  3. Iskraemeco MT880
Iskraemeco MT880
Profile picture for user hivesoft
By hivesoft , 15 June, 2021
Hi guys,
I was trying to connect to a Iskraemeco MT880 via Terminal but with no success.
I tried using the following configuration for GXDLMSClient:
Client = new GXDLMSClient
UseLogicalNameReferencing = true,
Standard = Standard.DLMS,
InterfaceType = InterfaceType.HDLC,
ClientAddress = 1,
ServerAddress = GXDLMSClient.GetServerAddressFromSerialNumber(76127083, 1),
Authentication = Authentication.Low,
Password = System.Text.Encoding.ASCII.GetBytes("12345678")
After succesful modem connnection, how SNRMRequest I have:
7E A0 0A 00 02 7E 27 03 93 FD F6 7E
But the meter doesn't give me any response.
I also tried with the GXDLMSDirector with many configuration options but even using the tool I don't get any response to SNRM.
Any ideas or suggestions other than throwing this meter away?
BR
Christian
5 years ago
Hi Christian,
Hi Christian,
I'm sorry for the slow reply. For some reason, I didn't notice your post.
Have you try GXDLMSDirector with the default Iskra settings?
Client address 64, Logical address 1 and Physical address 11.
We don't have MT-880 at the moment, so I can't test this.
hivesoft
5 years ago
this is the GXDLMSDirector log output for 0x64 0x1 0x11:
4:38:10.386 Info Open
Send SNRM request.
TX: 7E A0 08 02 23 C9 93 E4 43 7E
04:38:10.425 Sent 7E A0 08 02 23 C9 93 E4 43 7E
04:38:15.433 Sent 7E A0 08 02 23 C9 93 E4 43 7E
04:38:20.449 Sent 7E A0 08 02 23 C9 93 E4 43 7E
Send Disconnect request.
TX: 7E A0 08 02 23 C9 53 E8 85 7E
04:38:25.467 Sent 7E A0 08 02 23 C9 53 E8 85 7E
04:38:30.477 Sent 7E A0 08 02 23 C9 53 E8 85 7E
04:38:35.489 Sent 7E A0 08 02 23 C9 53 E8 85 7E
04:38:40.493 Info Closing
If you want some Italian telephone numbers to call, I have them. If you like to investigate the matter, I can also provide you with a remote connection on which you can do all your tests.
BR
Christian
5 years ago
Hi Christian,
Hi Christian,
We are a little bit busy before the summer holidays, so we can't check this at the moment.
Try to set the server Physical address to 4A (74) and logical address to 1.
Your server or client address is different than the meter expects.
hivesoft
5 years ago
I have applied the change but
I have applied the change but still receive no replies.
This is the new SNRM sended by director.
TX: 7E A0 08 02 95 C9 93 7F 1F 7E
The meter should be in standard configuration for the Italian market but there is no way to make it work.
BR
Christian
5 years ago
Do you have the meter that you can access with the serial port connection? If you have, you can get the server address for the terminal/modem connection if you can read the meter settings. The server address for modem connection might be different than for serial port connection. Is meter reply anything if you send /?!\r\n?
hivesoft
2 years 9 months ago
Hi Mikko, I try with putty…
I try with putty and I don't receive any response!
  • JeffreyPal
  • DingfanXue
  • UrukTroge
  • Quarryboss
  • CorwXGlcWwyuiJawypxb
