  3. Connection Initialisation Fails [Arduino Example + ACE6000]
Connection Initialisation fails [Arduino example + ACE6000]
By zerow , 5 January, 2022
I'm trying to read data from smart meter ace6000 , i've been succeseful in reading its data from GXDirector so fat but when i try to establish connection with the meter using my mcu and the example provided i dont seem to manage to get it working .
the hardware connection is all good i tried reading the meter using the python library using my mcu as a proxy and it works however using the C library i seem to have some problem.
i'll join the logs plus the Gxdirector config i used
thank you for your support i hope of hearing back from you.
P.S: Forgot to include code snippet :
void setup() {
// put your setup code here, to run once:
TraceSerial.begin(9600);
HSerial.begin(9600);
GXTRACE(GET_STR_FROM_EEPROM("Start application"), NULL);
BYTE_BUFFER_INIT(&frameData);
//Set frame capacity.
bb_capacity(&frameData, 128);
Client.init(true, 1, Client.GetServerAddress(1,0x11,0), DLMS_AUTHENTICATION_LOW,"ABCDEFGH", DLMS_INTERFACE_TYPE_HDLC);
counter = millis();
void loop() {
int ret;
if (millis() - runTime > 5000)
runTime = millis();
GXTRACE(GET_STR_FROM_EEPROM("Start reading"), NULL);
//TODO: Change logical name of the frame counter if it's used.
ret = com_readAllObjects("0.0.43.1.0.255");
com_close();
//transparentMode();
zerow
4 years 6 months ago
Logs :
Logs :
:Start application :Start readingTransmiting ->
7E A0 8 2 23 3 93 3E 74 7E
DONE
Received ->
7E A0 23 3 0 2 0 23 73 C0 48 81 80 14 5 2 0 80 6 2 0 80 7 4 0 0 0 1 8 4 0 0 0 1 CE 6A 7E DONE
:Received bytes:
37 :Data send failed. Try to resend. 1
Transmiting ->
DONE
Received ->
Received ->
7E A0 23 3 0 2 0 23 73 C0 48 81 80 14 5 2 0 80 6 2 0 80 7 4 0 0 0 1 8 4 0 0 0 1 CE 6A 7E 7E A0 23 3 0 2 0 23 73 C0 48 81 80 14 5 2 0 80 6 2 0 80 7 4 0 0 0 1 8 4
:Received bytes:
74 :Data send failed. Try to resend. 2
Transmiting ->
DONE
Received ->
Received ->
0 0 0 1 CE 6A 7E 7E A0 23 3 0 2 0 23 73 C0 48 81 80 14 5 2 0 80 6 2 0 80 7 4 0 0 0 1 8 4 0 0 0 1 CE 6A 7E DONE
:Received bytes:
111 :Data send failed. Try to resend. 3
Transmiting ->
DONE
Received ->
Received ->
0 0 0 1 CE 6A 7E 7E A0 23 3 0 2 0 23 73 C0 48 81 80 14 5 2 0 80 6 2 0 80 7 4 0 0 0 1 8 4 0 0 0 1 CE 6A 7E 7E A0 23 3 0 2 0 23 73 C0 48 81 80 14 5 2 0 80 6 2 0 80 7 4 0 0 0 1 8 4 0 0 0 1 CE 6A 7E DONE
:Received bytes:
148 :com_initializeConnection failed 252
DONE
Received ->
:Received bytes:
Transmiting ->
DONE
Received ->
Received ->
ACE6000 is a special case.
Change this:
to:
Client.GetServerAddress(1,0x11,4)
  • UIRlLOZQoyTZHC…
  • mpjTCKVBgHdfcCSDJDRc
  • BaEdhlfwwvUqFMkOYk
  • CrzONrPdvkWUif…
  • kra4026
