  3. Read a Set of Meters From a Unique RS-485 Communication Bus
Read a set of meters from a unique RS-485 communication bus
By Diego2911 , 15 April, 2021
I'm working on a smart metering project. I want to be able to read one specific meter from a set of meters, all of this meters are conected by RS-485 to a unique RS-485 bus communication. I'm able to connect to one meter alone by RS-485 and read it, but I don't know how identify a specific meter from a set of them all of them connected to a unique RS-485 bus and read it. What process or what object can I use for this purpose?? The net is something like the picture. Thanks.
5 years 3 months ago
This depends on the meter. Some metes are using serial numbers as device addresses. Some meters are expecting that one of the meters is working as a master and other meters are added to the SAP table of the master meter.
Diego2911
Thanks for the response. In
Thanks for the response. In that case, how can I set the serial number as device address with gurux libraries for python ??
Best regards.
You can try with client example. Add -n parameter. Like this:
-n METER_SERIAL_NUMER.
Function is GXDLMSClient.getServerAddressFromSerialNumber
Note! Some meters might use a different formula to count the server address from the serial number.
  • Vital479
  • HealthPro16
  • Brandondiz
  • JeffreyPal
  • DingfanXue
