  3. How Will I Read Data From All Logical Devices of DCU(Data Concentrator Unit) Sequentially Without Breaking Socket Connection?
How will I read data from all logical devices of DCU(Data Concentrator Unit) sequentially without breaking socket connection?
By pradson , 7 April, 2021
How will I read block-profile data from logical devices of DCU(Data Concentrator Unit) one by one without breaking socket connection?
The scenario is that I have a DCU and 40 meters. All 40 meters are connected with DCU. The DCU has an IP and a port for communication. The DCU is able to read data from all 40 meters and stores data according to its logical device.
I want to retrieve data from all logical devices of DCU using my client application with breaking only logical device channel but without breaking socket connection.
How could I achieve same? Kindly suggest.
Thanks & Regards,
Pradson
5 years 3 months ago
This depends on the DCU. Usually, you will keep the TCP/IP connection and send the release. After you have sent the release you will make the connection to the next meter. As I told, this depends on the DCU and some DCUs require that a new TCP/IP connection is made before the next meter can be read.
pradson
5 years 1 month ago
HI Mikko,
HI Mikko,
Could you share a sample example for the same. Like below steps-
1- Client connects to DCU using IP and port.
2- connect and Read logical meter-1 and release it.
4- connect and read logical meter-2 and release it.
so on
5- close() the socket connection.
Pradson
5 years 1 month ago
Hi ,
Hi ,
We don't have an example like that, but I hope this link helps you.
https://gurux.fi/Gurux.DLMS.DynamicIP
  • agize
  • BioTips
  • Vital479
  • HealthPro16
  • Brandondiz
