  3. How To Set Load Surveys Registers
How to set Load Surveys registers
By hhkx , 17 August, 2020
I am trying to set profile generic registers for load survey to a meter. What I mean is, I want, for example, 0.0.21.0.1.255 register includes only 1.0.1.8.0.255, 1.0.2.8.0.255, 1.0.5.8.0.255, 1.0.1.8.1.255, 1.0.2.8.1.255, 1.0.5.8.1.255. etc.
Basically, I want to change registers.
How can I achieve this with gurux.net code?
6 years 3 months ago
You need to connect using High authentication. Then you can write capture objects. I believe that best way to start is if you download GXDLMSDirector and change capture objects with that.
hhkx
Hi Kurumi,
Thanks for your reply. I want it to be done programmatically so I have to use .net client and nuget library.
But as you said, I will try first with GXDLMSDirector. Is there any information where and how I can do it with .net library?
hhkx
On the GXDLMSDirector
On the GXDLMSDirector settings, I've switched from low authentication to high and tried to connect with the same password. But it throws the attached exception.
There are several different settings. If one of them is wrong, the meter doesn't reply.
Try to connect first without authentication. If you change authentication you need also change the client address.
hhkx
I must say this you're doing a very great job by supporting us, beyond gurux itself. So many thanks for your support.
When I select meter brand, client address becomes 64 but I cannot connect with this setting.
I can connect it successfully with low authentication setting, on client address 1.
Changing it to High Authentication, client address changes to 64 again. Neither 64 nor 1 works.
Do you think there is a possibility that high authentication mode is disabled on the meter? Or the password is different?
And do I need to try every client address from 1 to 64 for high authentication?
Try to change 64 to 0x40. I believe that the client address is wrong and that is the reason.
hhkx
Client Address is digit only area in GXDLMSDirector. So I can't type in 0x40.
Add 40. GXDLMSDirector uses hex values.
hhkx
I have been trying all the client addresses since yesterday, but it doesn't get connected with high authentication.
There is one thing.
It always drops to timeout unless the client address is 1. If it is 1, it gives the below error.
"Connection is permanently rejected. Authentication mechanism name not recognised."
Does it mean something other than incorrect client address?
I can set registers via the meter's own software (sep2 meterview). However, when I try it with low authentication, Gurux gives me an error saying "Access error:other reason."
By the way, I can set the clock with Gurux.
If client address is 1, you need to use the authentication level. Change authentication from None to Low or High and set password.
You can set time using low authentication, but if you want to set something else you need to use High authentication level. This error is coming because you try to set value and your authentication level is wrong.
If you make a connection with Meterview using High authentication and add trace (the first line is enough) I can check the correct client address for you.
hhkx
Thanks in advance.
Sep2MeterView output:
00 01 00 01 00 01 00 38 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 XX XX XX XX XX XX XX XX BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 7E 1F FF FF
Gurux output:
00 01 00 01 00 01 00 38 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 XX XX XX XX XX XX XX XX BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF
There are only two differences at the end, sep2mv is sending 7E 1F while gurux's is 1E 1D.
PS: XX contains the meter password
Differences are because the conformance bits are different, but it should not affect in any away.
You should be able to make connection using Low authentication with those settings.
Can you connect using High authentication with Meterview?
hhkx
On Meterview, there is no authentication type like low, high etc. There are only password, md-5, sha1 and gmac types (please see the attached image). We're using password option and I can change registers (capture objects).
On GXDLMSDirector, I can make Low authentication connection with those settings, but I cannot capture objects.
hhkx
and this is the gurux
and this is the gurux settings.
You need to connect using Meterview. MD5, SHA-1 and GMAC are all High authentication types.
Connect with that usually use and add trace so I can check correct settings for your meter.
hhkx
I don't have Meterview.
I have Sep2 Meterview, if you mean this, below is trace log:
Log name: ALC_ME382_GPRS
Events: 6, Bytes: 209
Requests: 3 (50.00%), Requests bytes: 106 (50.72%)
Answers: 3 (50.00%), Answer bytes: 103 (49.28%)
1. Request: 13:55:48.295
Size 64 B (30.62%)
00 01 00 01 00 01 00 38 60 36 A1 09 06 07 60 85 .......8`6....`.
74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 t..........`.t..
02 01 AC 0A 80 08 XX XX XX XX XX XX XX XX BE 10 ......XXXXXXXX..
04 0E 01 00 00 00 06 5F 1F 04 00 00 7E 1F FF FF ......._....~...
2. Answer: 13:55:48.691
Size 51 B (24.40%)
00 01 00 01 00 01 00 2B 61 29 A1 09 06 07 60 85 .......+a)....`.
74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 t...............
00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 7E 1F 05 ........_....~..
00 00 07 ...
3. Request: 13:55:48.692
Size 21 B (10.05%)
00 01 00 01 00 01 00 0D C0 01 40 00 08 00 00 01 ..........@.....
00 00 FF 02 00 .....
4. Answer: 13:55:48.987
Size 26 B (12.44%)
00 01 00 01 00 01 00 12 C4 01 40 00 09 0C 07 E4 ..........@.....
08 12 02 0D 37 31 00 FF 4C 80 ....71..L.
5. Request: 13:55:48.987
Size 21 B (10.05%)
6. Answer: 13:55:49.250
Size 26 B (12.44%)
You are connecting using Low authentication. I believe that you can't write anything else than the clock.
The connection is re-established when you write something. I need first frame from that.
hhkx
Yes it's true, I can only write the clock with GXDLMSDirector.
Sep2 Meterview write anything.
I believe I have sent the first frame for Sep2 Meterview and GXDLMSDirector above whic has 2 different bits at the end.
So here is the log for adding 1.0.1.7.0 register to 1.0.99.1.0.255 by using Sep2 Meterview.
Events: 8, Bytes: 316
Requests: 4 (50.00%), Requests bytes: 229 (72.47%)
Answers: 4 (50.00%), Answer bytes: 87 (27.53%)
1. Request: 20:27:07.291
Size 64 B (20.25%)
02 01 AC 0A 80 08 xx xx xx xx xx xx xx xx BE 10 ......XXXXXXXX..
2. Answer: 20:27:07.685
Size 51 B (16.14%)
00 00 07 ...
3. Request: 20:27:07.686
Size 113 B (35.76%)
00 01 00 01 00 01 00 69 C1 01 40 00 07 01 00 63 .......i..@....c
01 00 FF 03 00 01 05 02 04 12 00 08 09 06 00 00 ................
01 00 00 FF 0F 02 12 00 00 02 04 12 00 01 09 06 ................
00 00 60 0A 01 FF 0F 02 12 00 00 02 04 12 00 03 ..`.............
09 06 01 00 1F 07 00 FF 0F 02 12 00 00 02 04 12 ................
00 03 09 06 01 00 20 07 00 FF 0F 02 12 00 00 02 ...... .........
04 12 00 03 09 06 01 00 01 07 00 FF 0F 02 12 00 ................
00 .
4. Answer: 20:27:08.284
Size 12 B (3.80%)
00 01 00 01 00 01 00 04 C5 01 40 00 ..........@.
5. Request: 20:27:08.284
Size 26 B (8.23%)
00 01 00 01 00 01 00 12 C1 01 40 00 07 01 00 63 ..........@....c
01 00 FF 04 00 06 00 00 03 84 ..........
6. Answer: 20:27:08.783
Size 12 B (3.80%)
7. Request: 20:27:08.783
Size 26 B (8.23%)
01 00 FF 08 00 06 00 00 4E 00 ........N.
8. Answer: 20:27:09.046
Size 12 B (3.80%)
