  3. Reading Profile Generics
Reading profile generics
By kristupas , 23 February, 2022
What is the correct way to read profile generic buffer? I try to read load profile, but buffer is always empty. I am using simple server example (C).
First I read all attributes except 2 (buffer). I get those values (which are correct):
"1": "1.0.99.1.0.255",
"3": "[0.0.1.0.0.255, 1.1.21.25.0.255]",
"4": "0",
"5": "1",
"6": "0.0.1.0.0.255",
"7": "0",
"8": "170"
for (auto &pos : attributes) {
if (this->object->GetObjectType() == DLMS_OBJECT_TYPE_PROFILE_GENERIC && pos == 2) {
continue;
value.clear();
if ((this->object->GetAccess(pos) & DLMS_ACCESS_MODE_READ) != 0) {
if ((ret = this->server->comm->Read(this->object, pos, value)) != DLMS_ERROR_CODE_OK) {
fprintf(stderr, "Error! Index: %d read failed: %s\n", pos,
CGXDLMSConverter::GetErrorMessage(ret));
} else {
values.push_back(std::make_pair(pos, value));
Then I try to read attribute 2
this->server->comm->Read(this->object, 2, value)
And I still get empty value.
Am I missing some steps? I tried adding method 2, but it didnt help
CGXDLMSVariant methodVal;
this->server->comm->Method(this->object, 2, methodVal);
4 years 5 months ago
Use ReadRowsByEntry or ReadRowsByRange methods to read data from the buffer.
You can give index and count or start and end time and meter returns values from that range.
  • kra4026
  • HilipLot
  • NithnCXPiBJHVG…
  • utkarsh9460
  • cWYHszETmudslY…
