  3. GXDLMS Python - Write Parameter To Object
GXDLMS Python - write parameter to object
By manuel , 23 November, 2021
unfortunately I have to ask you something again.
I would like to send a command to the meter.
For example 0.0.96.3.10.255 (Disconnect control) -> connect / reconnect circuit breaker (or any other possible command)
In .NET the command would be like this:
GXDLMSData prt = new GXDLMSData("OBIS_CODE");
prt.setDataType(pos, DataType.BITSTRING);
GXBitString dt = new GXBitString("010");
prt.setValue(dt);
device.reader.writeObject(prt, 2);
Could you please tell me how to replace this in Python? Is there a similar function or method?
def write(self, item, attributeIndex):
data = self.client.write(item, attributeIndex)
self.readDLMSPacket(data)
Best Regards,
Manuel
4 years 9 months ago
Hi Manuel,
Hi Manuel,
Check the client example:
Code looks like this:
prt = GXDLMSData("OBIS_CODE")
prt.setDataType(2, DataType.BITSTRING)
prt.value = GXBitString("010")
reader.write(prt, 2)
