  3. How To Read Single OBIS Using Python
How to read single OBIS using python
By nhzq , 25 January, 2021
I'm trying to read single OBIS instead of read the whole association view. In GXDLMSReader.py, I did modify the codes like this:
def readAll(self, outputFile):
try:
read = False
self.initializeConnection()
#OBIS Clock
d = GXDLMSData("0.0.1.0.0.255")
self.read(d, 2)
self.getReadOut()
self.getProfileGenerics()
if outputFile:
self.client.objects.save(outputFile)
except (KeyboardInterrupt, SystemExit):
self.media = None
raise
finally:
self.close()
The response return is like this:
gurux_dlms version: 1.0.95
gurux_net version: 1.0.17
gurux_serial version: 1.0.15
ClientAddress: 0x14
ServerAddress: 0xff
Standard: Standard.DLMS
TX: 13:26:40 7E A0 08 02 FF 29 93 D1 80 7E
RX: 13:26:43 7E A0 21 29 02 FF 73 CC 61 81 80 14 05 02 01 20 06 02 01 20 07 04 00 00 00 01 08 04 00 00 00 01 0B C9 7E
TX: 13:26:43 7E A0 45 02 FF 29 10 14 8B E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 33 33 33 33 33 33 33 33 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF D5 AF 7E
RX: 13:26:46 7E A0 38 29 02 FF 30 77 F4 E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 01 20 00 07 76 D3 7E
TX: 13:26:46 7E A0 1A 02 FF 29 32 9A 96 E6 E6 00 C0 01 C1 00 01 00 00 01 00 00 FF 02 00 57 28 7E
RX: 13:26:48 7E A0 12 29 02 FF 52 5A 98 E6 E7 00 C4 01 C1 01 04 CC F6 7E
TX: 13:26:48 7E A0 08 02 FF 29 53 DD 46 7E
RX: 13:26:50 7E A0 08 29 02 FF 73 39 50 7E
Access Error : Device reports a undefined object.
Can you please help me what could be the cause of this error and how fix it?
nhzq
5 years 7 months ago
I think I found the answer. I tried using GXDLMSClock("0.0.1.0.0.255") instead of GXDLMSData("0.0.1.0.0.255") and it did work.
I'm glad that this is solved. Amount of error codes is limited in DLMS and object type must be correct or meter returns an error. Data type just also be correct if you try to write something to the meter.
DomenP
3 years 3 months ago
Hello, I tried using your…
Hello, I tried using your method, I imported GXDLMSClock, changed the code, but still I get an error:
I wanted to read the voltage with OBIS : 1.0.32.7.0.255. I'm using Low Authentication with Password and I can read every parameter through the GXDLMS Director. Do you think the reason is that I would need High Authentication?
EDIT: I found the reason for this error, I was trying to read a register with GXDLMSClock and GXDLMSData, but you have to use GXDLMSRegister (for a register of course). Hope it helps anyone, if they stumble on the same problem.
Hi, Please, create a new…
Please, create a new topic if you have a new question. The reason for your error is that the OBIS code that you try to read doesn't exist in the association view.
DomenP
Hello, I solved the issue as…
Hello, I solved the issue as I stated in the Edit. And yes while that OBIS code isn't in the Associaton view, I can read it normally.
With regards
Reese
3 years 1 month ago
Hi @DomenP, did you get read…
Hi @DomenP, did you get read obis code successfully ?, did you do that using the getAssociationView or it can be done without reading getAssociationView?
i'm trying to read justvoltage value (Obis Code: 1.1.32.7.0.255) but it only works when I use getAssociationView, otherwise, it's just return Index: 2 Value: None
