  3. Gurux.DLMS.Python GXXmlReader.GXDLMSConverter.changeType('0', DataType.BOOLEAN) = True
By alexav , 26 January, 2022
Hi, Mikko!
I found bug into GXDLMSObjectCollection.load() method
Deserialization of Item
<GXDLMSData>
<Value Type="3">0</Value>
</GXDLMSData>
return object_data.value=True
At method GXDLMSConverter.changeType() instead
ret = bool(value)
should fix on
ret = bool(int(value))
Alex
4 years 10 months ago
You are giving the integer as a string. You need to change it like this:
GXXmlReader.GXDLMSConverter.changeType(0, DataType.BOOLEAN)
This is not changed for now because a meter returns a boolean value as an integer value.
alexav
> You need to change it like this GXXmlReader.GXDLMSConverter.changeType(0, DataType.BOOLEAN)
No, i use Gurux.DLMS.GXDLMSObjectCollection.load(filename). Changes need to be made in Gurux.DLMS module https://github.com/Gurux/Gurux.DLMS.Python/blob/0e232efdeb44c39ac5a7205…
In method Gurux.DLMS.GXXmlReader.readElementContentAsObject():
str_ = self.currentElement.text # str_ = '0' - str type, not integer!
ret = GXDLMSConverter.changeType(str_, uiType) # uiType=DataType.BOOLEAN
# ret = True
Yes, you are right. Thank you for pointing this out. :-)
This is fixed and tested with Windows and Linux. The new version is released shortly.
Version 120 is released and your name is added for credits.
