  3. DLMSVERSIONTO LOW
DLMSVERSIONTO LOW
By maham_elelc , 29 April, 2022
HI.I am try Read a meter In Gmac mode.
TX:7E A0 0A 00 02 90 77 21 93 55 7F 7E
RX:7E A0 23 21 00 02 90 77 73 18 F8 81 80 14 05 02 00 F0 06 02 00 F0 07 04 00 00 00 01 08 04 00 00 00 01 48 DC 7E
TX:7E A0 2E 00 02 90 77 21 10 33 C5 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 5D FF FF B3 E2 7E
RX:7E A0 3A 21 00 02 90 77 30 77 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 10 00 F0 00 07 EE 1D 7E
TX:7E A0 1C 00 02 90 77 21 32 D2 26 E6 E6 00 C0 01 C1 00 01 00 00 2B 01 00 FF 02 00 7D 8F 7E
RX:7E A0 18 21 00 02 90 77 52 5B 68 E6 E7 00 C4 01 C1 00 06 00 00 00 52 EA 69 7E
TX:7E A0 0A 00 02 90 77 21 53 59 B9 7E
RX:7E A0 0A 21 00 02 90 77 73 A2 DA 7E
TX:7E A0 21 00 02 90 77 03 93 D7 7A 81 80 12 05 01 F0 06 01 F0 07 04 00 00 00 01 08 04 00 00 00 01 F9 CB 7E
RX:7E A0 23 03 00 02 90 77 73 2E 75 81 80 14 05 02 00 F0 06 02 00 F0 07 04 00 00 00 01 08 04 00 00 00 01 48 DC 7E
TX:7E A0 6E 00 02 90 77 03 10 B6 12 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 3A 10 5B 47 6E 48 6B 6E 4A 07 55 1B 49 59 3B 57 BE 23 04 21 21 1F 30 00 00 00 53 61 2A AB 5E 99 B5 B3 C4 08 00 5C B7 AD 76 D4 91 A8 1B E7 8D 82 CA 80 E4 E4 2B BB DA 7E
RX:7E A0 30 03 00 02 90 77 30 16 18 E6 E7 00 61 1F A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 06 04 04 0E 01 06 01 9B 5F 7E
in the last recived Frame from Meter :
<HDLC len="2F" >
<TargetAddress Value="1" />
<!-- Logical address:1, Physical address:9275 -->
<SourceAddress Value="643B" />
<!-- AARE frame. -->
<FrameType Value="30" />
<PDU>
<AssociationResponse>
<!-- PermanentRejected -->
<AssociationResult Value="01" />
<ResultSourceDiagnostic>
<!-- NoReasonGiven -->
<ACSEServiceUser Value="01" />
</ResultSourceDiagnostic>
<ConfirmedServiceError>
<Service Value="01" />
<ServiceError>
<Initiate Value="DlmsVersionTooLow" />
</ServiceError>
</ConfirmedServiceError>
</AssociationResponse>
</PDU>
</HDLC>
What is means Of this Error?
Block cipher Key:00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F
A KEy:D0D1D2D3D4D5D6D7D8D9DADBDCDDDEDF
4 years 6 months ago
I believe that your block cipher and authentication keys are invalid. Check them from the meter vendor.
The client must use the same block cipher and authentication keys as the meter or the connection fails.
From the trace I can see that you can read the invocation counter from the meter, but the connection with ciphering fails.
