  3. Ignore Time Part of GXDateTime
ignore time part of GXDateTime
By ali_bahal , 11 September, 2021
Hi, is there any way in c# version of library, I can create GXDateTime object that, it translate something like below ? I mean it put FF for time part of it?
<!-- 9/4/2021 *:*:* -->
<OctetString Value="07E50904FFFFFFFFFFFFFFFF" />
ali_bahal
5 years ago
I also looked at GxDate, but
I also looked at GxDate, but in converting to hex it translated into 5 bytes, that I think it's not correct for reading load profile.
case GXDate _:
buff.SetUInt8((byte) 5);
GXCommon.SetDate(settings, buff, value);
return;
case DateTime _:
buff.SetUInt8((byte) 12);
GXCommon.SetDateTime(settings, buff, value);
return;
ali_bahal
5 years ago
if I use skip property of
if I use skip property of GxDateTime,every thing work ok except Deviation that replaces with 80 00
instead of FF FF,
if ((gxDateTime.Skip & DateTimeSkips.Deviation) == DateTimeSkips.None)
short totalMinutes = (short) gxDateTime.Value.Offset.TotalMinutes;
if (settings != null && settings.UseUtc2NormalTime)
buff.SetInt16(totalMinutes);
else
buff.SetInt16(-totalMinutes);
else
buff.SetUInt16((ushort) 32768);
can we do anything about this ?
5 years ago
You can ignore the time part using Skip as you have done. DLMS standard defines the deviation is ignored using 0x8000 and not 0xFFFF. If your meter is using 0xFFFF, then it's wrong and not as DLMS standard defines. You need to ask the meter manufacturer to fix it.
ali_bahal
5 years ago
as you know sl7000 does not
as you know sl7000 does not implement dlms correctly. we have a lot of sl7000 meters. about 99 percent of them, does not have a problem. but only for 1% of them, I get access violated error on reading it's second load profile. I analyzed aimsPro packets and my packets, there was two differences in get request that I changed them after I get packet from your library.
but I stile get the same access violated error.
the differences was on 020412000809060000010000FF0F02120000090C that aims pro send simply
00090C for clock obis in get packet and time part that I already said above.
I should say that after changing packet contents, I checked them with translator and all of them was correct.
do you have any other idea ?
5 years ago
The best way is if you can update the firmware. Is that possible? Can you modify the source code and change 32768 to 0xFFFF? Or are you reading all the meters with the same application?
ali_bahal
5 years ago
we don't have access to new
we don't have access to new firmware. I also checked the version on meters and all meters are the same one.
also I changed 32768 to 0xFFFF and newly created packet is the same as aimsPro Packet.
but i checked snrm packet that we send and I see that :
<MaxInfoTX Value="117" />
<MaxInfoRX Value="114" />
I changed this values to 128. but then it send this values again. I don't hnow where this changes ? do you have any idea?
5 years ago
I believe that you are using C#. You can change those values in GXDLMSClient.HdlcSettings
ali_bahal
5 years ago
yes I changed them, but again
yes I changed them, but again it uses this values. if I don't set UseFrameSize , then everything is Ok.
but If I use UseFrameSize =true, then this values(117,114) apply instead of 128.
5 years ago
Leave UseFrameSize to false and use MaxInfoTX and MaxInfoRX properties.
UseFrameSize is for some special meters when communicating Over The Air.
