  3. Change Type Failed. Not Enought Data
Change type failed. Not enought data
By salman1538 , 8 April, 2021
Hi All, I try to read date and time from Meter.
1.1.0.9.1.255:2 -> I get the time
1.1.0.9.2.255:2 -> I get the message change type failed. Not enought data
I am using Gurux DLMS Client Example in Python.
Please guide to resolve the error.
5 years 3 months ago
Can you add a trace from the bytes so I can check it?
salman1538
Hi, thanks for reply. Below
Hi, thanks for reply. Below is the trace from log file -t Verbose
[Trace removed]
I was able to repeat this. I create an issue from this and a new version is released later today.
https://www.gurux.fi/node/18287
salman1538
Thanks for quick support. Got the new version 1.0.103 - Will update after test.
salman1538
I test and it works fine. Thank you.
  • agize
  • BioTips
  • Vital479
  • HealthPro16
  • Brandondiz
