  3. Device Error -
Device Error -
By aeeccims@tnebnet.org , 12 October, 2021
While opening/closing and for all actions the following error is displayed.
Not able to add device and can do nothing.
Guidance in this regard is appreciated.
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.UnauthorizedAccessException: Access to the path 'C:\ProgramData\Gurux\GXDLMSDirector\LastError.log' is denied.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.FileStream.Init(String path, FileMode mode, FileAccess access, Int32 rights, Boolean useRights, FileShare share, Int32 bufferSize, FileOptions options, SECURITY_ATTRIBUTES secAttrs, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.FileStream..ctor(String path, FileMode mode, FileAccess access, FileShare share, Int32 bufferSize, FileOptions options, String msgPath, Boolean bFromProxy, Boolean useLongPath, Boolean checkHost)
at System.IO.StreamWriter.CreateFile(String path, Boolean append, Boolean checkHost)
at System.IO.StreamWriter..ctor(String path, Boolean append, Encoding encoding, Int32 bufferSize, Boolean checkHost)
at System.IO.StreamWriter..ctor(String path, Boolean append)
at System.IO.File.CreateText(String path)
at GXDLMS.Common.Error.ShowError(IWin32Window owner, Exception Ex)
at GXDLMSDirector.MainForm.MainForm_Load(Object sender, EventArgs e)
at System.Windows.Forms.Form.OnLoad(EventArgs e)
at System.Windows.Forms.Form.OnCreateControl()
at System.Windows.Forms.Control.CreateControl(Boolean fIgnoreVisible)
at System.Windows.Forms.Control.CreateControl()
at System.Windows.Forms.Control.WmShowWindow(Message& m)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.Form.WmShowWindow(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4250.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
System
Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
GXDLMSDirector
Assembly Version: 8.2.2110.602
Win32 Version: 8.2.2110.0602
CodeBase: file:///C:/Users/IMS-04.10.2021/AppData/Local/Apps/2.0/Q07QBAZC.ORC/9CEXAA9O.XXO/gxdl..tion_fac3cc4fecb816b3_0008.0002_f89d72b6c3b780d2/GXDLMSDirector.exe
Gurux.Common
Assembly Version: 8.1.2109.2401
Win32 Version: 8.1.2109.2401
CodeBase: file:///C:/Users/IMS-04.10.2021/AppData/Local/Apps/2.0/Q07QBAZC.ORC/9CEXAA9O.XXO/gxdl..tion_fac3cc4fecb816b3_0008.0002_f89d72b6c3b780d2/Gurux.Common.DLL
Gurux.MQTT
CodeBase: file:///C:/Users/IMS-04.10.2021/AppData/Local/Apps/2.0/Q07QBAZC.ORC/9CEXAA9O.XXO/gxdl..tion_fac3cc4fecb816b3_0008.0002_f89d72b6c3b780d2/Gurux.MQTT.DLL
Win32 Version: 4.8.4270.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.8.3752.0 built by: NET48REL1
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
Gurux.DLMS.AMI.UI
Assembly Version: 8.1.2110.602
Win32 Version: 8.1.2110.602
CodeBase: file:///C:/Users/IMS-04.10.2021/AppData/Local/Apps/2.0/Q07QBAZC.ORC/9CEXAA9O.XXO/gxdl..tion_fac3cc4fecb816b3_0008.0002_f89d72b6c3b780d2/Gurux.DLMS.AMI.UI.DLL
Assembly Version: 9.0.2110.602
Win32 Version: 9.0.2110.602
CodeBase: file:///C:/Users/IMS-04.10.2021/AppData/Local/Apps/2.0/Q07QBAZC.ORC/9CEXAA9O.XXO/gxdl..tion_fac3cc4fecb816b3_0008.0002_f89d72b6c3b780d2/Gurux.DLMS.DLL
Gurux.DLMS.UI
Win32 Version: 9.0.2110.0602
CodeBase: file:///C:/Users/IMS-04.10.2021/AppData/Local/Apps/2.0/Q07QBAZC.ORC/9CEXAA9O.XXO/gxdl..tion_fac3cc4fecb816b3_0008.0002_f89d72b6c3b780d2/Gurux.DLMS.UI.DLL
System.Configuration
Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Core
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
System.Xml
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Deployment
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Deployment/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Deployment.dll
System.Numerics
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Numerics/v4.0_4.0.0.0__b77a5c561934e089/System.Numerics.dll
Gurux.Net
CodeBase: file:///C:/Users/IMS-04.10.2021/AppData/Local/Apps/2.0/Q07QBAZC.ORC/9CEXAA9O.XXO/gxdl..tion_fac3cc4fecb816b3_0008.0002_f89d72b6c3b780d2/Gurux.Net.DLL
System.Data
CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_64/System.Data/v4.0_4.0.0.0__b77a5c561934e089/System.Data.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
5 years 1 month ago
You don't have access rights for LastError.log. Can you remove LastError.log from C:\ProgramData\Gurux\GXDLMSDirector?
5 years 1 month ago
That error has gone on logging as Administrator
But
Now I couldn't get updated the list of Manufacture online
Any settings in windows 10 to be done.
Kindly clarify
And the Error.log is
System.Net.WebException: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.
at System.Net.Security.SslState.StartSendAuthResetSignal(ProtocolToken message, AsyncProtocolRequest asyncRequest, Exception exception)
at System.Net.Security.SslState.CheckCompletionBeforeNextReceive(ProtocolToken message, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslState.ProcessReceivedBlob(Byte[] buffer, Int32 count, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslState.StartReceiveBlob(Byte[] buffer, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslState.ForceAuthentication(Boolean receiveFirst, Byte[] buffer, AsyncProtocolRequest asyncRequest)
at System.Net.Security.SslState.ProcessAuthentication(LazyAsyncResult lazyResult)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Net.TlsStream.ProcessAuthentication(LazyAsyncResult result)
at System.Net.TlsStream.Write(Byte[] buffer, Int32 offset, Int32 size)
at System.Net.PooledStream.Write(Byte[] buffer, Int32 offset, Int32 size)
at System.Net.ConnectStream.WriteHeaders(Boolean async)
--- End of inner exception stack trace ---
at System.Net.WebClient.DownloadDataInternal(Uri address, WebRequest& request)
at System.Net.WebClient.DownloadData(Uri address)
at Gurux.DLMS.ManufacturerSettings.GXManufacturerCollection.UpdateManufactureSettings()
at GXDLMSDirector.MainForm.updateManufactureSettingsToolStripMenuItem_Click(Object sender, EventArgs e)
5 years 1 month ago
I haven't heard from this before. I believe that this is something to do with your PC security settings If you need to log as Administrator to start GXDLMSDirector.
5 years 1 month ago
Hi Mikko
Hi Mikko
Thank you for the response
I am logging as Administrator only
This is happening for Windows 10 machine and not for Windows 7
Guidance is needed to proceed further
5 years 1 month ago
There must be something on your Windows 10 because you are the first one who has this problem.
Can you try with another Windows 10?
If Windows 7 is working, you can also copy manufacture settings from:
5 years 1 month ago
Thanks for the reply.
But only two files are available in that directory.
Is it possible to get exact location of the manufacture list available.
Windows 10 machine is connected to meter network so I need in that machine.
5 years 1 month ago
I'm sorry. OBIS codes are in:
C:\ProgramData\Gurux\OBIS
5 years 1 month ago
Thank you
Copied the folder and now manufactures are listing.
