  3. Cosem_init2
cosem_init2
By ybou04 , 14 September, 2021
I'm trying to use the server example from your directory NordicSemi on a PC, under National Instruments CVI IDE, before use it on a STM32 target.
I have an running error in cosem_init2() function, in cosem.c file, line 416 :
memset(object, 0, size);
When called from addLogicalDeviceName(), size is 32 (sizeof DLMS_OBJECT_TYPE_DATA) but gxObject* object is 16.
I've just replace this init line by :
memset(object, 0, sizeof(object));
Yvan
5 years ago
gxObject* is 16 because you are using 16 bytes addressing. You need to remove it and replace it with the original code. Not your gxData is not fully initialized.
ybou04
5 years ago
Mikko,
Mikko,
Thanks for your answer, but I don't understand...
I've try to add __ptr32 before to cast in 32 bits the addressing :
gxObject* __ptr32 object,
But it's already in 32 bits addressing ! On CVI, I can use only 32 or 64 bits addressing, not 16.
Yvan
ybou04
5 years ago
Mikko,
Mikko,
gxObject* object, => 16 bytes
But size, which is int size = cosem_getObjectSize(type) ; where type = DLMS_OBJECT_TYPE_DATA
is : size = sizeof(gxData);
And gxData is :
typedef struct
* Base class where class is derived.
gxObject base;
dlmsVARIANT value;
} gxData;
Each : gxObject and dlmsVARIANT is 16, so size is really 32.
But the memset(object, 0, size);, where object is a gxObject* object, is not possible... except if you want to clear object and the next 16 bytes in the RAM.
Am I right ?
Yvan
5 years ago
Hi Yvan,
Hi Yvan,
Yes, the purpose is clear the content of the object. In this case content of the gxData.
I believe that you have missed the base object. The size of the base object is 16 bytes.
const unsigned char ln[6] = { 0, 0, 42, 0, 0, 255 };
gxData data;
cosem_init2(BASE(data), DLMS_OBJECT_TYPE_DATA, ln);
ybou04
5 years ago
I think we are not talking
I think we are not talking about the same thing ;)
gxData is 32 bytes and gxObject is 16 bytes
We can not use memset of 32 bytes on a 16 bytes buffer.
Some compiler will clear the gxObject and ... 16 other unknown RAM bytes.
My compiler don't want to and break on error.
5 years ago
OK. :-)
I'll ask to install National Instruments CVI and make test build with this code:
gxData data;
I'll let you know the results later today.
5 years ago
The size of gxData is 32 and this is current and everything works like expected, but what seems to be happening is that CVI is treating object as a pointer to an gxObject and not gxData. This is causing the error. There was an article that if gxObject* is replaced with void* it will solve this. This was tried, but this error is still there. I hope that there is a way to handle this bug id 461C7P34.
ybou04
5 years ago
Mikko,
Mikko,
Thanks for your answer.
I'm trying today to use the server on STM32 target (GCC compiler).
I'll be back with the behavior of this config !
Yvan
5 years ago
Hi Yvan,
Hi Yvan,
There are changes in the source code for the LabWindows/CVI. Get the latest version. There is also an client example for the LabWindows/CVI. You must define objects like this in LabWindows/CVI:
gxData data;
INIT_OBJECT(data, DLMS_OBJECT_TYPE_DATA, ln);
ybou04
5 years ago
Mikko,
Mikko,
Porting server stack (Nordic Semi directory) on STM32 successful !
No need to change anything in your code.
Now, I have to configure reals COSEM objects and add security...
Yvan
5 years ago
The source code should work with other compilers. LabWindows/CVI was interesting, but it should work now.
