  3. Om_initializeConnection Failed 279A
om_initializeConnection failed 279A
By benyamin.chesh… , 5 January, 2022
Hello
I added variables here according to the software but I can not connect?
void setup() {
GXTRACE(GET_STR_FROM_EEPROM("Start application"), NULL);
BYTE_BUFFER_INIT(&frameData);
//Set frame capacity.
bb_capacity(&frameData, 128);
//Client.init(true, 16, Client.GetServerAddress(1,0x157D,2), DLMS_AUTHENTICATION_NONE, NULL, DLMS_INTERFACE_TYPE_HDLC);
////Un-comment this if you want to set system title, block cipher key or authentication key.
Client.SetSecurity(DLMS_SECURITY_AUTHENTICATION_ENCRYPTION);
//TODO: Change logical name of the frame counter if it's used to com_readAllObjects.
gxByteBuffer bb;
bb_init(&bb);
bb_addHexString(&bb, "31 32 33 34 35 36 37 38");
Client.SetSystemTitle(&bb);
bb_clear(&bb);
bb_addHexString(&bb, "D0 D1 D2 D3 D4 D5 D6 D7 D8 D9 DA DB DC DD DE DF");
Client.SetAuthenticationKey(&bb);
bb_clear(&bb);
bb_addHexString(&bb, "00 01 02 03 04 05 06 07 08 09 0A 0B 0C 0D 0E 0F");
Client.SetBlockCipherKey(&bb);
bb_clear(&bb);
//Authentication.HIGH_GMAC, "01234567"
//Serial 1 is used to send trace.
Client.init(true, 1, Client.GetServerAddress(1,0x157D,0), DLMS_AUTHENTICATION_HIGH_GMAC, "12345678", DLMS_INTERFACE_TYPE_HDLC);
Serial1.begin(9600);
in terminal:
13:02:58.952 -> 279 :Start reading :com_initializeConnection failed 279
13:03:03.936 -> 279 :Start reading :com_initializeConnection failed 279
13:03:08.916 -> 279 :Start reading :com_initializeConnection failed 279
13:03:13.943 -> 279 :Start reading :com_initializeConnection failed 279
13:03:18.937 -> 279 :Start reading :com_initializeConnection failed 279
4 years 10 months ago
I have good news. I can repeat this. I don't know the reason yet, but now it's possible to solve.
I'll keep you posted.
benyamin.chesh…
I am waiting for your answer,
I am waiting for your answer, sir
Thank you very much for your kindness in answering
Get the latest version. Copy src and include from development folder under client example.
Then Un-comment security part from setup-function and change client and server address and authentication level. Let me know if you have any problems.
benyamin.chesh…
hex sent:
hex sent:
7E A0 0A 00 02 54 FB 21 93 2F 9F 7E 7E A0 2E 00 02 54 FB 21 10 49 25 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E 7E A0 1C 00 02 54 FB 21 32 A8 C6 E6 E6 00 C0 01 81 00 01 00 00 2B 01 00 FF 02 00 78 42 7E 7E A0 0A 00 02 54 FB 21 53 23 59 7E 7E A0 0A 00 02 54 FB 03 93 AC 8F 7E 7E A0 6E 00 02 54 FB 03 10 CC F2 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 0C 06 83 41 20 90 C8 64 32 19 8C C6 E3 F1 78 BC BE 23 04 21 21 1F 30 FF FF BA D3 E8 AD 27 F4 F6 FC 8B F4 02 AB 13 25 9A C3 65 D4 3C F2 E2 F8 4A 0D 80 4A 8A 36 35 A9 7E 7E A0 3E 00 02 54 FB 03 32 13 82 E6 E6 00 CB 2D 30 FF FF BA D4 D2 D7 97 6C 51 86 FC 8A C2 11 68 64 AF C6 C7 DB 3E CD 39 1D 0A B4 11 FB 6F F5 04 DF 60 B2 B9 3A 9B 48 B7 11 A2 DE 20 97 58 C8 7E 7E A0 0A 00 02 54 FB 03 53 A0 49 7E 7E A0 0A 00 02 54 FB 21 93 2F 9F 7E 7E A0 2E 00 02 54 FB 21 10 49 25 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E 7E A0 1C 00 02 54 FB 21 32 A8 C6 E6 E6 00 C0 01 81 00 01 00 00 2B 01 00 FF 02 00 78 42 7E 7E A0 0A 00 02 54 FB 21 53 23 59 7E 7E A0 0A 00 02 54 FB 03 93 AC 8F 7E 7E A0 6E 00 02 54 FB 03 10 CC F2 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 5E AF 57 2B 95 4A 25 12 89 44 22 11 88 44 A2 D1 BE 23 04 21 21 1F 30 FF FF BA D6 54 76 AC 39 4A B0 C7 29 F1 3A BE 01 54 8D 34 EA E7 A8 CA CF 03 A3 94 EE E6 A5 4F 34 7E 7E A0 3E 00 02 54 FB 03 32 13 82 E6 E6 00 CB 2D 30 FF FF BA D7 6D 6E 15 4E A0 F0 9D C7 6A 0D BC B0 CC AF 53 3F 42 FB E8 35 8E D0 4B FB 97 41 21 82 18 8E 05 30 DA B4 20 34 1D 0C 92 66 4D AC 7E 7E A0 0A 00 02 54 FB 03 53 A0 49 7E
rx arduino terminal
:Start reading:Invocation Counter: -17710:com_initializeConnection failed 258:Start reading:Invocation Counter: -17707:com_initializeConnection failed 258
benyamin.chesh…
I tried it in GuruxDLMS.c
I tried it in GuruxDLMS.c client's example, it 's still the same as before
GuruxDLMS.c-master\GuruxDLMSClientExample\VS\x64\Release>GuruxDLMSClientExample.exe -S COM8 -c 1 -s 21885 -a HighGmac -C AuthenticationEncryption -T 3132333435363738 -A D0D1D2D3D4D5D6D7D8D9DADBDCDDDEDF -B 000102030405060708090A0B0C0D0E0F -v 0.0.43.1.0.255 -t Verbose
updateInvocationCounter
TX: 7E A0 0A 00 02 54 FB 21 93 2F 9F 7E
RX: 7E A0 23 21 00 02 54 FB 73 8F B4 81 80 14 05 02 01 00 06 02 01 00 07 04 00 00 00 01 08 04 00 00 00 01 69 6D 7E
TX: 7E A0 2E 00 02 54 FB 21 10 49 25 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E
RX: 7E A0 3A 21 00 02 54 FB 30 E0 30 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 10 10 05 00 00 07 8D FF 7E
TX: 7E A0 1C 00 02 54 FB 21 32 A8 C6 E6 E6 00 C0 01 81 00 01 00 00 2B 01 00 FF 02 00 78 42 7E
RX: 7E A0 18 21 00 02 54 FB 52 CC 24 E6 E7 00 C4 01 81 00 06 FF FF BB D1 98 C5 7E
Invocation counter: -17454 (0xFFFFBBD2)
TX: 7E A0 0A 00 02 54 FB 21 53 23 59 7E
RX: 7E A0 0A 21 00 02 54 FB 73 35 96 7E
InitializeConnection
TX: 7E A0 0A 00 02 54 FB 03 93 AC 8F 7E
RX: 7E A0 23 03 00 02 54 FB 73 B9 39 81 80 14 05 02 01 00 06 02 01 00 07 04 00 00 00 01 08 04 00 00 00 01 69 6D 7E
TX: 7E A0 6E 00 02 54 FB 03 10 CC F2 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 FF FF BB D2 EC 78 94 1D D4 53 51 89 1A CC 7B 75 F3 6C 5C D4 61 06 D3 F1 86 55 38 9D F9 9D 7F CC 7E
RX: 7E A0 72 03 00 02 54 FB 30 3C A4 E6 E7 00 61 61 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 45 41 41 07 00 2D 8A 35 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 0A 80 08 D6 1F 64 FF 05 6F 79 0A BE 23 04 21 28 1F 30 00 00 02 40 61 CB 61 C7 05 D6 73 16 7E F3 F9 A9 6F EC A3 34 F0 76 C7 2A E5 F5 00 CD 65 66 DD C5 7E
TX: 7E A0 3E 00 02 54 FB 03 32 13 82 E6 E6 00 CB 2D 30 FF FF BB D3 91 6D A6 2A 91 71 FC 67 98 BD 5A 97 87 A6 92 BA A7 9A 64 DC 8A 94 22 69 3F 01 94 26 68 72 5F CC C3 16 86 97 3F 7C 8D C7 C0 D6 7E
RX: 7E A0 12 03 00 02 54 FB 52 AD 40 E6 E7 00 D8 01 01 3C 43 7E
TX: 7E A0 0A 00 02 54 FB 03 53 A0 49 7E
RX: 7E A0 0A 03 00 02 54 FB 73 03 1B 7E
OperationNotPossible
Select Help and About. What is your Arduino IDE version?
Do you have a link for your Arduino board?
benyamin.chesh…
Arduino IDE version 1.8.15
No, I did not use the link
There were problems with one Arduino version and I can't remember the version right now. Can you get version 1.8.19 and try with that?
When I was told that I can repeat this error the reason was that the block cipher key was for a different meter. So everything works with Arduino Mega that we have.
BR.
benyamin.chesh…
im install 1.8.19
im install 1.8.19
arduino version 1.8.19
terminal
:Start reading:Invocation Counter: -17425:com_initializeConnection failed 258:Start reading:Invocation Counter: -17422:com_initializeConnection failed 258
hex sent
7E A0 0A 00 02 54 FB 21 93 2F 9F 7E 7E A0 2E 00 02 54 FB 21 10 49 25 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E 7E A0 1C 00 02 54 FB 21 32 A8 C6 E6 E6 00 C0 01 81 00 01 00 00 2B 01 00 FF 02 00 78 42 7E 7E A0 0A 00 02 54 FB 21 53 23 59 7E 7E A0 0A 00 02 54 FB 03 93 AC 8F 7E 7E A0 6E 00 02 54 FB 03 10 CC F2 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 CE E7 73 39 1C 8E C7 E3 F1 78 BC 5E AF 57 2B 15 BE 23 04 21 21 1F 30 FF FF BB F0 29 CA 74 AA 85 69 2E 2D 00 2C 00 A1 CD 01 4F 1A 3F FF A7 1B 76 07 FC FA DB 26 10 1C 7E 7E A0 3E 00 02 54 FB 03 32 13 82 E6 E6 00 CB 2D 30 FF FF BB F1 0B EF CD A3 80 7B 27 D7 A3 31 22 69 54 91 27 87 6A FF C4 C7 F6 E6 DC 83 D4 07 FD 06 B3 8C 3E FB C9 72 B5 A4 36 C4 10 07 B7 1C 7E 7E A0 0A 00 02 54 FB 03 53 A0 49 7E 7E A0 0A 00 02 54 FB 21 93 2F 9F 7E 7E A0 2E 00 02 54 FB 21 10 49 25 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E 7E A0 1C 00 02 54 FB 21 32 A8 C6 E6 E6 00 C0 01 81 00 01 00 00 2B 01 00 FF 02 00 78 42 7E 7E A0 0A 00 02 54 FB 21 53 23 59 7E 7E A0 0A 00 02 54 FB 03 93 AC 8F 7E 7E A0 6E 00 02 54 FB 03 10 CC F2 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 0A 05 02 81 40 20 10 88 44 A2 51 28 94 4A A5 52 BE 23 04 21 21 1F 30 FF FF BB F3 B3 4D 43 1F 89 7A E9 F6 FD 2A 20 11 FA 36 F4 8C 4C BF 0E EA 84 1C 8D C5 7F EB B7 C9 7E 7E A0 3E 00 02 54 FB 03 32 13 82 E6 E6 00 CB 2D 30 FF FF BB F4 9B 81 C1 66 88 2A E2 DE 4C 66 1E B2 37 9A 67 C6 9B 00 DC D1 44 CA 89 F3 A7 C2 69 35 DA DA 5D 8A 82 7E B2 B4 A7 38 F4 06 B2 28 7E 7E A0 0A 00 02 54 FB 03 53 A0 49 7E
benyamin.chesh…
Sir
Sir
In my opinion, it is not related to Ardino. In clientexample's example in Visual Studio, there is also the problem that I have sent the hex code above.
We made a simulated meter that is using your client and server address. The initial Invocation counter value is the same as what you are using. Everything works without problems with Visual Studio and Android.
Can you run client example for ANSI C with those command line parameters and add output here?
-h YOUR_METER_IP_ADDRESS -p YOUR_METER_PORT_NUMBER -c 1 -a HighGMAC -P Gurux -t Verbose -s 21885 -v 0.0.43.1.0.255 -C AuthenticationEncryption
There is a fix that shows the correct Invocation counter value (4294951017 , not -17425).
benyamin.chesh…
hi invocation counter not
hi
problem:
7E A0 0A 00 02 54 FB 21 93 2F 9F 7E 7E A0 2E 00 02 54 FB 21 10 49 25 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E 7E A0 1C 00 02 54 FB 21 32 A8 C6 E6 E6 00 C0 01 81 00 01 00 00 2B 01 00 FF 02 00 78 42 7E 7E A0 0A 00 02 54 FB 21 53 23 59 7E 7E A0 0A 00 02 54 FB 03 93 AC 8F 7E 7E A0 6E 00 02 54 FB 03 10 CC F2 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 00 00 16 5C 0A A2 C3 07 19 49 41 BF 28 04 50 48 4A BF 7B FF 35 BA D0 19 8F 98 08 82 30 67 07 F2 7E 7E A0 3E 00 02 54 FB 03 32 13 82 E6 E6 00 CB 2D 30 00 00 16 5D DF 83 89 2F 71 C1 85 0D 74 53 99 72 4E 16 70 AA 6D A1 30 6E C4 7B 54 A1 B7 40 C3 29 2F 40 EE 18 8C 0A DD 75 E6 CC 8F 15 B0 71 7E 7E A0 0A 00 02 54 FB 03 53 A0 49 7E 7E A0 0A 00 02 54 FB 21 93 2F 9F 7E 7E A0 2E 00 02 54 FB 21 10 49 25 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E 7E A0 1C 00 02 54 FB 21 32 A8 C6 E6 E6 00 C0 01 81 00 01 00 00 2B 01 00 FF 02 00 78 42 7E 7E A0 0A 00 02 54 FB 21 53 23 59 7E 7E A0 0A 00 02 54 FB 03 93 AC 8F 7E 7E A0 6E 00 02 54 FB 03 10 CC F2 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 91 C8 E4 72 39 1C 8E 47 A3 D1 E8 74 BA DD 6E 37 BE 23 04 21 21 1F 30 00 00 16 5F 6D CF 45 CA 90 D3 A2 F1 0B 7B FE 06 74 35 F6 FA 5C AF 3F 1F 81 E6 D1 11 41 50 DA 49 7E 7E A0 3E 00 02 54 FB 03 32 13 82 E6 E6 00 CB 2D 30 00 00 16 60 57 3C 70 CE A2 67 75 93 E8 F9 58 C5 07 E4 25 57 9D F0 92 B7 AC 9A 29 E8 94 2E BD 25 E9 DA A4 45 6C 09 43 A7 0F 7D E9 F5 7B 8D 7E 7E A0 0A 00 02 54 FB 03 53 A0 49 7E
5249:com_initializeConnection failed 258:Start reading:Invocation Counter: 5252:com_initializeConnection failed 258:Start reading:Invocation Counter: 5255:com_initializeConnection failed 258:Start reading:Invocation Counter: 5258:com_initializeConnection failed 258:Start reading:Invocation Counter: 5261:com_initializeConnection failed 258:Start reading:Invocation Counter: 5264:com_initializeConnection failed 258:Start reading:Invocation Counter: 5267:com_initializeConnection failed 258:Start reading:Invocation Counter: 5270:com_initializeConnection failed 258:Start reading:Invocation Counter: 5273:com_initializeConnection failed 258
benyamin.chesh…
Hello, I did not understand
Hello, I did not understand these two cases, how should ip and port number?im use serial rs485 for connect to meter
In reply to Hello, I did not understand by benyamin.chesh…
For serial port try with those parameters:
-S YOUR_SERIAL_PORT -c 1 -a HighGMAC -P Gurux -t Verbose -s 21885 -v 0.0.43.1.0.255 -C AuthenticationEncryption
BR.
benyamin.chesh…
-----recieve terminal
:Start reading:Invocation Counter: 5723:com_initializeConnection failed 258:Start reading:Invocation Counter: 5726:com_initializeConnection failed 258:Start reading:Invocation Counter: 5729:com_initializeConnection failed 258:Start reading:Invocation Counter: 5732:com_initializeConnection failed 258:Start reading:Invocation Counter: 5735:com_initializeConnection failed 258:Start reading:Invocation Counter: 5738:com_initializeConnection failed 258:Start reading:Invocation Counter: 5741:com_initializeConnection failed 258:Start reading:Invocation Counter: 5744:com_initializeConnection failed 258:Start reading:Invocation Counter:
benyamin.chesh…
GuruxDLMSClientExample.exe -S COM11 -c 1 -s 21885 -a HighGMAC -P Gurux -t Verbose -s 21885 -v 0.0.43.1.0.255 -C AuthenticationEncryption -T 3132333435363738 -A D0D1D2D3D4D5D6D7D8D9DADBDCDDDEDF -B 000102030405060708090A0B0C0D0E0F
RX: 7E A0 18 21 00 02 54 FB 52 CC 24 E6 E7 00 C4 01 81 00 06 00 00 17 27 5F 52 7E
Invocation counter: 5928 (0x1728)
TX: 7E A0 6E 00 02 54 FB 03 10 CC F2 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 31 32 33 34 35 36 37 38 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 00 00 17 28 02 2C A1 E8 E0 85 6B B2 1F F1 96 6E 78 2D A7 F6 38 5E B2 1C 53 95 B2 BA D6 C9 50 D9 7E
RX: 7E A0 72 03 00 02 54 FB 30 3C A4 E6 E7 00 61 61 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 45 41 41 07 00 2D 8A 35 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 0A 80 08 FE 83 B5 63 F0 36 98 77 BE 23 04 21 28 1F 30 00 00 02 3F 99 80 4D 09 70 07 60 76 4F 31 AF 47 34 2E 52 C9 DD E6 B8 EE 2D 2A F1 DA E5 20 7C 55 7E
TX: 7E A0 3E 00 02 54 FB 03 32 13 82 E6 E6 00 CB 2D 30 00 00 17 29 2B 46 7A B7 FE D1 F1 4F 46 2D 55 4E 7C 68 0D 7C ED 34 D4 FC 84 3F AB 5A 05 27 67 45 70 FD 81 C7 20 D9 85 98 4C 75 63 79 8E 1E 7E
GuruxDLMSClientExample.exe -S COM11 -c 1 -a HighGMAC -P Gurux -t Verbose -s 21885 -v 0.0.43.1.0.255 -C AuthenticationEncryption
RX: 7E A0 18 21 00 02 54 FB 52 CC 24 E6 E7 00 C4 01 81 00 06 00 00 17 21 69 37 7E
Invocation counter: 5922 (0x1722)
TX: 7E A0 6E 00 02 54 FB 03 10 CC F2 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 41 42 43 44 45 46 47 48 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 70 38 9C CE 67 B3 59 AC 56 AB 55 2A 15 8A 45 22 BE 23 04 21 21 1F 30 00 00 17 22 DF 18 83 F2 BD 98 1F 04 DC 6C C8 10 67 FC C9 68 E6 18 50 D1 BB 22 E6 4E F8 B6 A7 55 7E
RX: 7E A0 72 03 00 02 54 FB 30 3C A4 E6 E7 00 61 61 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 45 41 41 07 00 2D 8A 35 88 02 07 80 89 07 60 85 74 05 08 02 05 AA 0A 80 08 22 67 21 F2 6F 05 BF 4F BE 23 04 21 28 1F 30 00 00 02 3D 9F EE 99 70 59 80 27 9F 5B D9 19 56 E5 83 98 DC 40 8F 17 7B 0B 1A C6 E6 40 37 E7 CC 7E
TX: 7E A0 3E 00 02 54 FB 03 32 13 82 E6 E6 00 CB 2D 30 00 00 17 23 4D D2 2B 28 F0 D2 69 E1 73 2D 75 25 A5 2A 66 1B 69 3D F1 E9 DE 8E FE 03 D5 CA 8B C2 08 93 74 7D 15 52 36 09 1A 59 1D 5B A6 FE 7E
What version from Visual Studio you are using? Are you sure that you haven't modified the source code? This is now run on five different PCs and all works without problems.
benyamin.chesh…
Hi, I downloaded the latest
Hi, I downloaded the latest version without changing the code, I ran it with Visual, so do you want me to give you access to AnYdesk?
Visual Studio 2019
benyamin.chesh…
In reply to Hi, I downloaded the latest by benyamin.chesh…
I try it with Arduino, there
I try it with Arduino, there is the same problem
benyamin.chesh…
7E A0 0A 00 02 54 FB 03 93 AC 8F 7E 7E A0 6E 00 02 54 FB 03 10 CC F2 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 05 08 02 05 20 00 00 00 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 F1 F8 FC 7E 3F 9F CF E7 F3 79 3C 9E CF 67 B3 D9 BE 23 04 21 21 1F 30 00 00 30 BC BD 91 B7 F7 01 45 7C 63 BE 13 67 F3 30 8B E1 62 E8 29 85 CB A3 7E A1 75 DF C9 7B 2B 7E 7E A0 0A 00 02 54 FB 03 53 A0 49 7E 7E A0 0A 00 02 54 FB 21 93 2F 9F 7E 7E A0 2E 00 02 54 FB 21 10 49 25 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E 7E A0 1C 00 02 54 FB 21 32 A8 C6 E6 E6 00 C0 01 81 00 01 00 00 2B 01 00 FF 02 00 78 42 7E 7E A0 0A 00 02 54 FB 21 53 23 59 7E 7E A0 0A 00 02 54 FB 03 93 AC 8F 7E 7E A0 6E 00 02 54 FB 03 10 CC F2 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 05 08 02 05 20 00 00 00 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 EC 76 BB DD 6E B7 DB 6D 36 9B 4D A6 D3 E9 F4 7A BE 23 04 21 21 1F 30 00 00 30 BE 07 CB D9 B8 F7 2D FB 3E 88 69 36 69 3A 87 72 EC 26 F5 41 D8 43 18 0B 55 D2 60 08 05 7E 7E A0 0A 00 02 54 FB 03 53 A0 49 7E 7E A0 0A 00 02 54 FB 21 93 2F 9F 7E 7E A0 2E 00 02 54 FB 21 10 49 25 E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 01 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF C5 E4 7E 7E A0 1C 00 02 54 FB 21 32 A8 C6 E6 E6 00 C0 01 81 00 01 00 00 2B 01 00 FF 02 00 78 42 7E 7E A0 0A 00 02 54 FB 21 53 23 59 7E 7E A0 0A 00 02 54 FB 03 93 AC 8F 7E 7E A0 6E 00 02 54 FB 03 10 CC F2 E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 05 08 02 05 20 00 00 00 8A 02 07 80 8B 07 60 85 74 05 08 02 05 AC 12 80 10 3D 1E 0F 87 43 A1 D0 68 34 1A 0D 86 43 A1 50 28 BE 23 04 21 21 1F 30 00 00 30 C0 B3 58 E0 EA E0 46 01 89 28 7F 26 03 32 4D 8C AF DA 4F 07 A1 FE 2E 69 48 C7 BA D2 0C 7E
13:52:29.650 -> SET settings.clientAddress : 16
13:52:29.650 -> SET settings.authentication : 0
13:52:29.650 -> SET settings.cipher.security : 0
13:52:29.915 -> GET settings.authentication : 0
13:52:30.008 -> **************Invocation Counter: 12499 , hex( 30d3 )
13:52:30.054 -> SET settings.clientAddress : 1
13:52:30.054 -> SET settings.authentication : 5
13:52:30.054 -> SET settings.cipher.security : 48
13:52:30.054 -> SET invocationCounter hex: 30d4 , int : 12500
13:52:30.426 -> com_initializeConnection failed 279
13:52:35.444 -> Start reading
13:52:35.444 -> GET settings.cipher.security : 48
13:52:35.444 -> GET settings.clientAddress : 1
13:52:35.444 -> GET settings.authentication : 5
13:52:35.491 -> GET settings.cipher.security : 48
13:52:35.491 -> SET settings.clientAddress : 16
13:52:35.491 -> SET settings.authentication : 0
13:52:35.491 -> SET settings.cipher.security : 0
13:52:35.726 -> GET settings.authentication : 0
13:52:35.819 -> **************Invocation Counter: 12501 , hex( 30d5 )
13:52:35.866 -> SET settings.clientAddress : 1
13:52:35.866 -> SET settings.authentication : 5
13:52:35.866 -> SET settings.cipher.security : 48
13:52:35.866 -> SET invocationCounter hex: 30d6 , int : 12502
13:52:36.234 -> com_initializeConnection failed 279
13:52:41.274 -> Start reading
13:52:41.274 -> GET settings.cipher.security : 48
13:52:41.274 -> GET settings.clientAddress : 1
13:52:41.274 -> GET settings.authentication : 5
13:52:41.274 -> SET settings.clientAddress : 16
13:52:41.274 -> SET settings.authentication : 0
13:52:41.274 -> SET settings.cipher.security : 0
13:52:41.533 -> GET settings.authentication : 0
13:52:41.627 -> **************Invocation Counter: 12503 , hex( 30d7 )
13:52:41.674 -> SET settings.clientAddress : 1
13:52:41.674 -> SET settings.authentication : 5
13:52:41.674 -> SET settings.cipher.security : 48
13:52:41.674 -> SET invocationCounter hex: 30d8 , int : 12504
13:52:42.052 -> com_initializeConnection failed 279
hen I try stm32 idecube to find this problem?
benyamin.chesh…
In reply to 7E A0 0A 00 02 54 FB 03 93 AC by benyamin.chesh…
I solved the problem with a
I solved the problem with a little change in the main libraries
thanks sir
Pagination
  • First page
  • Previous page
  • Page 1
  • Page 2
