  3. Can Not Load Gurux.Common.dll and Gurux.Serial.dll For .Net Core Project
Can not load Gurux.Common.dll and Gurux.Serial.dll for .Net Core project
By KhushbuBadheka , 30 March, 2020
Gurux.Serial
I tried to use GuruX.Common.dll and GuruX.Serial.dll of for my .Net Core 3.1 project. I tried to use " "netcoreapp2.0" and "netcoreapp2.1" dlls for reference, however we received error "Could not load file or assembly 'Gurux.Common, Version=0.0.1.0, Culture=neutral, PublicKeyToken=null'. The system cannot find the file specified.":"Gurux.Common, Version=0.0.1.0, Culture=neutral, PublicKeyToken=null" each time.
Thanks and Regards.
6 years 3 months ago
You need to download them from nuget.org. Visual Studio does that automatically.
https://www.nuget.org/
KhushbuBadheka
Thanks Mikko for your prompt
Thanks Mikko for your prompt reply.
However, I can not move forward by using DLLs from "netcoreapp2.0" and "netcoreapp2.1" in my Core application which run with 3.0 version. Do I need to use the latest version of source code of GuruX?
You should be able to use .Net Core 2.1 in .Net Core 3.0 without problems.
What IDE you are using?
KhushbuBadheka
We are using VS 2019
We are using VS 2019 Professional.
Can you select project. Then press the right button and select "Manage Nuget Packages..."
Select Browse and install Gurux.Serial.
KhushbuBadheka
Thanks Mikko.
Thanks Mikko.
Will try for the same. And let you know the results.
KhushbuBadheka
I tried and got success to communicate via Serial.
Thanks for your support.
Stay Safe.
  • darren
  • Georgerah
  • Pokiessearm
  • Rolling-Slots-Bok
  • OskoNadyLoold
