  3. GXDLMSServer On Python
GXDLMSServer on python
By germka , 21 June, 2021
Hi, I'm trying to make a DLMS server using your python libraries, since there is no example of a server in python, I used it in NET, but I ran into a problem that `media` (GXNet) sends data to listeners in the `_NetReceiveEventArgs` structure, but `GXDLMSServer` expects data in the other class, which has `isStreaming`, `setReply` and `connectionInfo` methods, is most similar to the `GXServerReply` class, but it does not have all the methods.
Please tell how to process incoming data from IGXMediaListener methods or give a short example of a server in Python.
5 years 1 month ago
Server-side code is not implemented for python at the moment. It's released in the autumn for the python.
germka
5 years 1 month ago
Thanks for the quick response
Thanks for the quick response!
R374
5 years ago
Dear Mikko,
Dear Mikko,
Consider that device could established a socket to a server and server could accept the device and register. (based on https://realpython.com/python-sockets/)
Is there any way that we could pass the socket to the "Gurux.DLMS.Client.Example.python" and continue the communication?
for instance:
- in server side:
sock = key.fileobj
conn, addr = sock.accept()
conn.setblocking(False)
data = xxxxxxxxxxxxxxxxxxxxxxx
events = selectors.EVENT_READ | selectors.EVENT_WRITE
self.sel.register(conn, events, data=data)
sampleclient.main(arg, conn)
- in Gurux.DLMS.Client.Example.python main.py
class sampleclient():
@classmethod
def main(cls, args, conn):
settings.media = conn
5 years ago
The server-side functionality and messages are totally different from than client-side, so this will not work.
You need to wait until the server side is implemented if you want to use it or then you can use other programming languages.
R374
5 years ago
I'll try to use current
I'll try to use current features of Gurux.DLMS.Python considering Gurux.DLMS.AMI project to implement the server.
I appreciate your efforts and wish the server could be implemented in near future so that we can upgrade ours.
5 years ago
Hi Ryan,
Hi Ryan,
Server-side for python and Delphi are released in August.
Profile picture for user phplego
phplego
4 years 11 months ago
Hi Kurumi,
Hi Kurumi,
Am I right that server-side python example will be commited here?
https://github.com/Gurux/Gurux.DLMS.Python
I'm also waiting for the same. I will monitor the repo then :)
R374
In reply to Hi Ryan, by Kurumi
Dear Mikko,
Dear Mikko,
Is there any chance that you would release server-side for python this month ?
Your guidance is so helpful.
Thank you.
Yes, that is the place where server-side example will come in any day now. :-)
  • JeffreyPal
  • DingfanXue
  • UrukTroge
  • Quarryboss
  • CorwXGlcWwyuiJawypxb
