  3. Read Works But Read_by_range Doesn't Work For ProfileGeneric Object
read works but read_by_range doesn't work for ProfileGeneric object
By tistepiste , 16 March, 2022
Dear,
I successfully created a ProfileGeneric object (in http://www.gurux.fi/node/19730) and I can also read out the contents from the buffer and capture objects using the function below:
def read(self, ln, gp):
profile_generic = GXDLMSProfileGeneric(ln)
gp.reader.read(profile_generic, 3)
gp.reader.read(profile_generic, 2)
return profile_generic
pg = reader.read(ln, gp)
I can easily read the buffer contents with this read using pg.buffer.
However, read_by_range doesn't seem to work.
read_by_range DOES work with another profile that was already set in the meter, it just doesn;t work on this specific profile
The code:
begin = datetime.datetime.now() - datetime.timedelta(days=2)
end = datetime.datetime.now() - datetime.timedelta(days=1)
def read_by_range(self, ln, begin, end, gp):
gp.reader.readRowsByRange(profile_generic, begin, end)
pg = reader.read_by_range(ln, begin, end, gp)
There IS data for those timestamps, and this code DOES work for another profile already set in the meter.
When I throw an Exception it reads the following:
Access Error : Device reports scope of access violated.
DLMS TRACE:
TX: 15:40:08 00 01 00 01 00 01 00 0D C0 01 C1 00 07 00 00 63 01 01 FF 03 00
RX: 15:40:10 00 01 00 01 00 01 00 2A C4 01 C1 00 01 02 02 04 12 00 04 09 06 00 01 18 02 01 FF 0F 02 12 00 00 02 04 12 00 08 09 06 00 00 01 00 00 FF 0F 02 12 00 00
TX: 15:40:10 00 01 00 01 00 01 00 40 C0 01 C1 00 07 00 00 63 01 01 FF 02 01 01 02 04 02 04 12 00 04 09 06 00 01 18 02 01 FF 0F 02 12 00 00 09 0C 07 E6 03 0E 01 0F 28 05 00 00 00 00 09 0C 07 E6 03 0F 02 0F 28 05 00 00 00 00 01 00
RX: 15:40:10 00 01 00 01 00 01 00 05 C4 01 C1 01 0D
Could you help me in finding out what I might be missing?
NOTE:
In GuruxDLMSDirector I am able to read out this profile between specific dates
4 years 4 months ago
Can you add GXDLMSDirector log so I can compare the date-time values?
tistepiste
I think I found the error.
I think I found the error. The buffer reads like this:
row = [19059, <gurux_dlms.GXDateTime.GXDateTime object at 0x7fa98d4d2a90>]
One row looks like what is stated above.
row[0] = value
row[1] = clock
read_by_range accesses index 0 of the capture objets and thinks that is the clock while it is not.
A solution would be for the buffer to save the values of the capture objects like this:
row = [<gurux_dlms.GXDateTime.GXDateTime object at 0x7fa98d4d2a90>, 19059]
But I am not sure how to reverse that order?
Or do I need to edit the read_by_range function, however I can't find where I can choose which capture object it reads
Hi.
Hi.
All the meters that I know are adding a clock for the first column. I strongly propose that you swap clock and value.
Swap the Capture objects (value and clock) and write them back for the meter.
http://www.gurux.fi/Gurux.DLMS.Objects.GXDLMSProfileGeneric
tistepiste
Dear,
Dear,
Thank you for your response.
Yes that is the issue I am trying to solve.
EDIT: Never mind, the code I had written to switch the columns actually works, just needed to overwrite the current stats.
  • kra4026
  • HilipLot
  • NithnCXPiBJHVG…
  • utkarsh9460
  • cWYHszETmudslY…
