  3. Not Able To Install Gurux In My Laptop
not able to install gurux in my laptop
By gamimilan6 , 6 April, 2021
Dear Sir,
I am not able to install gurux in my laptop.
Please guide me.
I have attched my laptop configuration and also attaching notepad file of error showing details.
Thanks and regards
Milan
gamimilan6
5 years 3 months ago
Also added system
Also added system configuration
Install dotnet to your computer.
https://docs.microsoft.com/en-us/dotnet/core/install/windows?tabs=net50
Then install GXDLMSDirector
https://www.gurux.fi/Downloads/gxdlmsdirector46/GXDLMSDirector.applicat…
gamimilan6
Dear Miko,
Dear Miko,
Still I am not able to install guruX in my laptop. As you told I install latest .Net frame work but still the result is same.
So please suggest more information.
Please help me ASAP.
Thanks and regards
Milan
Hi Milan,
Hi Milan,
Can you run this in the command prompt?
dotnet --version
The result should be something like this:
5.0.201
gamimilan6
Dear Miko,
Dear Miko,
As per your suggestion we tried by command prompt and I have shared a screenshot of the same.
Can you suggest me the any other method to check.
Thanks and regard
Milan
Hi Milan,
Hi Milan,
Please, don't add pics. They are hard to read. Can you add the original error message as text?
gamimilan6
Dear Mikko,
Dear Mikko,
Please find error message.
PLATFORM VERSION INFO
Windows : 10.0.18363.0 (Win32NT)
Common Language Runtime : 4.0.30319.42000
System.Deployment.dll : 4.8.4270.0 built by: NET48REL1LAST_C
clr.dll : 4.8.4300.0 built by: NET48REL1LAST_C
dfdll.dll : 4.8.4270.0 built by: NET48REL1LAST_C
dfshim.dll : 10.0.18362.1 (WinBuild.160101.0800)
SOURCES
Deployment url : file:///C:/Users/user/Downloads/GXDLMSDirector%20(10).application
ERROR SUMMARY
Below is a summary of the errors, details of these errors are listed later in the log.
* Activation of C:\Users\user\Downloads\GXDLMSDirector (10).application resulted in exception. Following failure messages were detected:
+ The referenced assembly is not installed on your system. (Exception from HRESULT: 0x800736B3)
COMPONENT STORE TRANSACTION FAILURE SUMMARY
No transaction error was detected.
WARNINGS
There were no warnings during this operation.
OPERATION PROGRESS STATUS
* [09-04-2021 11:16:00] : Activation of C:\Users\user\Downloads\GXDLMSDirector (10).application has started.
ERROR DETAILS
Following errors were detected during this operation.
* [09-04-2021 11:16:09] System.Runtime.InteropServices.COMException
- The referenced assembly is not installed on your system. (Exception from HRESULT: 0x800736B3)
- Source: System.Deployment
- Stack trace:
at System.Deployment.Internal.Isolation.IStore.GetAssemblyInformation(UInt32 Flags, IDefinitionIdentity DefinitionIdentity, Guid& riid)
at System.Deployment.Internal.Isolation.Store.GetAssemblyManifest(UInt32 Flags, IDefinitionIdentity DefinitionIdentity)
at System.Deployment.Application.ComponentStore.GetAssemblyManifestFromStore(DefinitionIdentity asmId)
at System.Deployment.Application.ComponentStore.GetAssemblyManifestWithRetry(DefinitionIdentity asmId, TimeSpan retryInterval, Int32 maxRetryCount)
at System.Deployment.Application.ComponentStore.GetSubscriptionStateInternal(DefinitionIdentity subId)
at System.Deployment.Application.SubscriptionStore.GetSubscriptionStateInternal(SubscriptionState subState)
at System.Deployment.Application.SubscriptionStore.CheckAndReferenceApplication(SubscriptionState subState, DefinitionAppId appId, Int64 transactionId)
at System.Deployment.Application.DownloadManager.DownloadDeploymentManifestDirectBypass(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, SubscriptionState& subState, IDownloadNotification notification, DownloadOptions options, ServerInformation& serverInformation)
at System.Deployment.Application.DownloadManager.DownloadDeploymentManifestBypass(SubscriptionStore subStore, Uri& sourceUri, TempFile& tempFile, SubscriptionState& subState, IDownloadNotification notification, DownloadOptions options)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl, Uri& deploymentUri)
at System.Deployment.Application.ApplicationActivator.PerformDeploymentActivationWithRetry(Uri activationUri, Boolean isShortcut, String textualSubId, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String& errorPageUrl)
--- End of stack trace from previous location where exception was thrown ---
at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw()
at System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker(Object state)
COMPONENT STORE TRANSACTION DETAILS
No transaction information is available.
Thanks and Regards
Milan
Hi Mialn,
Hi Mialn,
This error is seen once. The PC was corrupted. Try to run this:
SFC /SCANNOW
  • agize
  • BioTips
  • Vital479
  • HealthPro16
  • Brandondiz
