  3. Landis+Gry E550 With 4G Modem
Landis+Gry E550 with 4G Modem
By XYTeoh , 14 October, 2021
Connecting Landis+Gry E550 to Gurux through 4G LTE network.
'Failed to receive reply from the device in given time' error occur
5 years 1 month ago
If I remember correctly Landis+Gyt E550 isn't using WRAPPER. Try to change it for the HDLC.
XYTeoh
5 years 1 month ago
Hi Kurumi,
Hi Kurumi,
I had test with HDLC, same error as "Failed to receive reply from the device in given time."
5 years 1 month ago
Check that you can access the meter and your port and address are correct. Change also your wait time higher. It might be that 5 seconds is not enough.
  • Suria
  • pespinosaferrer777
  • Gabice William
  • ngewe
  • jojon15
