  3. Step By Step To Implment Gurux Dlms Java Server
Step by step to implment gurux dlms java server
By hridendra , 21 May, 2020
please guide me on how to create a setup for the DLMS as the server.
6 years 2 months ago
Download gurux.dlms.server.example.java from GitHub and read this:
https://www.gurux.fi/Gurux.DLMS.Server
hridendra
6 years 1 month ago
I make run the code (gurux.dlms.server.example.java) and it is connected through socket and received when i push data from other side socket, But when I connected the Meter it shows connected but did not received any information while connected. The method on connected (onClientConnected) is called. So tell me how we can fetch the meter data information while on connect.
I am not able to get data from meter after the meter connected.
6 years 1 month ago
Hi Hridendra,
Hi Hridendra,
If you want to read data from the meter, you need to implement a client, not a server.
I believe this might help you.
hridendra
6 years 1 month ago
I received the data from the meter using IP and port.
I want to implement MQ(messaging queue (Rabbit Mq)) for connectivity with meters using the client java. Can you please explain it that is possible or not if yes then how..?
6 years 1 month ago
Hi Hridendra,
Hi Hridendra,
We have MQTT media only for sharp at the moment. You can use any MQ client you want to. You can generate and parse bytes using our libraries. You only need to send generated bytes to the wanted meter.
epdcldlms
6 years ago
Hi Hridendra,
Hi Hridendra,
we have started implementing smart meter project,
i configured the project as per the steps given
can you please explain / provide step by step document if any to read smart meter data.
6 years ago
In reply to Hi Hridendra, by epdcldlms
Do you want to use MQTT or TCP/IP connection to read the meters?
Have you read those:
http://gurux.fi/Gurux.MQTT
http://gurux.fi/Gurux.DLMS.Client
I believe that best way to start is if you download GXDLMSDirector and read data with that.
It will visualize what kind of data meter can offer.
epdcldlms
6 years ago
In reply to Hi, by hridendra
Hi hridendra,
Hi hridendra,
can you please tell me the process how to import project and implement meter reading process using java
  • Dawsontot
  • Jerrylam
  • qvlLdJweKzGUYaSOVS
  • LindanEt
  • annoyingconsultants
