  3. Data Does Not Show
Data does not show
By Dmitry , 11 January, 2022
Hi, Mikko!
I updated DLMSDirector to version 8.2.2112.2101.
After it does not show read data.
For example i try read Data (0.0.96.1.2.255). It contains octet string "1A2B3C".
Request:
7E A0 1F 03 61 54 A3 D3 E6 E6 00 D9 C0 00 00 05 00 01 01 00 01 00 00 60 01 02 FF 02 01 00 5F 6F 7E
Answer:
7E A0 1C 61 03 74 7C 31 E6 E7 00 DA C0 00 00 05 00 00 01 09 03 1A 2B 3C 01 01 00 4D 50 7E
But no effect.
In version 8.2.2110.0602 - OK.
Thanks!
4 years 6 months ago
I tested this and it worked without problems.
Select the 0.0.96.1.2.255 data object.
Then select "Acces rights" tab. What is UI Type and access?
They should be String and Read.
Dmitry
Yes. String and Read.
OS -Windows 11.
In version 8.2.2110.0602 - it works fine
Any ideas?
Dmitry
I try read Clock object -
I try read Clock object - same bug.
Request:
7E A0 6C 03 61 DC 6B A4 E6 E6 00 D9 C0 00 00 09 00 08 01 00 08 00 00 01 00 00 FF 02 01 00 08 00 00 01 00 00 FF 03 01 00 08 00 00 01 00 00 FF 04 01 00 08 00 00 01 00 00 FF 05 01 00 08 00 00 01 00 00 FF 06 01 00 08 00 00 01 00 00 FF 07 01 00 08 00 00 01 00 00 FF 08 01 00 08 00 00 01 00 00 FF 09 08 00 00 00 00 00 00 00 00 7E B0 7E
Answer:
7E A0 5A 61 03 FC 11 64 E6 E7 00 DA C0 00 00 09 00 00 08 09 0C 07 E6 01 0C 07 09 2B 3B FF FF 4C 00 10 FF 4C 11 00 09 0C FF FF 03 14 07 00 00 FF FF FF FF 00 09 0C FF FF 0A 18 07 00 00 FF FF FF FF 00 0F 00 03 00 16 00 08 01 00 01 00 01 00 01 00 01 00 01 00 01 00 01 00 D3 6A 7E
Dmitry
Version 8.1.2109.3001 also
Version 8.1.2109.3001 also works fine but it don't know NTP object
Can you select the current association view? What is the version number? You can see it after the Logical name.
We can repeat this. Select "Supported services" and deselect "Access". Now everything is working like expected. Tests are started and for this is releaded latest tomorrow.
This issue is fixed for version 8.2.2201.1302.
Dmitry
Thank you very much!
Is "Supported services"--->"Access" must be unchecked in version 8.2.2201.1302?
No, now it's working as it should be. The idea of this is that the default values are not shown.
The default values were causing some misunderstanding and for that reason only read values are shown.
Dmitry
Hmm.. When I select "Access"
Hmm.. When I select "Access" values are not shown.
I wrote video. Please, look at this (1 min): https://www.youtube.com/watch?v=PHMr11HX8Yo
You are right. The wrong commit was taken to the new build. The release of the updated build is started. It should be out in less than 30 mins.
The new version is out where this is fixed. I just tested it. Update to version 8.2.2201.1401.
I'm sorry about the hassle.
  • Vegazone-au
  • ksFhuuipOxKrxk…
  • sherylrk3
  • OLaneHycle
  • LxfgLnoisbruoL…
