Meter name :- Genus meter
Encryption Key + Authentication key :- 16 bit
Its a follow up on https://www.gurux.fi/comment/20393#comment-20393
I am Using Gurux_python code.
I am working on Genus meter and trying to read through optical port.
By simple command python3 main.py -S port No. (inside : Gurux.DLMS.Client.Example.python)
This command return me some value of meter details.
/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python$ python3 main.py -S Port No.
-------- Reading 15 0.0.40.0.1.255 Ch. 0 Association #1
Index: 1 Value: 0.0.40.0.1.255
Index: 2 Value: 0.0.40.0.1.255 Ch. 0 Association #1, 0.0.96.1.0.255 Ch. 0 Device ID 1, manufacturing number, 0.0.42.0.0.255 Ch. 0 COSEM Logical device name, 0.0.1.0.0.255 Ch. 0 Clock object #1, 0.0.41.0.0.255 Ch. 0 SAP Assignment, 0.0.40.0.0.255 Ch. 0 Current association
Index: 3 Value: 16, 1
Index: 4 Value: 2 16 756 5 8 1 1
Index: 5 Value: Conformance.GET 512 512 6 0
Index: 6 Value: 2 16 756 5 8 2 0
Attribute7 is not readable.
Index: 8 Value: 2
-------- Reading 1 0.0.96.1.0.255 Ch. 0 Device ID 1, manufacturing number
Index: 1 Value: 0.0.96.1.0.255
Index: 2 Value: GXXXXAAX7
-------- Reading 1 0.0.42.0.0.255 Ch. 0 COSEM Logical device name
Index: 1 Value: 0.0.42.0.0.255
Index: 2 Value:
-------- Reading 8 0.0.1.0.0.255 Ch. 0 Clock object #1
Index: 1 Value: 0.0.1.0.0.255
Index: 2 Value: 04/21/22 02:01:55
Index: 3 Value: 480
Index: 4 Value: 0
Attribute5 is not readable.
Attribute6 is not readable.
Attribute8 is not readable.
Index: 9 Value: 1
-------- Reading 17 0.0.41.0.0.255 Ch. 0 SAP Assignment
Index: 1 Value: 0.0.41.0.0.255
Index: 2 Value: (1, 'GXXXXXXXXXXXO')
-------- Reading 15 0.0.40.0.0.255 Ch. 0 Current association
Index: 1 Value: 0.0.40.0.0.255
Index: 8 Value: 2
1.But when i tried to read instantaneous or load Profile by providing -g OBIS Code, I am getting a error :-
File "main.py", line 106, in main
raise Exception("Unknown logical name:" + k)
Exception: Unknown logical name:1.0.12.44.0.255
So for confirmation of suitable obis code i also run this on meter tool and that tool are giving me response but same obis code is not working in GURUX code.
2. When i tried with 32 client address and provide Password and Authentication is Low
~/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python$ python3 main.py -S Port No.-c 32 -s 1 -a Low -P Password
ClientAddress: 0x20
Standard: Standard.DLMS
Connection is permanently rejected
The application context name is not supported.
3. When i tried with 32 client address and provide Password and Authentication is High
~/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python$ python3 main.py -S Port No. -c 32 -s 1 -a High -P Password
ClientAddress: 0x20
So need your help In how can i read profile data in guruX python code.
There is no object with the logical name 1.0.12.44.0.255 in the association view. Check your logical name or then you need to connect with High authentication.
Client address 32 is for Low-level security. You need to change it.
Read your meter with GXDLMSDirector. In that way, you can see the correct command line settings when you select the meter.
Thank you for your response.But i tried with GXDLMSDirector. I changed according you mentioned but not able to read profile.
Your security level is wrong. You need to use Encryption and not AuthenticationEncryption. Try to change that from the "Secured Connections" tab.
Hi there,
Hi there,
Thanks for reply. I have one question I am using wasion meter model (RA2110005). And trying with CLI. So do you support wasion dlms meter.
Our clients are reading Wasion meters. I can't remember the model, but you should be able to read your meter with Gurux products.
Hello, I am also trying to…
I am also trying to connect to a Genus Meter and got the exact same setup. Were you able to get this working?
This the output I am getting :
~/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python$ python3 main.py -S /dev/ttyUSB0
gurux_dlms version: 1.0.150
gurux_net version: 1.0.19
gurux_serial version: 1.0.20
ClientAddress: 0x10
Index: 2 Value: 0.0.40.0.1.255 Ch. 0 Association #1, 0.0.1.0.0.255 Ch. 0 Clock object #1, 0.0.42.0.0.255 Ch. 0 COSEM Logical device name, 0.0.96.1.0.255 Ch. 0 Device ID 1, manufacturing number, 0.0.40.0.0.255 Ch. 0 Current association
Index: 8 Value: 2
Attribute9 is not readable.
Index: 2 Value: 04/02/24 02:48:04
Index: 3 Value: 330
Index: 4 Value: 0
Index: 9 Value: 1
Index: 2 Value: GOERAPDRP-C
Index: 2 Value: 3101306
Index: 8 Value: 2
