  3. Data Send Failed - Python_Raspberry PI
Data send failed - Python_Raspberry PI
By Krzysztof S. , 23 December, 2020
Hello!
I have a problem with Gurux.DLMS for python on Raspberry PI 4.
I'd like to read data from meter Landis Gyr E650 using optical interface with USB. I connected USB to raspberry and I've done step by step your instructions for python Gurux.DLMS.
I check a connection meter Landis Gyr E650 and optical interface with USB on GXDLMSDriector (Windows10) and It works. I can read data.
My output of console is below.
python main.py -S /dev/ttyUSB0
gurux_dlms version: 1.0.95
gurux_net version: 1.0.17
gurux_serial version: 1.0.15
ClientAddress: 0x10
Standard: Standard.DLMS
RX: 10:12:44
File "main.py", line 105, in main
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 508, in readAll
self.initializeConnection()
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 305, in initializeConnection
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 117, in readDLMSPacket
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 167, in readDLMSPacket2
raise e
TimeoutException: Failed to receive reply from the device in given time.
Please help with the problem :)
5 years 7 months ago
If you are using an optical probe you need to start communication using IEC 62056-21 Mode E. Try to add -i parameter.
Krzysztof S.
Thank you for your answer. I've added -i parameter but it doesnt work. I attach photo with a screen of console.
Krzysztof
Krzysztof S.
My second photo is without -i
My second photo is without -i parameter.
Maybe it will help to understand the problem.
Please help :)
Please, add plain text it's easier to read than pics. Your meter didn't reply anything. Check that your serial port is correct. Remove optical probe and check that ttyUSB0 is not available anymore.
Krzysztof S.
I've already checked serial port as you said and everything is correct. I know that the problem is with connection, but when I use GXDLMSDriector on Windows 10 I can read data.
Do you have any ideas what's next I can do?
Ok, sorry for photos. Next time I will send plain text. Unless you need text from above photos.
Krzysztof
Try to run python code in Windows and let me know what happened.
Can you share the information on what optical probe you are using? I did try with Kamstrup and EMH optical probes and I was able to read the meters without problems from the Pi.
Krzysztof S.
I tried to run python code on Windows console but my serial port wasnt visible.
Available serial ports:
Using GXDLMSDriector application on Windows I can choose serial port and get data.
The optical probe is from a polish company Numeron - https://www.numeron.pl/urzadzenia/glowica-optyczna/
The company doesnt have an english language version of website.
I tried to run python code on PI several times and I got an answer from meter. I will paste it below.
python3 main.py -S /dev/ttyUSB3 -t Verbose -r sn
ClientAddress: 0x10
TX: 15:30:31 7E A0 07 03 21 93 0F 01 7E
RX: 15:30:31 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 3E 07 04 00 00 00 01 08 04 00 00 00 01 07 22 7E
TX: 15:30:31 7E A0 2B 03 21 10 FB AF E6 E6 00 60 1D A1 09 06 07 60 85 74 05 08 01 02 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 1C 03 20 FF FF 80 AB 7E
RX: 15:30:31 7E A0 2D 21 03 30 63 63 E6 E7 00 61 1F A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 01 A3 05 A1 03 02 01 01 BE 06 04 04 0E 01 06 00 7E 79 7E
TX: 15:30:31 7E A0 07 03 21 53 03 C7 7E
Connection is permanently rejected
No reason is given.
Krzysztof
Krzysztof S.
I tried to run python code on another computer. The serial port was found and connected, but the problem is still the same as on PI.
Maybe there is a problem with the meter. I only connected the meter to a power supply and used my optical probe.
Krzysztof
Krzysztof S.
Below I show logs from DXDLMSDirector. Maybe It will help with the problem.
GXDLMSDirector 8.2.2012.1701
Log created 21:05:05
System.ArgumentException: Element PortName nie może być pusty.
Nazwa parametru: PortName
w System.IO.Ports.SerialPort.set_PortName(String value)
w Gurux.Serial.GXSerial.set_PortName(String value)
w GXDLMSDirector.DevicePropertiesForm.AdvancedBtn_Click(Object sender, EventArgs e)
08:15:19 Initializing serial connection.
08:15:21 IEC Sending:/?!<CR><LF>
08:15:22 HDLC received: /LGZ5\2ZMD4104157.B32<CR><LF>
08:15:22 BaudRate is : 9600
08:15:22 Moving to mode E.
06 32 35 32 0D 0A
08:15:25 Send SNRM request.
08:15:25
08:15:25 Parsing UA reply succeeded.
08:15:25 Send AARQ request.
08:15:25
7E A0 37 21 03 30 6C 7C E6 E7 00 61 28 A1 09 06 07 60 85 74 05 08 01 02 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 0F 04 0D 08 00 06 5F 1F 04 00 18 02 20 09 60 FA 00 0A A8 7E
08:15:25 Parsing AARE reply succeeded.
08:15:29 Read object type Register index: 1
7E A0 11 03 21 32 B7 3D E6 E6 00 05 01 02 04 48 04 3A 7E
08:15:29
7E A0 17 21 03 52 2B B3 E6 E7 00 0C 01 00 09 06 00 00 61 61 00 FF 7A 26 7E
08:15:29 Read object type Register index: 3
7E A0 11 03 21 54 87 3B E6 E6 00 05 01 02 04 58 85 2A 7E
08:15:29
7E A0 15 21 03 74 69 CE E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
08:15:29 Read object type Register index: 2
7E A0 11 03 21 76 97 39 E6 E6 00 05 01 02 04 50 CD A6 7E
08:15:29
7E A0 15 21 03 96 75 0A E6 E7 00 0C 01 00 09 04 02 00 00 00 40 91 7E
7E A0 11 03 21 98 E7 37 E6 E6 00 05 01 02 48 A0 84 BE 7E
08:15:29
7E A0 17 21 03 B8 7F FB E6 E7 00 0C 01 00 09 06 00 00 60 F0 0C FF C4 40 7E
7E A0 11 03 21 BA F7 35 E6 E6 00 05 01 02 48 B0 05 AE 7E
08:15:29
7E A0 15 21 03 DA 1D 82 E6 E7 00 0C 01 00 02 02 0F 00 16 FF 4B C2 7E
7E A0 11 03 21 DC C7 33 E6 E6 00 05 01 02 48 A8 CC 32 7E
08:15:29
7E A0 11 21 03 FC C5 B4 E6 E7 00 0C 01 00 11 4F 9B DE 7E
08:15:29 Read object type Clock index: 1
7E A0 11 03 21 FE D7 31 E6 E6 00 05 01 02 2B C0 BF 92 7E
08:15:29
7E A0 17 21 03 1E 43 3B E6 E7 00 0C 01 00 09 06 00 00 01 00 00 FF 0F E0 7E
08:15:29 Read object type Clock index: 2
7E A0 11 03 21 10 A7 3F E6 E6 00 05 01 02 2B C8 F7 1E 7E
08:15:30
7E A0 1D 21 03 30 91 2F E6 E7 00 0C 01 00 09 0C 07 D0 01 07 05 17 15 39 FF 80 00 01 D3 E2 7E
...cd
Krzysztof
You need to give -i parameter. I believe it's the reason.
Krzysztof S.
I've added -i parameter but It doesn't work. Please for advice.
Below is text from PI console after this operation.
python3 main.py -S /dev/ttyUSB7 -i -t Verbose
ClientAddress: 0x10
TX: 12:38:49 /?!
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 301, in initializeConnection
self.initializeOpticalHead()
File "/home/pi/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 198, in initializeOpticalHead
raise Exception("Failed to received reply from the media.")
Exception: Failed to received reply from the media.
Krzysztof
Krzysztof S.
I check my serial port communication on Windows using an application for COM monitoring. A screen of the operation is below.
I sent /?! and got the answer. I think something is wrong with the python library if I'd like to use an optical probe.
Maybe you have some advice?
Thanks for help.
Krzysztof
Can you see if the Pi app is sending <CR><LF> after "/?!"? The meter should reply and now there is nothing.
Krzysztof S.
I've checked it during runing python code on Windows. The app sent <CR><LF> after "/?!", but there was no reply from meter.
But Biatel COM Monitor which I sent the image above was able to communicate with meter and get data.
Any ideas what's next?
Krzysztof
5 years 6 months ago
Try with this:
python3 main.py -S /dev/ttyUSB7:300:7Even1 -i -t Verbose
The client example is also modified so 300:7Even1 is the default serial port setting when IEC Mode E is used.
Biatel application is using IEC 62056-21 readout mode and not DLMS.
Krzysztof S.
I've already realized your idea, but It doesn't work :(
Krzysztof
And you are running this?
You must use -i parameter!
Are you getting any reply from the meter?
Krzysztof S.
Yes, I've runned your instruction with -i parameter, but It doesn't work.
I don't have more time to get know the library, so I've writed my own script with pyserial library to read data from the meter and It works.
I've used your instruction from website http://www.gurux.fi/DLMSIntro how to communicate with the meter and everything is fine. In my project I only need data from registers of the meter.
My python script works, so It is the end :)
Thank for your time and help Mikko.
Krzysztof
HI,
HI,
I'm glad if IEC 62056-21 readout fills your needs and you don't need DLMS.
It's much easier in this way.
Toni
Dear Krzysztof,
  • RobertEncum
  • BrandonKar
  • Danielfaw
  • TcmLCyrzROrdrv…
  • Anas Zaatreh
