  3. Usb Serial Port / Connection Rejected
usb serial port / connection rejected
By baraa148 , 29 April, 2022
Gurux.Serial
Hi every one ,
this is my first time with dlms ..
I need to run a client python code for dlms
There is a meter connected to the pc via serial port on com6
When I write this command
Py main.py -S COM6
output :
gurux_dlms version: 1.0.122
gurux_net version: 1.0.18
gurux_serial version: 1.0.18
ClientAddress: 0x10
Standard: Standard.DLMS
Connection is permanently rejected
The application context name is not supported.
Note ,
My meter connected over com6
But , when I run the program like this
Py main.py
To see the avaliable serial ports
It just shows Com1
Why ?!
4 years 4 months ago
If you run an application without parameters it shows available serial ports. Try to read your meter with GXDLMSDirector first. It will show what command line parameter you should use. DLMS meter doesn't reply if one of your settings is wrong. I believe that you need to add -r sn parameter.
Py main.py -S COM6 -r sn
