  3. HeartBeat
HeartBeat
By ali_bahal , 8 December, 2021
hi, is there any standard for HeartBeat packet (I mean packet that, the meter will send to
head-end periodically to keep connection alive) ?
and do you implemented this in c# version ?
4 years 11 months ago
Call GXDLMSClient.GetKeepAlive-method. It will do this.
ali_bahal
thank you for response. I
thank you for response. I already had looked at your KeepAlive method. it's try to read an object.
public byte[] GetKeepAlive()
Settings.ResetBlockIndex();
if (UseLogicalNameReferencing)
return Read("0.0.40.0.0.255", ObjectType.AssociationLogicalName, 1)[0];
return Read(0xFA00, ObjectType.AssociationShortName, 1)[0];
but we have meter that sends its KeepAlive in this format:
0001000100000003011113
hence, I want to know is there standard for it?
There is a keepalive in HDLC standard, but there is no standard solution for WRAPPER.
Your meter is using the manufacturer-specific solution to keep the connection up. It's better to read something from the meter to keep the connection up than use a manufacturer-specific solution like this.
This manufacturer-specific solution might cause problems later if DLMS standard changes.
ali_bahal
sorry for troubling you, can
sorry for troubling you, can you comment keepalive in HDLC standard?
I couldn't find it. I'm really sorry for this request and thank thank you for complete answer.
All the metes doesn't support DLMS RR, but you can find more information from here:
https://en.wikipedia.org/wiki/High-Level_Data_Link_Control#Receive_Read…
ali_bahal
thank you.
thank you.
