  3. Profile Generic Row Dates Are Affected By Local PCs DST Settings What May Result In Incorrect Dates
Profile generic row dates are affected by local PCs DST settings what may result in incorrect dates
By rdk1 , 25 October, 2020
Meter has no DST adjustment and always uses UTC+2 timezone. When I read historical data, only the first record has the correct time offset, other rows are affected by local PCs settings.
10/23/2020 11:00:00 PM +02:00 //meter timezone, correct
10/24/2020 1:00:00 AM +03:00 //local
10/24/2020 2:00:00 AM +03:00
10/24/2020 3:00:00 AM +03:00
10/24/2020 4:00:00 AM +03:00
If I read the same data on a PC with no DST adjustment I will get the correct data:
Meter time (UTC): 2020-10-25 04:38:13
Date (UTC) / Value
10/24/2020 11:00:00 PM > 5012072.8 //ok
10/25/2020 12:00:00 AM > 4910510.5 /ok
10/25/2020 1:00:00 AM > 4992696.8
10/25/2020 2:00:00 AM > 4980169.9
10/25/2020 3:00:00 AM > 5194268.9
10/25/2020 4:00:00 AM > 5313574.7 <- all good
But if I read the same rows on a PC with DST adjustment:
Meter time (UTC): 2020-10-25 04:37:14
Date (UTC) / Value
10/25/2020 1:00:00 AM > 4910510.5 //1-hour ahead
10/25/2020 2:00:00 AM > 4992696.8
10/25/2020 3:00:00 AM > 4980169.9
10/25/2020 4:00:00 AM > 5194268.9
10/25/2020 5:00:00 AM > 5313574.7 <- 1-hour ahead, incorrect, meter time is only 4:37
Is there a reason why only the first row is in the meters timezone and other rows use local dates?
https://github.com/Gurux/Gurux.DLMS.Net/blob/b01e62ecf2f1d6940df6ba2997…
Shouldn't the date be always in the same timezone as the meter has?
rdk1
5 years 9 months ago
Update on this:
Update on this:
Simply replacing local DateTime (dt.Value.LocalDateTime) with the meters DateTimeOffset (dt.Value) will fix the issue and let us have the original date and correctly convert it to UTC or local time if required.
Meter | UTC | Local
10/25/2020 12:00:00 AM +02:00 | 2020-10-24 22:00:00 | 2020-10-25 01:00:00 / "+3"
10/25/2020 1:00:00 AM +02:00 | 2020-10-24 23:00:00 | 2020-10-25 02:00:00 / "+3"
10/25/2020 2:00:00 AM +02:00 | 2020-10-25 00:00:00 | 2020-10-25 03:00:00 / "+3"
10/25/2020 3:00:00 AM +02:00 | 2020-10-25 01:00:00 | 2020-10-25 03:00:00 / "+2"
10/25/2020 4:00:00 AM +02:00 | 2020-10-25 02:00:00 | 2020-10-25 04:00:00 / "+2"
Is date-time field zero after the first row in your meter? Is this causing the problem?
rdk1
Yes, only the first row
Yes, only the first row contains the date (meter is ISKRA MT880)
Row [0] column [0]: System.Byte[]
Row [1] column [0]: null
Row [2] column [0]: null
Row [3] column [0]: null
Row [4] column [0]: null
It is not causing problems as you handle such cases by increasing previous date by profile capture period.
But, for some reason, you don't keep the last date in meter timezone (only first date), but convert it to local time (lastDate = dt.Value.LocalDateTime;)
10/24/2020 1:00:00 AM +03:00 // converted to local
This makes it dependent on local PCs DST and when DST change happens local time is shifted back/forward and correlation with the original time is lost.
It would be more explicit to have all dates in meter timezone and convert them to UTC/local later when you need to display it to the user.
Thank you for this information. Now I know the reason and I'll need to think about this a little bit. We'll talk about this and how to solve this.
There are only a few meter manufacturers that are saving bytes and ignore the date-time field after the first row. This makes testing a little more easier.
5 years 8 months ago
This is fixed to a new version from GXDLMSDirector. Let me know if you have any problems.
rdk1
Thank you for a quick update, but it seems that dates are still inconsistent as original timezone is lost.
1. https://github.com/Gurux/Gurux.DLMS.Net/blob/master/Development/Objects…
lastDate = dt.Value.DateTime;
you keep the date, but timezone/offset information is lost here
2. https://github.com/Gurux/Gurux.DLMS.Net/blob/master/Development/Objects…
GXDateTime(DateTime value) will call GXDateTime(DateTime value, TimeZoneInfo timeZone) with no timezone info and will calculate offset from local time TimeZoneInfo.Local.GetUtcOffset(value)
This will produce the following results:
10/24/2020 4:30:00 AM +02:00 //1st record
10/24/2020 4:45:00 AM +03:00 //2nd record has meter time, but uses local timezone
And DST:
10/25/2020 2:30:00 AM +03:00 //UTC 11:30:00 PM
10/25/2020 2:45:00 AM +03:00 //UTC 11:45:00 PM
10/25/2020 3:00:00 AM +02:00 //UTC 1:00:00 AM <-wrong
10/25/2020 3:15:00 AM +02:00 //UTC 1:15:00 AM
This can be solved by using the same DateTimeOffset to keep the last date and preserve the original meters timezone:
GXDateTime dt = (GXDateTime)row[pos];
lastDate = dt.Value;
and dates can be correctly converted to UTC/Local timezone
10/25/2020 1:45:00 AM +02:00 | UTC 2020-10-24 23:45:00
10/25/2020 2:00:00 AM +02:00 | UTC 2020-10-25 00:00:00
10/25/2020 2:15:00 AM +02:00 | UTC 2020-10-25 00:15:00
10/25/2020 2:30:00 AM +02:00 | UTC 2020-10-25 00:30:00
10/25/2020 2:45:00 AM +02:00 | UTC 2020-10-25 00:45:00
10/25/2020 3:00:00 AM +02:00 | UTC 2020-10-25 01:00:00
10/25/2020 3:15:00 AM +02:00 | UTC 2020-10-25 01:15:00
So, you are saying that this will work for you if lastDate is changed to DateTimeOffset? Like this
DateTimeOffset lastDate = DateTime.MinValue;
What time zone you are using in your PC and the meter? We'll check this also with those time zones.
rdk1
Yes, if you keep the date in DateTimeOffset and use dt.Value as lastValue the correct timezone offset will be preserved.
In fact, it all depends on how you initialize GXDateTime - passing DateTimeOffset will use the date and offset from it, but passing DateTime with no offset information will use local PCs default timezone and is dependent on PCs DST settings
10/24/2020 1:00:00 AM +03:00 //GXDateTime from DateTime with no offset, uses local PC timezone
This is changed and a new version is released. A new version from GXDLMSDirector is released later today.
  • EdwinObjef
  • LutzG
  • Ralf Schmitz
  • prosper.abanga
  • moGiaco
