 A2 F9 2A 0B B5 2E 4D 67 40 C4 1E EC F2 2E
Index: 5 Value: Conformance.GET|DATA_NOTIFICATION|BLOCK_TRANSFER_WITH_GET_OR_READ|GENERAL_BLOCK_TRANSFER|GENERAL_PROTECTION 512 512 6 0
TX: 11:43:12 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 17 D8 06 8C 0F 9D D2 23 91 02 35 92 FA EF 46 A3 0D EF 45 8C 48 DE CB F0 59 07
RX: 11:43:13 00 01 00 01 00 30 00 20 CC 1E 30 00 00 01 17 76 9B DA 28 FC 4C 21 94 68 75 98 57 95 BB 42 16 13 32 4D 12 82 12 E8 B7 09
TX: 11:43:13 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 18 46 32 82 5D BC 7C BF A2 12 64 C2 E3 A8 83 50 24 3E 2B 0C 60 E3 8D 5C 4E 39
RX: 11:43:14 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 18 96 F0 97 F0 2B 44 B9 EF AF 4F 81 C2 F8 93 6E 5F 60 85
Index: 8 Value: 2
TX: 11:43:14 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 19 B8 C9 5E 8D 80 7A 43 24 CC 91 43 B2 2E 65 99 4D 98 19 68 B2 2F B6 07 29 1A
RX: 11:43:15 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 19 DC E9 CE 5A 4E BE FF E1 7A 0B BE 71 6F 44 C6 C6 E7 89 75 7A E4 0E D6 A3
Index: 9 Value: 0.0.43.0.4.255
raise e
raise ex
raise e
raise ex
TX: 11:43:19 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 1E A5 65 23 70 4C 11 70 B6 BC 9C 7D 06 91 40 39 F3 5D 88 5F 6E 4E 7F 9E E0 2A
RX: 11:43:20 00 01 00 01 00 30 00 2A CC 28 30 00 00 01 1E C9 7A 3B DB 6C 71 57 3A 63 67 96 5F 49 94 B6 C9 16 18 7D 3F A9 1C 47 20 AE 45 EF 49 FC AC 3F F7 48 D5 95
Index: 5 Value: Conformance.ACTION|SET|GET 512 512 6 0
TX: 11:43:20 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 1F 25 C6 8F EE 9D 86 E2 C5 0E 66 31 AA 52 63 7F 54 00 D6 A8 1B D9 9B 9C DB 7D
RX: 11:43:21 00 01 00 01 00 30 00 20 CC 1E 30 00 00 01 1F 1B E4 D9 1E 0F 52 A1 55 3B CA BC F0 B4 EA 41 8B 99 4B 93 55 4D CE CC BD 39
TX: 11:43:21 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 20 72 D1 E6 36 B5 48 77 E5 41 1C FA 27 3D 20 42 3A 30 79 2A 79 ED D0 72 CD CB
RX: 11:43:22 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 20 09 59 FC 33 F2 EE CB 72 DC D4 A6 59 68 7B 7D 6F 7C E6
Index: 8 Value: 0
TX: 11:43:22 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 21 09 EF B8 DC E0 B6 04 02 2F 89 FC 22 14 43 67 4D E9 C8 C0 70 8E 36 65 18 48
RX: 11:43:23 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 21 A7 3F 6D EA A4 6A A3 06 77 DC 0F D2 65 99 23 B5 7A C7 A2 CA 5A 29 E6 E6
Index: 9 Value: 0.0.43.0.5.255
-------- Reading 18 0.0.44.0.0.255 Ch. 0 Image transfer #0
TX: 11:43:23 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 22 42 0D F6 2C C3 11 63 78 D4 C7 04 88 45 54 AA 73 8F 88 47 6B 1E B8 81 32 65
RX: 11:43:24 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 22 B6 B8 91 A0 48 89 40 2E 86 18 D1 16 BB F1 5D 15 E7 D4 E1 AE A3 A8 12 21
Index: 1 Value: 0.0.44.0.0.255
TX: 11:43:24 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 23 C3 06 D2 E5 8D D6 A9 F0 1F E5 90 FD ED EF B0 EF 9E 9C C9 69 E3 9B E4 E7 87
RX: 11:43:25 00 01 00 01 00 30 00 1C CC 1A 30 00 00 01 23 F1 7C FC A6 ED 4F 31 BD AA 36 9F A9 58 35 DD 63 4C 54 A6 C0 D7
Index: 2 Value: 256
TX: 11:43:25 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 24 6D D8 DD 2C 41 07 64 8F 52 E5 94 BE 72 4E 22 A5 7E BA 4D F4 28 B4 2F 33 2A
RX: 11:43:26 00 01 00 01 00 30 00 1A CC 18 30 00 00 01 24 FC 03 76 D6 CC 65 9B 34 B4 B9 6C EC 01 90 9E FF CD CC 55
Index: 3 Value: 0
TX: 11:43:26 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 25 76 4E 96 BD AC B1 4D 66 5D B5 B0 0D 54 72 A6 14 4D EB 8D 81 CA 6C E1 D2 56
RX: 11:43:27 00 01 00 01 00 30 00 1C CC 1A 30 00 00 01 25 07 F9 6F DD 7A 95 B1 35 25 3A 84 D5 D2 C3 16 83 CA 97 52 B9 58
Index: 4 Value: 0
TX: 11:43:27 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 26 12 52 7D 1F 0D 6D E0 43 9A CF F7 FF 03 7D 0B 26 16 B6 20 27 23 BF C7 0F 8D
RX: 11:43:28 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 26 EA FD E4 F1 42 28 53 B2 E9 00 F9 27 11 44 4A 99 32 8D
Index: 5 Value: True
TX: 11:43:28 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 27 14 2D 97 0D DA 7E DA 5E 77 6D 12 28 BC BF C0 BF 84 B5 EA 70 B2 BB 7E 5D 57
RX: 11:43:29 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 27 59 07 FD B4 70 7E FD BC D8 17 C5 75 24 A2 13 99 6F 5D
Index: 6 Value: 0
TX: 11:43:29 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 28 F4 0A 65 1E AB 9B 86 C1 1E CE B9 32 D7 FD 15 3A 3A 8E A0 9D D7 56 7A 17 33
RX: 11:43:30 00 01 00 01 00 30 00 26 CC 24 30 00 00 01 28 A0 92 0D 8E 98 DD 42 D3 D4 07 17 CB 74 08 B0 D1 82 FF 76 CC BD 80 FD CC BA 40 A0 05 EE 18 5F
Index: 7 Value: bytearray(b'') bytearray(b'\x00\x00') 0
-------- Reading 20 0.0.13.0.0.255 Ch. 0 Activity calendar #1
TX: 11:43:30 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 29 85 C2 95 6A 87 07 EF 11 B0 80 5B 06 C6 E4 C1 55 00 D9 89 F6 6B 8E B6 6D 76
RX: 11:43:31 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 29 F9 F5 A7 DC 2D F8 B7 96 87 89 52 64 AC 97 ED B9 87 82 C5 1F EE A7 01 B4
Index: 1 Value: 0.0.13.0.0.255
TX: 11:43:31 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 2A 44 A2 59 23 E5 CC 9F 93 5F 35 0B C8 0F AE 4E B4 48 BF 51 E0 57 C7 54 2A 4B
RX: 11:43:32 00 01 00 01 00 30 00 22 CC 20 30 00 00 01 2A 35 7B 24 CC 0F 4A 49 77 EA 31 F6 F4 CA 92 E0 02 2F FC DF D1 30 E3 FF 5A 2E 90 30
Index: 2 Value: calendar1
TX: 11:43:32 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 2B 2E EA AE C4 16 19 DA B5 7F D0 45 5F 3C 5A 9F 5B 0C 56 9F 35 90 B5 D5 D7 5B
RX: 11:43:33 00 01 00 01 00 30 00 3A CC 38 30 00 00 01 2B 05 B8 D3 F1 8F 17 3C D6 5D 6B 03 C4 38 DE C8 82 95 6C 20 10 A7 7E 8F 62 52 8C F5 23 93 F6 57 59 64 62 02 10 01 96 5A C8 4F 6F A1 E2 3A A0 2E 5E CB F8 81
Index: 3 Value: Season1 23:59:00
TX: 11:43:33 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 2C B2 B6 7B A5 D7 4C CC C3 A9 A3 C6 56 65 2E 12 4F 3D 3A 32 9A E5 21 86 BA E7
RX: 11:43:34 00 01 00 01 00 30 00 31 CC 2F 30 00 00 01 2C 91 0D 86 3C 44 D0 90 33 23 4D 6D 1F AE 26 1C FF E5 D4 BD C7 D2 3C 1F D0 FD EE 32 5B 89 B6 95 E0 79 AE CF EA 3F 33 99 68 1F 61
Index: 4 Value: 57 45 45 4B 2D 31
TX: 11:43:34 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 2D 07 56 64 A7 79 4D 20 58 EF 6D 14 05 DF 68 2D 43 69 23 12 C9 36 65 A3 96 54
RX: 11:43:36 00 01 00 01 00 30 00 92 CC 81 8F 30 00 00 01 2D 37 73 C0 7C FC 07 71 C1 9C DE B6 4C 60 4E B2 DA CA 5E 2E AE D9 42 DB 27 5B D7 DA EB 88 AF 0D 97 60 69 A5 D8 96 E3 A2 4B D2 03 C8 AF EB 4C DA 70 EA E2 D9 E9 96 EA 3B E8 A5 B2 F5 40 A0 B8 BB 96 C2 02 56 66 69 48 DB D4 7F BB 7E 50 64 4C 06 7B 58 3D 8B 71 6C BC 61 F9 3A 0F 9E 15 F0 7E 93 A3 4C A4 E5 EC C9 65 B2 21 1A 86 9F BE 13 62 64 E9 10 C0 C8 92 97 50 23 7E 08 08 07 09 A6 CC 22 6E 1E D2 99 5B EC C5 ED 1C F1 A9
Index: 5 Value: 1 00:00:00 0.0.10.0.100.255 06:00:00 0.0.10.0.100.255 12:00:00 0.0.10.0.100.255 18:00:00 0.0.10.0.100.255 00:00:00 0.0.10.0.100.255 00:00:00 0.0.10.0.100.255
TX: 11:43:36 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 2E 08 AC B3 5C FE 37 1C 9A C7 10 45 2E 71 BE 6B 18 37 35 12 86 D4 CF 6D 5A CA
RX: 11:43:36 00 01 00 01 00 30 00 22 CC 20 30 00 00 01 2E 06 4B 95 71 F4 7E BE 37 71 AE A5 85 14 37 37 9E 8E 67 A9 F0 29 43 91 5A A8 97 5A
Index: 6 Value: calendar2
TX: 11:43:36 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 2F 3B 33 EA 9E 49 8B 20 65 3A 81 B2 CD 28 4A AB 34 C7 4B DD A5 01 B3 CE 6B 1C
RX: 11:43:37 00 01 00 01 00 30 00 3A CC 38 30 00 00 01 2F 91 E2 83 1A 53 80 06 D6 EC 58 4C B9 A6 0D 0A 14 66 37 35 EA 18 06 78 B7 8C 93 08 55 C2 74 A9 D0 9A 5B 79 25 47 4C 0A 91 8A 64 15 35 8A 9F 40 D0 89 6C C6
Index: 7 Value: Season1 23:59:00
TX: 11:43:37 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 30 8A A8 F7 E1 D2 39 F2 6C DE 4C 5A F8 16 36 7E 77 63 8F 72 C0 5F AA 16 DD 05
RX: 11:43:38 00 01 00 01 00 30 00 31 CC 2F 30 00 00 01 30 66 B1 E7 B9 A4 93 04 68 EB C5 49 B2 74 CC 4C AA F0 A2 01 2F 2E 5C 1A 7F 43 5D 4B FA 08 16 85 65 33 09 06 6F DC C5 DF 40 B9 50
Index: 8 Value: 57 45 45 4B 2D 31
TX: 11:43:38 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 31 93 EE EF 02 F0 E0 A4 92 9A 9E 47 53 04 E3 A0 B2 42 EE A5 76 B2 75 C7 86 CD
RX: 11:43:39 00 01 00 01 00 30 00 92 CC 81 8F 30 00 00 01 31 24 75 03 96 8E A3 B0 D9 9C 79 15 3A 72 A0 2F F1 1F 5C C5 10 68 67 50 D3 CB 60 BE 4B 4B 92 28 F4 53 12 86 59 F5 19 C9 08 F3 A6 86 8E 7C 52 AF 52 A4 6E FC D3 27 87 18 01 D7 22 59 3D 7E BD EF 27 2F 8B 91 95 C4 19 8A 40 3F 26 81 F6 C7 76 0F 6D E0 7C 38 1C D3 99 D9 94 33 66 5C A9 5C 90 10 D4 3C ED 8B 55 6D A7 06 9D 05 53 0B F7 C1 B0 10 BF 8C 1A CA 93 6C EC B8 6A 61 1E BE 23 F6 ED 48 77 55 27 5A 45 FD D6 AB B6 85 46
Index: 9 Value: 1 00:00:00 0.0.10.0.100.255 06:00:00 0.0.10.0.100.255 12:00:00 0.0.10.0.100.255 18:00:00 0.0.10.0.100.255 00:00:00 0.0.10.0.100.255 00:00:00 0.0.10.0.100.255
TX: 11:43:39 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 32 BB B5 24 8F 81 56 30 3B 5F F3 4F 8E 4B A3 63 C0 9B F3 41 FB 0C 03 91 63 FC
RX: 11:43:40 00 01 00 01 00 30 00 25 CC 23 30 00 00 01 32 23 DB 66 25 61 6F 4A 43 26 0C B0 E5 9A 49 64 1E 4A E4 04 31 FD 45 14 8C 0C EF FF 3C 35 78
Index: 10 Value:
-------- Reading 22 0.0.15.0.0.255 Ch. 0 End of billing period
TX: 11:43:40 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 33 5C 94 F4 2C 67 D6 4F 23 51 3B 28 BE 7F 6C D2 68 AF B5 DD 76 89 BF 15 AD 8F
RX: 11:43:41 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 33 7B 3A 37 28 F0 65 B1 03 C6 81 76 1F 71 BB 6E 06 D2 8F C2 23 F3 5A 92 7F
Index: 1 Value: 0.0.15.0.0.255
TX: 11:43:41 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 34 CE 12 5E E9 A3 10 A6 92 2F 42 B5 3B DF FA 80 80 BE A9 E7 4A 07 58 10 3B A4
RX: 11:43:42 00 01 00 01 00 30 00 24 CC 22 30 00 00 01 34 F7 63 D9 E5 7C D0 2A 5E D0 36 3E 10 C3 EB 53 5F B2 81 7E 8F AD FA 21 5A D7 BA FF B7 49
Index: 2 Value: 0.0.10.0.1.255, 1
TX: 11:43:42 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 35 84 C3 2A 5D F5 DE 8F 06 30 BE 66 74 93 A2 AF C1 D8 66 06 1E 15 92 40 EB 15
RX: 11:43:43 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 35 15 96 42 3E 1A 71 CE 49 85 A4 D5 71 BF 0B 2A EF F3 ED
Index: 3 Value: 1
TX: 11:43:43 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 36 63 3A 20 9A BE 0E 65 00 94 CC B7 F5 CC 38 2E 72 5B 04 D9 8D 0F DB 96 20 BF
RX: 11:43:44 00 01 00 01 00 30 00 28 CC 26 30 00 00 01 36 4A 7A 13 1C 8D E6 31 89 E4 FC 99 87 46 A7 F0 FB 6E 4A 5E 68 BD D4 3F 81 49 7C 3A 96 C9 61 CF 98 B6
Index: 4 Value: /01 00:00:000000
-------- Reading 22 0.0.15.0.2.255 Ch. 0 Image activation
TX: 11:43:44 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 37 8E 8D 27 34 07 94 8E 93 27 F2 E3 B1 B5 9B 30 C8 C2 E8 0B 92 08 2F 11 CA 98
RX: 11:43:45 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 37 7C 6A 0E E1 DA 45 9E 92 AE BE FC EC 0A DF 20 84 0B 83 7F 76 59 B9 D6 36
Index: 1 Value: 0.0.15.0.2.255
TX: 11:43:45 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 38 CA CE 9A B3 64 E6 5A 12 F7 FE B7 10 C5 B1 30 C4 01 9E 29 2A 6C 23 81 EA 2C
RX: 11:43:46 00 01 00 01 00 30 00 24 CC 22 30 00 00 01 38 23 11 51 D8 8B 43 82 5E CA 28 04 96 32 57 75 B1 8D 43 7A C3 5A B3 B4 F9 C5 1A F4 4B 58
Index: 2 Value: 0.0.10.0.107.255, 1
TX: 11:43:46 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 39 DF BC 03 05 0F 42 AC 84 69 F4 E5 8C D6 E4 1E 5F 07 E3 A2 80 55 D0 BE ED D0
RX: 11:43:47 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 39 A6 B0 98 B9 FA 40 F1 A4 18 39 F6 BD BB 5E 5C 72 03 2E
Index: 3 Value: 1
TX: 11:43:47 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 3A D8 02 0B 3A B4 30 BD 4C BE BA C3 A7 75 4F 2E AE E1 CA CC 3B 00 45 31 B4 24
RX: 11:43:48 00 01 00 01 00 30 00 28 CC 26 30 00 00 01 3A 45 39 68 C4 A8 D3 96 F1 2D F4 05 5C 8A BE F6 B7 D3 DA 70 FA AF 69 D0 A8 DC F3 EF D8 86 6C 54 50 63
Index: 4 Value:
-------- Reading 22 0.0.15.0.4.255 Ch. 0 Push
TX: 11:43:48 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 3B D8 9C C7 E8 0A 5E 87 2C 1A D5 49 44 85 74 68 EA 82 7F 94 96 6D 56 9E 1B C1
RX: 11:43:49 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 3B 7B F5 53 D4 9A 2B 9C CE B4 6B C9 B4 7E 15 9E 33 0F D7 D6 8A EE EE FB 64
Index: 1 Value: 0.0.15.0.4.255
TX: 11:43:49 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 3C 78 D6 14 E9 3B 74 EB DD 5E 03 AE 9F 9A 4F F5 40 2D 15 34 C4 8D 12 CE C6 EB
RX: 11:43:50 00 01 00 01 00 30 00 24 CC 22 30 00 00 01 3C 47 03 1C B5 5E CC 68 09 0F 6C 4B 21 7F 2B 3D BF 20 97 95 24 81 97 E6 B3 8D 84 A2 BD EA
Index: 2 Value: 0.0.10.0.108.255, 1
TX: 11:43:50 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 3D CE 15 4C 59 E0 95 A9 D6 B9 79 9A FE 90 1B 4F 37 E3 25 E5 24 BC 61 AD DF C9
RX: 11:43:51 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 3D 53 E3 EF B7 CF D1 DA 75 E5 5B 20 A1 69 F7 16 35 80 6B
Index: 3 Value: 1
TX: 11:43:51 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 3E 7E 68 27 61 79 A7 35 61 DF D3 C9 19 25 21 D8 D6 69 57 27 3D 49 71 5D 3A 1B
RX: 11:43:52 00 01 00 01 00 30 00 28 CC 26 30 00 00 01 3E AC CD 5C 02 0F C9 50 EE B5 8A 12 75 81 F4 72 9F 4D A4 3E DD AE 5D 68 FE 71 F0 44 90 B0 AE FD 81 B8
Index: 4 Value: :00:000000
-------- Reading 23 0.0.22.0.0.255 Ch. 0 IEC HDLC setup
TX: 11:43:52 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 3F 5C AC 82 7D 62 F6 C3 FF A5 B0 59 1A F5 DE 4D CF 77 2D B8 7F 87 C9 C4 43 2A
RX: 11:43:53 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 3F 9A 41 9C D8 B9 00 76 9B 94 FB 2A C9 61 1D 1B F1 AD C0 51 72 FC C4 AD 70
Index: 1 Value: 0.0.22.0.0.255
TX: 11:43:53 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 40 45 53 60 D9 08 78 33 43 D9 C5 5B D4 F5 26 0D CF 27 9A AF 1B E6 3A 48 73 60
RX: 11:43:54 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 40 51 09 A9 5B BE FB AA 14 B2 E8 B3 39 B4 AD 1C 17 09 98
Index: 2 Value: 5
TX: 11:43:54 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 41 12 CD 70 21 EA B6 15 1C EE C3 EB 05 BB 32 AB B6 33 27 71 4F 09 0D 7C A4 19
RX: 11:43:55 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 41 23 E3 34 93 75 BD A3 54 72 29 49 0C EA 0B C8 AC 30 65
Index: 3 Value: 1
TX: 11:43:55 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 42 30 AC D3 DD B8 1D 13 A9 5E 0B 8A 11 F9 EE 81 64 F7 C9 26 28 B3 D8 08 35 52
RX: 11:43:56 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 42 B3 1C 05 01 D1 EC 31 6F 7C 85 E6 CF 89 5C CB A6 96 D8
Index: 4 Value: 1
TX: 11:43:56 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 43 CE CB 37 AE 70 C7 8A DE B4 A8 68 55 0F 66 BB 83 3C 04 FC 5C C2 66 3B 7B FA
RX: 11:43:57 00 01 00 01 00 30 00 1A CC 18 30 00 00 01 43 BC C5 49 4C A2 CF 0A F9 B3 E1 99 F2 1C 04 95 3A C8 46 26
Index: 5 Value: 512
TX: 11:43:57 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 44 80 1D 74 50 A8 93 AF C6 1C 92 09 E1 92 48 72 4E 1E EE 0C 1D 90 51 0E D4 22
RX: 11:43:58 00 01 00 01 00 30 00 1A CC 18 30 00 00 01 44 7D EA 8B B0 F2 65 B9 D3 BF 03 32 8E 1F 1B D6 A2 01 9A FF
Index: 6 Value: 512
TX: 11:43:58 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 45 99 45 D9 C7 7F 68 FA 05 A8 69 74 96 7F F8 BB 9C 43 27 CF 35 A7 9C 9F EF E3
RX: 11:43:59 00 01 00 01 00 30 00 1A CC 18 30 00 00 01 45 1C A8 C9 AD 8C 44 FD 4F A4 C8 74 14 6E 14 45 43 2A AA 49
Index: 7 Value: 100
TX: 11:43:59 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 46 5E 8E 45 00 54 C6 D7 06 D6 C3 43 7E A9 8F 1B 7F 4D 77 E6 A6 23 3B 76 C3 59
RX: 11:44:00 00 01 00 01 00 30 00 1A CC 18 30 00 00 01 46 0B 25 56 A1 0E C7 EC 98 05 DC AB BA 20 A4 84 EE AE 42 59
Index: 8 Value: 5000
TX: 11:44:00 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 47 57 36 21 D0 89 93 8F 98 A4 D9 A4 4A 03 0C FB B8 0A 11 C2 2F F3 79 E6 CD 7A
RX: 11:44:01 00 01 00 01 00 30 00 1A CC 18 30 00 00 01 47 33 E6 83 BB 35 C4 6C 9B 99 08 D4 19 75 BA 65 A5 E6 AB F9
Index: 9 Value: 256
-------- Reading 40 0.0.25.9.0.255 Ch. 0 Push setup
TX: 11:44:01 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 48 75 FF E1 64 37 D3 D1 A9 C8 A0 6E 40 2E EA A1 BF 71 89 5D E7 FF B1 A3 6D A4
RX: 11:44:02 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 48 52 F4 AB D7 41 8F C8 E1 61 29 1D B0 53 F1 C4 20 31 DD 75 04 06 6A 5F D3
Index: 1 Value: 0.0.25.9.0.255
TX: 11:44:02 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 49 93 7A C2 D9 C1 A2 97 A3 0D 40 F2 16 EA 49 F0 40 0F 36 4A EA 0C 46 7C 8D D3
RX: 11:44:04 00 01 00 01 00 30 01 05 CC 82 01 01 30 00 00 01 49 8B 98 23 5D AB 31 92 02 4B FE 2A AD 4C 8E BC CD 3D F6 D3 68 8D C3 22 5A DE 4A 96 A5 84 F9 A7 3F 85 1E 8F 85 E3 FC FC 1A F0 3E 4B 73 F5 44 6E 5D 51 D8 87 38 A2 55 12 42 91 A0 62 83 98 8C F7 C7 BA DB 62 AC 86 CF 4C 24 DF D7 2D 63 99 B0 0B C4 48 CA A8 06 8B BD 2C 65 02 88 87 A7 C1 FC DC 05 B3 81 F1 4F ED 45 09 5D 87 88 66 DD 34 A6 17 BF 0A 24 A4 FA 69 56 5C 51 EA BB E9 95 58 C6 57 47 10 BC EE FC 74 18 0C 21 78 67 7C 82 88 02 8A 94 7A A9 E8 74 33 12 FB 1B 39 CA D3 24 CD D9 E2 0B 17 98 7C FB 08 95 D3 7A F3 21 67 39 B7 9D 04 39 08 DD 4F 01 E3 CE DF 6A 7F A6 C9 8F 09 F3 13 A7 14 EF 91 51 A9 36 EC 91 F5 97 12 CC 51 E2 24 21 36 C5 A4 40 95 92 C3 5F E6 30 D6 F2 C2 19 F6 AE 68 DA 32 D4 64 3B 23 94 09 1A F5 31 1A 7E 26 F7 C5 7D B8 11 74 90 44 AC 45 2D 9B 21
Index: 2 Value: (<gurux_dlms.objects.GXDLMSData.GXDLMSData object at 0x7f346d1e8d60>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x7f346e25e460>), (<gurux_dlms.objects.GXDLMSPushSetup.GXDLMSPushSetup object at 0x7f346d1a4e80>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x7f346d1942b0>), (<gurux_dlms.objects.GXDLMSClock.GXDLMSClock object at 0x7f346d185a60>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x7f346d0645b0>), (<gurux_dlms.objects.GXDLMSRegister.GXDLMSRegister object at 0x7f346d1de130>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x7f346d064670>), (<gurux_dlms.objects.GXDLMSRegister.GXDLMSRegister object at 0x7f346d1de280>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x7f346d064790>), (<gurux_dlms.objects.GXDLMSRegister.GXDLMSRegister object at 0x7f346d1de3d0>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x7f346d064340>), (<gurux_dlms.objects.GXDLMSRegister.GXDLMSRegister object at 0x7f346d1de520>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x7f346d0647c0>), (<gurux_dlms.objects.GXDLMSRegister.GXDLMSRegister object at 0x7f346d1de670>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x7f346d064430>), (<gurux_dlms.objects.GXDLMSRegister.GXDLMSRegister object at 0x7f346d1de7c0>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x7f346d064820>), (<gurux_dlms.objects.GXDLMSRegister.GXDLMSRegister object at 0x7f346d1de910>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x7f346d064880>), (<gurux_dlms.objects.GXDLMSRegister.GXDLMSRegister object at 0x7f346d1dea60>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x7f346d0648e0>), (<gurux_dlms.objects.GXDLMSRegister.GXDLMSRegister object at 0x7f346d1debb0>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x7f346d064940>), (<gurux_dlms.objects.GXDLMSExtendedRegister.GXDLMSExtendedRegister object at 0x7f346d1ca670>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x7f346d0649a0>)
TX: 11:44:04 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 4A 3D AD 1E B5 46 E0 AC 33 8E 2F 1D 8C 03 2E E2 4F 04 9C 80 54 D6 FC 35 2F D2
RX: 11:44:04 00 01 00 01 00 30 00 4D CC 4B 30 00 00 01 4A 8E C7 EB C6 03 F0 F1 23 11 74 64 68 45 76 36 04 AF D7 CB 26 A2 7B 9C A2 95 6D 50 91 31 99 20 2F 61 12 8B CB 51 CA DF CE 10 49 56 3B FD FC CC ED E3 3D 61 D1 AC 43 68 D0 A6 9D 74 D7 B6 A6 3E B0 D7 D4 E7 CA 24 7D
Index: 3 Value: (<ServiceType.UDP: 1>, '[2402:3A80:1702:2390:E847:542C:20F2:29DD]:4059', 0)
TX: 11:44:04 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 4B 71 1D 7D A1 CC 2D 32 29 CD A1 CF A5 9A A4 CC 33 DF E6 80 CF AD 2D BE BE F4
RX: 11:44:05 00 01 00 01 00 30 00 37 CC 35 30 00 00 01 4B BD 67 B1 01 14 E7 86 00 25 EF 87 FC 31 97 53 04 44 BB 22 8D 42 8E 3E 9F 41 85 47 67 E5 90 4D 91 75 6B 4F 01 F7 02 03 E2 F0 1D 82 8C A8 B1 18 01
Index: 4 Value: (<gurux_dlms.GXDateTime.GXDateTime object at 0x7f346d064ac0>, <gurux_dlms.GXDateTime.GXDateTime object at 0x7f346d0646d0>)
TX: 11:44:05 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 4C 34 76 77 CD 74 23 C1 BE 21 E2 3D 10 B3 92 42 B8 1B D2 84 AC 76 C8 70 0C E4
RX: 11:44:06 00 01 00 01 00 30 00 1A CC 18 30 00 00 01 4C 32 E7 BD 8A 47 42 1C BE 98 64 13 F4 01 AF 1D 9C 1A 41 CB
Index: 5 Value: 0
TX: 11:44:06 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 4D 66 DF 46 8E 81 1E 0F 9B BF AA AF 42 5A 06 4E 44 85 10 CB B8 71 20 60 A6 EB
RX: 11:44:07 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 4D 30 67 2E 1D 5F 4B 62 35 45 11 97 BF E0 97 F7 72 67 DF
Index: 6 Value: 5
TX: 11:44:07 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 4E D5 14 72 D9 9D 46 19 F9 77 16 5D 69 19 D7 BF 97 85 DA B3 74 9A C5 6E BE 6D
RX: 11:44:08 00 01 00 01 00 30 00 1A CC 18 30 00 00 01 4E 55 5D 70 F2 44 16 04 53 D3 60 FE 1F 53 89 CA 8E AB 58 CC
Index: 7 Value: 10
-------- Reading 40 0.4.25.9.0.255 Ch. 4 Push setup
TX: 11:44:08 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 4F 9D 36 27 B8 FC BC 1E 42 E0 16 D9 B7 83 1F 89 07 92 8B 6A 67 06 CE A7 9A BC
RX: 11:44:09 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 4F 40 27 C4 4B 12 33 36 F0 15 51 78 B3 43 01 C4 A5 7E CF 89 05 8E 9A 72 CF
Index: 1 Value: 0.4.25.9.0.255
TX: 11:44:09 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 50 44 08 65 99 74 F3 A7 E5 DB EF 31 53 75 55 0C 08 CD EE B3 6C 68 F6 25 BB F5
RX: 11:44:10 00 01 00 01 00 30 00 61 CC 5F 30 00 00 01 50 06 9F 26 DB 80 67 5D D7 7F 8F F7 06 8C F1 14 B2 CF 4D A5 75 48 62 CA EE 62 31 78 13 92 ED 82 3C 56 6D 13 E1 3B A7 FE 07 89 A4 11 59 3A 53 C8 05 92 A0 BF 86 B9 99 68 92 52 60 54 0E 7D C2 AE 26 77 94 90 DE 20 17 C7 DD EE 7A D7 1B 1B 01 F1 A6 4E FC 3E B3 3D 9D DE 20 7A 73
Index: 2 Value: (<gurux_dlms.objects.GXDLMSData.GXDLMSData object at 0x7f346d1e8d60>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x7f346e25e550>), (<gurux_dlms.objects.GXDLMSPushSetup.GXDLMSPushSetup object at 0x7f346d1aa340>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x7f346d064e20>), (<gurux_dlms.objects.GXDLMSClock.GXDLMSClock object at 0x7f346d185a60>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x7f346d064a60>), (<gurux_dlms.objects.GXDLMSData.GXDLMSData object at 0x7f346d194070>, <gurux_dlms.objects.GXDLMSCaptureObject.GXDLMSCaptureObject object at 0x7f346d064a90>)
TX: 11:44:10 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 51 08 4C BF 23 9B 0A CC BE 13 BD 50 02 6F 73 6E 7A 7A 7F D3 AD 1E 9E E5 C9 E9
RX: 11:44:11 00 01 00 01 00 30 00 4D CC 4B 30 00 00 01 51 C9 FB BA 38 77 1D C7 A2 60 91 BB 9C D7 54 1A CC 5D 30 90 BD 0B FA B1 FF FB 5C FE 70 08 96 18 73 85 6B 2F 17 2D 79 05 8C 48 85 53 52 5F D4 E8 9D 58 68 6F C8 3B AE AB 8F 35 63 F1 DC A6 E8 A0 36 0D 43 8D 50 B5 F6
TX: 11:44:11 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 52 C3 A4 76 60 1F 1D B6 67 79 2C AB 85 84 D1 E2 34 7E D8 4A 1E 80 9B 8F 8D 11
RX: 11:44:12 00 01 00 01 00 30 00 37 CC 35 30 00 00 01 52 90 38 7E 28 8B 92 84 D2 E5 81 9E 57 3E 1D FF 38 E0 B7 C4 02 BF BA 55 68 C6 05 2A D8 1C F6 CE 09 5E 16 96 1E 51 88 7B 5B 64 66 B4 A5 DE D9 50 EB
Index: 4 Value: (<gurux_dlms.GXDateTime.GXDateTime object at 0x7f346d064e80>, <gurux_dlms.GXDateTime.GXDateTime object at 0x7f346d064fd0>)
TX: 11:44:12 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 53 42 48 4B 30 F6 9F 7C EC FD 44 C6 34 CE E3 AA 0C 09 35 21 00 4E 78 AD F4 35
RX: 11:44:13 00 01 00 01 00 30 00 1A CC 18 30 00 00 01 53 27 E5 3E 05 1E 9D 05 D8 DC FB BA 64 F3 26 11 54 A4 1A 33
Index: 5 Value: 0
TX: 11:44:13 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 54 A6 C9 38 9F F9 2B E0 80 23 4C 75 A4 BA C7 C3 C3 C3 E4 8C 2F E1 AF 1E 78 00
RX: 11:44:14 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 54 E5 B9 9F 21 96 6E E2 98 F5 82 3C 22 B6 76 1E 80 56 1F
Index: 6 Value: 5
TX: 11:44:14 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 55 B4 CE 55 7E 89 1A 3F 40 45 BF 2D CB 7E 83 BA 06 F4 6B 15 1B 3A 5B 3E A6 D3
RX: 11:44:15 00 01 00 01 00 30 00 1A CC 18 30 00 00 01 55 9F A1 3C 58 B4 88 4A 12 68 A4 E5 9C 88 E7 1C 3E 24 C5 E7
Index: 7 Value: 10
-------- Reading 41 0.0.25.0.0.255 Ch. 0 TCP-UDP setup
TX: 11:44:15 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 56 F7 2C 0D 57 CD B1 3D 9D 3A B1 5F 61 4A 50 C2 DE 1D 58 2E E7 EE AD 0B F7 C9
RX: 11:44:16 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 56 53 C5 FB C0 F4 88 7E 59 E3 EE 31 FD E4 0F 07 33 04 43 4A 54 20 7D 62 60
Index: 1 Value: 0.0.25.0.0.255
TX: 11:44:16 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 57 16 0F 1E D8 EF 04 84 D5 9F 7F 06 81 AC 39 FA E8 57 89 FD AE C6 32 30 E7 9B
RX: 11:44:17 00 01 00 01 00 30 00 1A CC 18 30 00 00 01 57 35 BA DF E2 5D A7 BE 29 9F 7D CD 86 EF 69 1F 2F 90 69 40
Index: 2 Value: 4059
TX: 11:44:17 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 58 6D 81 50 A2 35 34 1C 3B 85 E4 70 29 4F F3 43 4F A1 6D E4 2D B9 8E 19 28 CA
RX: 11:44:18 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 58 E9 7A D4 A5 5C 2D 79 5E E9 8D 47 F8 42 AC F2 D7 9A 6E 8F 1A 26 1D 20 6E
Index: 3 Value: 0.0.25.7.0.255
TX: 11:44:18 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 59 6C 7C 76 1A 84 3A C7 61 F9 88 74 40 85 5C DA 2B A0 6F 07 88 62 BB 81 1E FC
RX: 11:44:19 00 01 00 01 00 30 00 1A CC 18 30 00 00 01 59 B7 94 DF D1 D9 56 3A 2A A6 15 08 5B 9C A0 A3 FC 16 78 29
Index: 4 Value: 576
TX: 11:44:19 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 5A A9 96 98 91 34 B2 A4 51 BA 4A 16 9D E4 7A 36 9F B6 AF 55 37 B1 66 03 E4 12
RX: 11:44:20 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 5A 0E 0E DE 68 FF CE AB 31 AD 1E 36 53 04 D4 89 6C F9 10
Index: 5 Value: 1
TX: 11:44:20 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 5B 58 E4 02 A4 14 41 12 FB 22 74 24 31 ED 22 EF 5D 8C 7D 60 E7 6F 38 B4 82 A0
RX: 11:44:21 00 01 00 01 00 30 00 1A CC 18 30 00 00 01 5B 97 09 6E 79 F7 83 F3 D7 D6 E5 88 7E 4D 89 2E C9 56 A5 A5
Index: 6 Value: 180
-------- Reading 45 0.0.25.4.0.255 Ch. 0 GPRS modem setup
TX: 11:44:21 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 5C 8F C6 0A 1F B9 C4 25 A7 B0 7E DD 97 EF 0C 7A C0 A9 C0 8B DA 3A 5C B3 71 E4
RX: 11:44:22 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 5C F3 00 69 48 46 D0 04 6F 1C CF 94 77 38 71 D6 B2 97 78 54 5C 01 8F 90 07
Index: 1 Value: 0.0.25.4.0.255
TX: 11:44:22 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 5D BB 06 0B EB 94 DD 43 BE 4C 09 64 C1 57 0A 28 BF 44 0E 8E 7D 05 07 8A B0 54
RX: 11:44:23 00 01 00 01 00 30 00 2C CC 2A 30 00 00 01 5D 3B 3C 57 02 B3 03 AF F7 1E 28 39 C4 A2 7C 51 A4 A6 4F 3A 35 F8 1B 6A D9 93 EE 7F C8 26 C8 37 F1 37 19 83 78 55
Index: 2 Value: m2m.meteripv6.co.in
TX: 11:44:23 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 5E CF 17 FE 49 9F F2 2A 85 E5 D4 40 CC E4 AE 8A 2F 2B 19 E7 93 A9 42 9B 74 02
RX: 11:44:24 00 01 00 01 00 30 00 1A CC 18 30 00 00 01 5E 6F 59 9B E0 1D D6 87 AD 40 B6 8C DA B4 53 FC 6E 1A 19 CE
Index: 3 Value: 0
TX: 11:44:24 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 5F 9A 96 DE 02 4B 89 B2 A9 57 A8 5B 50 2D 1C 74 E4 EB B6 0A 21 C1 81 42 0F 99
RX: 11:44:25 00 01 00 01 00 30 00 31 CC 2F 30 00 00 01 5F E7 99 31 B6 99 D9 90 11 D5 CB 58 98 0F F2 10 E8 8C 19 E3 7A F9 BF 6E 7D 16 FE BE ED 90 D6 D1 73 08 05 5B 00 CE 92 38 A7 B3 AB
Index: 4 Value: <gurux_dlms.objects.GXDLMSQualityOfService.GXDLMSQualityOfService object at 0x7f346d1aa6d0>
-------- Reading 48 0.0.25.7.0.255 Ch. 0 IPv6 setup
TX: 11:44:25 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 60 74 08 28 6D BA 92 C8 77 DA 34 E0 97 3E 97 48 2A 47 24 1E 06 FA 57 6D 98 59
RX: 11:44:26 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 60 2D 63 75 CB AA 18 BD 42 B0 F2 DE 65 01 AE FA 9F 2F 16 E4 08 9F 76 AE 1A
Index: 1 Value: 0.0.25.7.0.255
TX: 11:44:26 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 61 EC 6B 8C F6 C3 58 8C E3 1C 1C 4B 42 D4 8A EA C9 2D 3C 47 8A 7F 79 A2 32 21
RX: 11:44:27 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 61 75 EB 3E 00 F0 FF 5D 3D CC CC CE FB 24 6D D4 03 68 8F B0 32 A9 6E 6A 96
Index: 2 Value: 0.0.25.4.0.255
TX: 11:44:27 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 62 D3 B7 C7 CF 8E 68 AD 2C 37 AF D8 C6 8E E5 60 2C DB D7 EA B3 4B D3 FE 94 18
RX: 11:44:28 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 62 28 8F 25 B4 1E B8 65 52 A7 1E 13 94 8E 0A E7 95 CE 69
Index: 3 Value: AddressConfigMode.AUTO
TX: 11:44:28 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 63 B1 15 89 16 18 B7 1B D8 84 F9 53 4E A9 B7 B6 80 51 82 57 06 27 FA 8C EC D6
RX: 11:44:29 00 01 00 01 00 30 00 2B CC 29 30 00 00 01 63 93 A9 9B 8B C6 C0 C5 88 9C A3 A1 65 12 8D 9E 6A 26 BC 9D CB F3 01 39 94 AA 2A 9F 40 37 37 39 FB A1 88 7B 47
Index: 4 Value: 2402:4180:1702:116::1
TX: 11:44:29 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 64 A1 7D 07 1A 14 CA D7 50 45 51 1F 20 B5 84 D5 89 86 A0 46 D2 BF F6 FC 3B 48
RX: 11:44:30 00 01 00 01 00 30 00 2B CC 29 30 00 00 01 64 54 CE F5 3D C8 24 92 21 08 E2 F0 69 4F 38 87 B6 2D E0 6D 6B F8 54 DE DA 78 DC 84 4B AC AC AA 0D AD D7 71 A8
Index: 5 Value: ::
TX: 11:44:30 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 65 FF 97 8C 8F FD 9E 8F 00 B4 CD 48 58 1A 0D 2E 34 35 11 2A F3 BC 85 4D A9 AF
RX: 11:44:31 00 01 00 01 00 30 00 2B CC 29 30 00 00 01 65 E4 0D 9C 92 20 35 FC 31 BD D5 56 7E 34 BB 55 62 F7 BD 8A 4E CB A4 38 90 48 4B FD 9C 23 50 84 87 9B A4 00 28
Index: 6 Value: ::
TX: 11:44:31 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 66 33 38 CC D7 4D 1C A2 17 5F 86 EC F0 11 1E E9 D2 1B 3D 8A 7B 0A 53 F6 53 59
RX: 11:44:32 00 01 00 01 00 30 00 29 CC 27 30 00 00 01 66 D7 9F FC 8D EA B9 FC B3 FC 66 CC AC C8 36 6E 14 5E 55 B3 0B A8 CE 29 B0 26 3F BC 44 BA EA 38 11 36 15
Index: 7 Value: ::
TX: 11:44:32 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 67 05 E3 0B A2 7E 0C 0A 3D D2 B8 22 A4 3B 98 F5 76 6D 15 72 21 B8 03 BC 52 0E
RX: 11:44:33 00 01 00 01 00 30 00 29 CC 27 30 00 00 01 67 0A E3 89 8F 03 B4 6E 6C 37 D1 BF A4 66 E6 17 A4 50 5F 59 2E 75 1C 90 73 14 1B AF B3 78 DA 9D 7E F4 BC
Index: 8 Value: ::
TX: 11:44:33 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 68 76 ED BD FF 15 DE 78 8E 4C 66 CD F3 12 A2 F5 EB AC 36 2C CD 02 F7 D5 FE 3A
RX: 11:44:34 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 68 A5 84 F9 C2 EA E9 D9 35 98 3A E9 92 4A F3 50 97 BE EC
Index: 9 Value: 0
TX: 11:44:34 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 69 87 3A FC 54 0C 5A DC C3 70 C2 0F 18 4C 32 3E 8B 92 16 06 59 C7 9F C9 D3 D1
RX: 11:44:35 00 01 00 01 00 30 00 25 CC 23 30 00 00 01 69 4D 71 5B 3D 82 A0 7B 85 C6 D3 7F B4 3C 70 C5 E9 D5 97 DC C7 EE 09 F6 BC 2A 01 07 DA E0 42
Index: 10 Value: <gurux_dlms.objects.GXNeighborDiscoverySetup.GXNeighborDiscoverySetup object at 0x7f346e268910>
-------- Reading 64 0.0.43.0.2.255 Ch. 0 Security setup #2
TX: 11:44:35 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 6A D8 B4 75 3B 91 1F 86 8C B9 5D C9 00 E8 A6 9D 41 CB 9D 09 DE 22 EA 1F 19 0C
RX: 11:44:36 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 6A A2 90 14 CE 9F C5 22 4D 89 9E D8 00 66 F9 13 AE 69 8B 2B 6B E3 1E 8F 03
Index: 1 Value: 0.0.43.0.2.255
TX: 11:44:36 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 6B A4 73 FB 5A 2E 46 83 E2 B3 43 1A 1F CA 57 60 21 F8 87 9C 5C FF C6 A5 D8 C3
RX: 11:44:37 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 6B 19 DE 97 11 25 64 C5 55 E2 E8 BB 92 1E BC 02 C8 03 86
Index: 2 Value: SecurityPolicy0.ENCRYPTED
TX: 11:44:37 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 6C C5 DD 47 CF AC 10 96 68 4F 84 43 F8 F9 D7 0A C2 39 27 37 11 8E 12 C0 72 B1
RX: 11:44:38 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 6C 89 ED 43 F9 A5 20 EA 0A 3B FA 17 16 7B 1B 16 5E 28 4B
Index: 3 Value: 0
TX: 11:44:38 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 6D D0 F6 ED F4 63 58 F7 D5 2E 0B BF 09 65 7F 14 7E A3 87 F6 A7 2A B0 CE 27 6E
RX: 11:44:39 00 01 00 01 00 30 00 21 CC 1F 30 00 00 01 6D B7 A4 BD B4 DF 2D 17 E9 16 7C B0 F6 EB 17 14 F8 26 8F DD D8 F0 5A 95 90 DA 5E
Index: 4 Value: 31 52 45 4E 45 53 41 53
TX: 11:44:39 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 6E 14 76 A8 AA 57 70 B9 78 FF 4C FA B4 6D 00 88 88 36 71 1F 2F 1F 37 4D B5 D0
RX: 11:44:40 00 01 00 01 00 30 00 21 CC 1F 30 00 00 01 6E 84 6F B6 04 66 A5 6C 7D 2F E4 14 0A 71 A2 7E 12 5C 29 86 9E E2 6C EB 71 DE 20
Index: 5 Value: 54 49 49 30 30 30 30 30
-------- Reading 64 0.0.43.0.3.255 Ch. 0 Security setup #3
TX: 11:44:40 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 6F 01 62 65 E6 ED AB EE 74 D4 D0 CC 18 0F 37 4B 04 42 86 07 A2 1B 5D EB 1E 75
RX: 11:44:41 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 6F C5 77 5A 3B B3 6A CE 1E F8 0E E1 0E 15 37 CB 1A 30 76 98 7F 66 9B 06 73
Index: 1 Value: 0.0.43.0.3.255
TX: 11:44:41 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 70 B0 95 99 87 DD 5E B9 63 D4 1F 75 D4 4B BE 82 25 05 0E 7B F8 6A F2 48 68 77
RX: 11:44:42 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 70 34 61 AF E8 62 86 08 CD 30 D2 F0 D2 09 BA 20 6B 5E DD
Index: 2 Value: SecurityPolicy0.AUTHENTICATED_ENCRYPTED
TX: 11:44:42 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 71 D5 B0 99 18 5A 4B DE 4C 7A 83 D2 C1 63 D3 CF EF ED 15 7C AF EC A1 D5 85 0B
RX: 11:44:43 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 71 5B 69 B8 DB 90 BC 0A 84 80 46 96 A7 05 27 47 7C 06 3D
Index: 3 Value: 0
TX: 11:44:43 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 72 98 46 62 08 64 64 06 0F 02 B6 16 5A DD 13 24 CB 22 EC 53 D5 E6 00 99 9B A0
RX: 11:44:44 00 01 00 01 00 30 00 21 CC 1F 30 00 00 01 72 9D 8E 13 21 99 94 1D 2B 79 18 F8 3A 75 D2 7F 44 EC 02 12 AF A3 A5 B6 84 B8 0A
TX: 11:44:44 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 73 18 E1 75 61 1B 92 71 FD F9 67 08 7F 64 0A 67 52 49 95 58 6C 17 C0 62 A8 47
RX: 11:44:45 00 01 00 01 00 30 00 21 CC 1F 30 00 00 01 73 9F 2D F7 77 9E F3 43 05 1E 4B C9 56 79 CA 9B 66 A8 78 4E 77 96 3C 37 A7 D7 23
-------- Reading 64 0.0.43.0.4.255 Ch. 0 Security setup #4
TX: 11:44:45 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 74 3F 9C 8C 76 60 8D 5B E5 EA 35 8B 9B BE 70 D9 E8 73 C7 7F 0B 88 FC C8 ED D2
RX: 11:44:46 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 74 41 DF 0B 5B B1 56 FD 71 8E 2D 33 26 E8 A0 87 BE B7 83 24 A8 0F 51 1F 55
Index: 1 Value: 0.0.43.0.4.255
TX: 11:44:46 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 75 43 75 42 3C 66 B4 27 02 9B 75 7D CB C2 80 68 9C B2 24 67 F3 8F 82 A8 F4 58
RX: 11:44:47 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 75 21 0B F8 91 B9 6C 50 1C 28 F2 4E C1 7B D5 BD 07 08 DB
TX: 11:44:47 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 76 B1 3D DC BC A5 DE 4D 4C EF 42 79 0B F8 49 CE D7 1B EA 91 AC 7A 55 5A 7C D7
RX: 11:44:48 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 76 18 8C E6 A4 0F 34 64 0C A8 77 C5 5D 1D E5 21 B8 A8 B5
Index: 3 Value: 0
TX: 11:44:48 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 77 59 52 96 64 C7 11 2E 0C A8 89 13 9B 32 1D 9F 94 34 71 51 34 66 15 81 D2 26
RX: 11:44:49 00 01 00 01 00 30 00 21 CC 1F 30 00 00 01 77 53 F6 8A 79 B4 3A 27 42 23 14 24 F7 54 7C DE D9 3A A2 9F 9C B1 A7 CC 7A FB 38
TX: 11:44:49 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 78 13 9A 8C 57 B0 BB 92 DE 3C C9 B2 A8 C0 AE 07 15 3A DA 1A 3B E6 5F 20 59 AE
RX: 11:44:50 00 01 00 01 00 30 00 21 CC 1F 30 00 00 01 78 BB 2B D3 52 24 23 7D F1 05 0D 27 BD 6F E8 1D 95 2F 6F 0E 51 D3 43 EB A6 FC 6E
Index: 5 Value: 52 45 53 5F 50 55 53 48
-------- Reading 64 0.0.43.0.5.255 Ch. 0 Security setup #5
TX: 11:44:50 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 79 02 19 22 CB 63 E2 8F 11 79 34 78 D3 72 CF 4E CE AD 5E A5 95 4D 2E 32 87 F2
RX: 11:44:51 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 79 FE 03 99 C7 57 16 64 DE 25 15 60 04 E9 64 2A DB E5 4D A7 86 20 3C 8A DE
Index: 1 Value: 0.0.43.0.5.255
TX: 11:44:51 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 7A 84 C0 37 4A AD 8C C6 0A 1E 28 8D B1 E3 46 DD 96 67 E4 91 3D CD 4E E2 54 D6
RX: 11:44:52 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 7A 84 C9 A7 38 3E 5C 2F A1 91 68 FB 83 BD 56 74 7C 48 9F
TX: 11:44:52 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 7B C3 34 89 66 C5 E2 E7 CA 5A 71 C2 5C 21 F7 8C 01 EE 70 83 5D 79 A8 2F 32 24
RX: 11:44:53 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 7B 3C 16 97 FF 7D 0F 7A A3 A6 F6 E8 0A 97 5D 3A 2C 53 C4
Index: 3 Value: 0
TX: 11:44:53 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 7C 21 01 EB 66 F9 73 31 35 70 F9 5A 5D 87 28 8E BF 62 43 5E 38 4E 8E C8 1D 35
RX: 11:44:54 00 01 00 01 00 30 00 21 CC 1F 30 00 00 01 7C 3A 3C 92 6C 64 DE 54 8A 88 CB 2F D2 0D F9 D8 82 5A 04 B3 E7 A0 DD 66 46 02 38
TX: 11:44:54 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 7D 91 1B 03 B0 E8 11 E3 06 D2 4C 84 A5 09 C2 B1 CA E6 70 5B AE CC 6B 63 A5 89
RX: 11:44:55 00 01 00 01 00 30 00 21 CC 1F 30 00 00 01 7D A8 BC B0 24 D5 A7 8C D9 E4 BE D0 BF 65 AF 96 09 40 EE 2C 27 2F 8E E2 55 6B 68
-------- Reading 70 0.0.96.3.10.255 Ch. 0 Disconnect control
TX: 11:44:55 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 7E A4 1B 80 2D B2 12 28 83 9E 16 0B 23 72 DE 51 EF 46 69 DB B1 E1 A8 47 BD DA
RX: 11:44:56 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 7E 07 CC 1B 5E 34 47 F4 C0 E5 03 26 86 4F F8 4F C8 01 A2 54 B2 64 9C 32 58
Index: 1 Value: 0.0.96.3.10.255
TX: 11:44:56 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 7F A3 8D FB BB 73 E9 30 D9 24 A9 18 12 A5 95 AF 77 50 75 29 D2 7A CF 32 29 06
RX: 11:44:57 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 7F EA D1 38 70 1C E6 FA 45 38 FC FD 24 04 F2 28 EC DC 08
Index: 2 Value: True
TX: 11:44:57 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 80 F3 AD E7 0B 0B 64 67 07 15 D5 A5 62 F5 44 B0 A4 A5 72 B5 FE C5 AB 68 02 26
RX: 11:44:58 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 80 F4 95 89 22 7D 72 56 69 19 1A 72 72 F2 98 DA 33 78 34
Index: 3 Value: 1
TX: 11:44:58 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 81 CA 28 17 EC 45 17 CA 83 79 0A C2 73 8E 27 76 CB A8 67 55 22 8F 09 5C DF BC
RX: 11:44:59 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 81 37 BF 44 ED BE 15 4A 0C F1 C5 F3 51 AB 91 F6 83 88 0C
Index: 4 Value: 6
-------- Reading 71 0.0.17.0.0.255 Ch. 0 Limiter #1
TX: 11:44:59 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 82 C4 C4 66 93 84 B9 E9 63 E0 B1 F4 BF C6 55 98 03 D6 08 B6 BC 51 70 5C F2 2C
RX: 11:45:00 00 01 00 01 00 30 00 1F CC 1D 30 00 00 01 82 E4 6E 8E 6D 36 CE 59 16 5D CE 86 03 8F 26 4C D9 45 A1 18 2E 83 93 7C 17
Index: 1 Value: 0.0.17.0.0.255
TX: 11:45:00 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 83 60 A4 D7 85 0A 1B 20 C2 38 C0 E1 79 84 45 A2 4B CA 87 88 76 8D 94 6E D4 97
RX: 11:45:01 00 01 00 01 00 30 00 26 CC 24 30 00 00 01 83 E2 1C 3A 97 06 AF E2 11 A5 BD 8F 2B 07 EA 73 A4 D9 EF E7 67 C6 0C 7C 42 1D 44 19 21 FF A6 77
Index: 2 Value: 1.0.1.7.0.255 Ch. 0 Sum Li Active power+ (QI+QIV) Inst. value
TX: 11:45:01 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 84 09 E4 72 B4 61 E3 49 7F F3 FC 7E E7 E6 C9 82 25 60 7E AD A0 93 C0 16 09 B9
RX: 11:45:02 00 01 00 01 00 30 00 1A CC 18 30 00 00 01 84 DE 09 1F 13 87 71 D4 95 23 4A E5 7A 6C 67 3A 55 69 0E 1C
Index: 3 Value: 17280
TX: 11:45:02 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 85 82 E0 81 FA A6 90 65 B4 B2 A9 6C 7E 26 B7 48 CE 8D 13 3D E8 18 06 00 E9 34
RX: 11:45:03 00 01 00 01 00 30 00 1A CC 18 30 00 00 01 85 6D 32 B8 3F FB 78 F0 AF D0 38 20 92 00 2A ED DE F8 02 4D
Index: 4 Value: 17280
TX: 11:45:03 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 86 44 35 71 89 F9 B7 CE 40 BF A4 9A BF 3A 2B 2D 68 1F EB B2 94 95 AF DE 6B 8B
RX: 11:45:04 00 01 00 01 00 30 00 1A CC 18 30 00 00 01 86 2E C8 3F 1F B6 0E E3 02 C4 C2 1F E4 8B 76 E9 84 85 D5 D5
Index: 5 Value: 17280
TX: 11:45:04 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 87 BD 6F 55 5C D3 C3 A6 57 0B F4 43 1F CA A9 CE 61 4D 08 2F 2B 35 5B 98 DD D7
RX: 11:45:05 00 01 00 01 00 30 00 1C CC 1A 30 00 00 01 87 EE 49 9B 2B B1 D2 F0 7A 81 EE 1C A3 2A AE 95 9A B2 CC 7E 9E D4
Index: 6 Value: 120
TX: 11:45:05 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 88 29 D9 3C D1 49 81 13 F1 64 88 32 6B 2D B0 38 8A 9D 57 F2 D6 0A 08 7C DE AF
RX: 11:45:06 00 01 00 01 00 30 00 1C CC 1A 30 00 00 01 88 7D D2 26 EE 19 C7 D3 68 A7 2D 2F 96 E5 C6 4A F7 9D 4D 9D 3B D2
Index: 7 Value: 120
TX: 11:45:06 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 89 3A A3 C7 41 AC 80 34 78 C0 8E 52 29 2E 73 01 BF 92 C0 9E AF E3 78 42 91 9D
RX: 11:45:07 00 01 00 01 00 30 00 2F CC 2D 30 00 00 01 89 D1 D1 0E E8 84 14 C2 50 6E D4 80 22 6B 3B 30 4D 46 2A 41 6E D2 A2 5C 24 DF 20 B8 94 72 06 07 D2 0B 4E FB AD BA 66 97 2F
Index: 8 Value: 1 1
TX: 11:45:07 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 8A 03 BD 97 0D 51 3D 7B 44 18 21 B6 EF D3 BE 79 53 F0 67 2B D4 76 D2 1F AE D1
RX: 11:45:08 00 01 00 01 00 30 00 1C CC 1A 30 00 00 01 8A 5B AD 88 A9 8C 16 F7 FE AD B0 5E 52 45 76 A7 4C 9C E8 00 0E 95
Index: 9 Value: 1
TX: 11:45:08 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 8B F9 D6 ED E9 2C CC 6B 48 6C 6C DA 78 28 9F 8C BB 07 BB 5F 71 D6 E3 A1 BE 96
RX: 11:45:09 00 01 00 01 00 30 00 19 CC 17 30 00 00 01 8B EA F0 D5 CB DF 1E 05 E2 DF 2A 2D C6 9B 78 1A EA 50 E3
Index: 10 Value: False
TX: 11:45:09 00 01 00 30 00 01 00 20 C8 1E 30 00 00 01 8C 4B 13 9E C4 D9 8E 59 48 6B 7C D1 C2 07 2A C4 A4 90 C0 CD 67 C0 76 CB CE A0
RX: 11:45:10 00 01 00 01 00 30 00 33 CC 31 30 00 00 01 8C 43 40 70 E6 62 C2 E0 99 12 E2 70 EB 3E CC 9C 23 73 F4 09 D5 F1 EE 19 EF 7F 29 4E 93 0B C1 98 69 95 CE 8A 64 FD A2 52 3D 41 85 8D D7
Index: 11 Value: 0.0.10.0.106.255 2, 0.0.10.0.106.255 3
______final_saving the file device.xml
TX: 11:45:10 00 01 00 30 00 01 00 09 62 03 80 01 00 03 80 01 00
RX: 11:45:11 00 01 00 01 00 30 00 17 63 15 80 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 02 00 00 07
3 years 11 months ago
The meter doesn't start the block numbers from one and that is causing the issue.
Ask if there is a firmware update available for the meter. There is nothing you can do about it.
ravichandra99
Thanks for ur prompt reply,
I want to run multiple meters from this same server on same port 4059
As of now Im able to run only one meter
python3 main.py -h 2402:3A80:1702:116::1 -p 4059 -d DLMS -i WRAPPER -c 48 -a High -P TriHLS1234567890 -C AuthenticationEncryption -T 5452493030303030 -A 5472695F5F5F556E6963617374417363 -B 5472695F5F5F556E6963617374417363 -L TIS -s 1 -W 1 -l 0 -t Verbose -o device.xml
using above.. pls let me know how for multiple meters on same port using python
Hi Ravi,
Hi Ravi,
You need to establish a new TCP/IP connection and DLMS client for each meter.
You also need to set the correct server address. Usually you can count the server address from the meter serial number. You can try with this:
python3 main.py -h 2402:3A80:1702:116::1 -p 4059 -d DLMS -i WRAPPER -c 48 -a High -P TriHLS1234567890 -C AuthenticationEncryption -T 5452493030303030 -A 5472695F5F5F556E6963617374417363 -B 5472695F5F5F556E6963617374417363 -L TIS -n YOUR_METER_SERIAL_NUMBER -W 1 -l 0 -t Verbose -o device.xml
  • Georgegeowl
  • brsRKNujhfnXWm…
  • TmncVuWXpMBjtlVn
  • suMPQCGuZJqlCP…
