  3. Physical Address In Client Example
Physical Address in Client Example
Profile picture for user kamerdack
By kamerdack , 20 March, 2020
Gurux.Serial
GXDLMS Director can connect to smart meter but when i want to connect by python client example, it does not work.
Physical address is 11
Client address is 1
Logical server
but i can not find any parameter for physical address in commond line.
python main.py -S COM4:9600:8None1 -P 12345678 -a Low -c 1 -s 1 -t Verbose -g "0.0.1.0.0.255:2"
screen saver for GXDLMS director is attached. what s my problem?
6 years 8 months ago
GXDLMSDirector address are in the hex format. Try this:
python main.py -S COM4:9600:8None1 -P 12345678 -a Low -c 17 -s 1
kamerdack
Thanks for reply.
Thanks for reply.
i tried that.
12345678 -a Low -c 17 -s 1 -t Verbose -g "0.0.1.0.0.255:2"
gurux_dlms version: 1.0.61
gurux_net version: 1.0.17
gurux_serial version: 1.0.14
ClientAddress: 0x11
TX: 19:53:40 7E A0 07 03 23 93 BF 32 7E
RX: 19:53:55 7E A0 1F 23 02 23 73 90 FE 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
raise TimeoutException("Failed to receive reply from the device in given time.")
gurux_common.TimeoutException.TimeoutException: Failed to receive reply from the device in given time.
but when i try it with GXDLMS DIRECTOR it send this
TX: 7e a0 08 02 23 03 93 3e 74 7e ~ ..#.“>t~
RX: 7e a0 1f 03 02 23 73 c3 71 81 80 12 05 01 80 06 ~ ...#sÃq€...€.
01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3b .€............S;
7e ~
and it works.
whats different between them? Do i miss something?
I'm sorry. I count the server address wrong. Correct parameter is:
python main.py -S COM4:9600:8None1 -P 12345678 -a Low -c 1 -s 145
mato3848
6 years 6 months ago
HI, Mikko,
HI, Mikko,
That’s solve my problem.
How the address 0x11 is converted to 145?
Hi Mauricio,
Hi Mauricio,
Counting the address for HDLC framing is explained here.
https://www.gurux.fi/dlmsaddress
mato3848
Dear Mikko,
Dear Mikko,
thanks for your answer, extremely useful information.
I still have some problems.
With GXDLMSDirector i used Client Address: 1, Logical Server:1 and Physical Server: 11 to read the meter without problems., in the LOG of Director i can see <TargetAddress Value="91" /> <SourceAddress Value="1" />.
But if used the same address to read the meter with python I got errors:
main.py -S COM2 -c 1 -s 145 -a Low -P "12345678" -C None -g "1.0.32.27.0.255:3"
gurux_dlms version: 1.0.72
ClientAddress: 0x1
ServerAddress: 0x91
Standard: Standard.DLMS
RX: 09:50:20 7E A0 18 03 00 02 00 23 DA C3 D0 E6 E7 00 C4 01 C1 00 17 42 FD 81 6C 8D C7 7E
File " main.py", line 102, in main
val = reader.read(settings.client.objects.findByLN(ObjectType.NONE, k), v)
File " GXDLMSReader.py", line 326, in read
self.readDataBlock(data, reply)
File " GXDLMSReader.py", line 183, in readDataBlock
File " GXDLMSReader.py", line 119, in readDLMSPacket
File " GXDLMSReader.py", line 171, in readDLMSPacket2
raise e
File " GXDLMSReader.py", line 149, in readDLMSPacket2
while not self.client.getData(rd, reply, notify):
File "C:\Python38\lib\site-packages\gurux_dlms\GXDLMSClient.py", line 1107, in getData
raise ex
File "C:\Python38\lib\site-packages\gurux_dlms\GXDLMSClient.py", line 1104, in getData
ret = GXDLMS.getData(self.settings, reply, data, notify)
File "C:\Python38\lib\site-packages\gurux_dlms\GXDLMS.py", line 1880, in getData
cls.getPdu(settings, target)
File "C:\Python38\lib\site-packages\gurux_dlms\GXDLMS.py", line 1710, in getPdu
cls.getValueFromData(settings, data)
File "C:\Python38\lib\site-packages\gurux_dlms\GXDLMS.py", line 1825, in getValueFromData
value = _GXCommon.getData(settings, data, info)
File "C:\Python38\lib\site-packages\gurux_dlms\internal\_GXCommon.py", line 297, in getData
value = cls.getFloat(settings, data, info)
File "C:\Python38\lib\site-packages\gurux_dlms\internal\_GXCommon.py", line 653, in getFloat
value = buff.getFloat()
File "C:\Python38\lib\site-packages\gurux_dlms\GXByteBuffer.py", line 360, in getFloat
if index is None:
UnboundLocalError: local variable 'index' referenced before assignment
With -t Verbose these are the last lines (Full Log at the end of the message):
TX: 10:07:36 7E A0 14 02 23 03 98 9D 09 E6 E6 00 C0 02 C1 00 00 00 33 C0 AC 7E
RX: 10:07:37 7E A0 31 03 00 02 00 23 B8 6D B2 E6 E7 00 C4 02 C1 FF 00 00 00 34 00 18 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 6D 8C 7E
TX: 10:07:38 7E A0 1A 02 23 03 BA 35 6A E6 E6 00 C0 01 C1 00 05 01 00 20 1B 00 FF 03 00 32 FD 7E
RX: 10:07:38 7E A0 18 03 00 02 00 23 DA C3 D0 E6 E7 00 C4 01 C1 00 17 42 FD 0B 14 FE 49 7E
The data arrive but the main.py is unable to decode.
Thanks for your support and help
main.py -S COM2 -t Verbose -c 1 -s 145 -a Low -P "12345678" -C None -g "1.0.32.27.0.255:3"
ClientAddress: 0x1
ServerAddress: 0x91
TX: 10:07:15 7E A0 08 02 23 03 93 3E 74 7E
RX: 10:07:16 7E A0 23 03 00 02 00 23 73 C0 48 81 80 14 05 02 00 F8 06 02 04 B0 07 04 00 00 00 01 08 04 00 00 00 01 D8 CC 7E
TX: 10:07:16 7E A0 45 02 23 03 10 FB 7F E6 E6 00 60 36 A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 01 AC 0A 80 08 31 32 33 34 35 36 37 38 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF DF FB 7E
RX: 10:07:16 7E A0 3A 03 00 02 00 23 30 AF CC E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 00 BE 10 04 0E 08 00 06 5F 1F 04 00 00 1C 1D 04 B0 00 07 F4 24 7E
TX: 10:07:16 7E A0 1A 02 23 03 32 75 62 E6 E6 00 C0 01 C1 00 0F 00 00 28 00 00 FF 02 00 91 53 7E
RX: 10:07:16 7E A0 FE 03 00 02 00 23 52 D6 A2 E6 E7 00 C4 02 C1 00 00 00 00 01 00 81 E4 01 81 EB 02 04 12 00 08 11 00 09 06 00 00 01 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 03 00 02 03 0F 08 16 03 00 02 03 0F 09 16 01 00 01 06 02 02 0F 01 03 01 02 02 0F 02 03 03 02 02 0F 03 03 03 02 02 0F 04 03 03 02 02 0F 05 03 03 02 02 0F 06 03 03 02 04 12 00 0F 11 00 09 06 00 00 28 00 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 00 00 02 03 0F 08 16 00 00 01 04 02 02 0F 01 03 01 02 02 0F 02 03 01 02 02 0F 03 03 01 02 02 0F 04 03 01 02 04 12 00 C1 7D 7E
TX: 10:07:16 7E A0 14 02 23 03 54 FD 05 E6 E6 00 C0 02 C1 00 00 00 01 51 BE 7E
RX: 10:07:17 7E A0 FE 03 00 02 00 23 74 E2 E6 E6 E7 00 C4 02 C1 00 00 00 00 02 00 81 E4 0F 11 00 09 06 00 00 28 00 02 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 03 00 02 03 0F 08 16 00 00 01 04 02 02 0F 01 03 01 02 02 0F 02 03 00 02 02 0F 03 03 01 02 02 0F 04 03 01 02 04 12 00 0F 11 00 09 06 00 00 28 00 03 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 00 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 03 00 02 03 0F 08 16 00 00 01 04 02 02 0F 01 03 01 02 02 0F 02 03 00 02 02 0F 03 03 01 02 02 0F 04 03 01 02 04 12 00 0F 11 00 09 06 00 00 28 00 04 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 65 C4 7E
TX: 10:07:17 7E A0 14 02 23 03 76 ED 07 E6 E6 00 C0 02 C1 00 00 00 02 CA 8C 7E
RX: 10:07:17 7E A0 FE 03 00 02 00 23 96 FE 22 E6 E7 00 C4 02 C1 00 00 00 00 03 00 81 E4 16 00 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 03 00 02 03 0F 08 16 00 00 01 04 02 02 0F 01 03 01 02 02 0F 02 03 00 02 02 0F 03 03 01 02 02 0F 04 03 01 02 04 12 00 11 11 00 09 06 00 00 29 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 2A 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 17 11 01 09 06 00 00 16 00 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 02 03 0F 09 16 01 00 01 00 02 04 12 DD 76 7E
TX: 10:07:17 7E A0 14 02 23 03 98 9D 09 E6 E6 00 C0 02 C1 00 00 00 03 43 9D 7E
RX: 10:07:17 7E A0 FE 03 00 02 00 23 B8 82 EA E6 E7 00 C4 02 C1 00 00 00 00 04 00 81 E4 00 01 11 00 09 06 00 00 60 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 02 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 03 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 04 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 05 FF 02 02 01 02 02 03 99 4F 7E
TX: 10:07:17 7E A0 14 02 23 03 BA 8D 0B E6 E6 00 C0 02 C1 00 00 00 04 FC E9 7E
RX: 10:07:18 7E A0 FE 03 00 02 00 23 DA 96 AA E6 E7 00 C4 02 C1 00 00 00 00 05 00 81 E4 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 06 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 47 12 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 01 05 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 09 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 09 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 09 05 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 E9 3C 7E
TX: 10:07:18 7E A0 14 02 23 03 DC BD 0D E6 E6 00 C0 02 C1 00 00 00 05 75 F8 7E
RX: 10:07:18 7E A0 FE 03 00 02 00 23 FC A2 EE E6 E7 00 C4 02 C1 00 00 00 00 06 00 81 E4 03 11 00 09 06 01 00 1F 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 33 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 47 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 5B 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 20 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 34 07 00 FF 02 02 01 03 02 03 0F 29 36 7E
TX: 10:07:18 7E A0 14 02 23 03 FE AD 0F E6 E6 00 C0 02 C1 00 00 00 06 EE CA 7E
RX: 10:07:19 7E A0 FE 03 00 02 00 23 1E BE 2A E6 E7 00 C4 02 C1 00 00 00 00 07 00 81 E4 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 48 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 51 07 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 51 07 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 51 07 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 51 07 05 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 CA F1 7E
TX: 10:07:19 7E A0 14 02 23 03 10 DD 01 E6 E6 00 C0 02 C1 00 00 00 07 67 DB 7E
RX: 10:07:19 7E A0 FE 03 00 02 00 23 30 C2 E2 E6 E7 00 C4 02 C1 00 00 00 00 08 00 81 E4 01 00 02 04 12 00 03 11 00 09 06 01 00 51 07 06 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 51 07 0F FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 51 07 1A FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0D 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 21 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 35 07 00 FF 02 1F 81 7E
TX: 10:07:19 7E A0 14 02 23 03 32 CD 03 E6 E6 00 C0 02 C1 00 00 00 08 90 23 7E
RX: 10:07:19 7E A0 FE 03 00 02 00 23 52 D6 A2 E6 E7 00 C4 02 C1 00 00 00 00 09 00 81 E4 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 49 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0E 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0F 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 80 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 01 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 36 C9 7E
TX: 10:07:20 7E A0 14 02 23 03 54 FD 05 E6 E6 00 C0 02 C1 00 00 00 09 19 32 7E
RX: 10:07:20 7E A0 FE 03 00 02 00 23 74 E2 E6 E6 E7 00 C4 02 C1 00 00 00 00 0A 00 81 E4 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 02 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 23 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 15 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 16 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 37 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 E1 C0 7E
TX: 10:07:20 7E A0 14 02 23 03 76 ED 07 E6 E6 00 C0 02 C1 00 00 00 0A 82 00 7E
RX: 10:07:20 7E A0 FE 03 00 02 00 23 96 FE 22 E6 E7 00 C4 02 C1 00 00 00 00 0B 00 81 E4 00 29 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 2A 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 4B 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 3D 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 3E 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 03 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 4C 21 7E
TX: 10:07:20 7E A0 14 02 23 03 98 9D 09 E6 E6 00 C0 02 C1 00 00 00 0B 0B 11 7E
RX: 10:07:21 7E A0 FE 03 00 02 00 23 B8 82 EA E6 E7 00 C4 02 C1 00 00 00 00 0C 00 81 E4 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 04 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 82 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 17 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 18 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 84 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 46 0A 7E
TX: 10:07:21 7E A0 14 02 23 03 BA 8D 0B E6 E6 00 C0 02 C1 00 00 00 0C B4 65 7E
RX: 10:07:21 7E A0 FE 03 00 02 00 23 DA 96 AA E6 E7 00 C4 02 C1 00 00 00 00 0D 00 81 E4 03 11 00 09 06 01 00 2B 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 2C 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 86 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 3F 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 40 07 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 05 11 00 09 06 01 00 1F 1B 00 FF 02 02 01 09 02 03 0F 52 7B 7E
TX: 10:07:21 7E A0 14 02 23 03 DC BD 0D E6 E6 00 C0 02 C1 00 00 00 0D 3D 74 7E
RX: 10:07:22 7E A0 FE 03 00 02 00 23 FC A2 EE E6 E7 00 C4 02 C1 00 00 00 00 0E 00 81 E4 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 05 11 00 09 06 01 00 33 1B 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 05 11 00 09 06 01 00 47 1B 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 F6 1B 7E
TX: 10:07:22 7E A0 14 02 23 03 FE AD 0F E6 E6 00 C0 02 C1 00 00 00 0E A6 46 7E
RX: 10:07:22 7E A0 FE 03 00 02 00 23 1E BE 2A E6 E7 00 C4 02 C1 00 00 00 00 0F 00 81 E4 01 00 02 04 12 00 05 11 00 09 06 01 00 20 1B 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 05 11 00 09 06 01 00 34 1B 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 05 11 00 09 06 01 00 48 1B 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 DA FE 7E
TX: 10:07:22 7E A0 14 02 23 03 10 DD 01 E6 E6 00 C0 02 C1 00 00 00 0F 2F 57 7E
RX: 10:07:22 7E A0 FE 03 00 02 00 23 30 C2 E2 E6 E7 00 C4 02 C1 00 00 00 00 10 00 81 E4 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 05 11 00 09 06 01 00 0D 1B 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 05 11 00 09 06 01 00 21 1B 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 05 11 00 09 06 01 00 35 1B 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 E0 8E 7E
TX: 10:07:22 7E A0 14 02 23 03 32 CD 03 E6 E6 00 C0 02 C1 00 00 00 10 59 BF 7E
RX: 10:07:23 7E A0 FE 03 00 02 00 23 52 D6 A2 E6 E7 00 C4 02 C1 00 00 00 00 11 00 81 E4 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 05 11 00 09 06 01 00 49 1B 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 05 11 00 09 06 01 00 01 1B 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 05 11 00 09 06 01 B8 02 7E
TX: 10:07:23 7E A0 14 02 23 03 54 FD 05 E6 E6 00 C0 02 C1 00 00 00 11 D0 AE 7E
RX: 10:07:23 7E A0 FE 03 00 02 00 23 74 E2 E6 E6 E7 00 C4 02 C1 00 00 00 00 12 00 81 E4 00 02 1B 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 05 11 00 09 06 01 00 03 1B 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 05 11 00 09 06 01 00 04 1B 00 FF 02 02 01 09 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 B6 27 7E
TX: 10:07:23 7E A0 14 02 23 03 76 ED 07 E6 E6 00 C0 02 C1 00 00 00 12 4B 9C 7E
RX: 10:07:24 7E A0 FE 03 00 02 00 23 96 FE 22 E6 E7 00 C4 02 C1 00 00 00 00 13 00 81 E4 0F 08 16 03 00 02 03 0F 09 16 03 00 01 00 02 04 12 00 03 11 00 09 06 01 00 01 1D 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 02 1D 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 02 FF 02 02 01 73 2E 7E
TX: 10:07:24 7E A0 14 02 23 03 98 9D 09 E6 E6 00 C0 02 C1 00 00 00 13 C2 8D 7E
RX: 10:07:24 7E A0 FE 03 00 02 00 23 B8 82 EA E6 E7 00 C4 02 C1 00 00 00 00 14 00 81 E4 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 0F 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 01 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 01 06 01 FF 02 02 01 05 02 03 0F FA FD 7E
TX: 10:07:24 7E A0 14 02 23 03 BA 8D 0B E6 E6 00 C0 02 C1 00 00 00 14 7D F9 7E
RX: 10:07:24 7E A0 FE 03 00 02 00 23 DA 96 AA E6 E7 00 C4 02 C1 00 00 00 00 15 00 81 E4 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 01 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 01 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 01 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 02 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 0A 96 7E
TX: 10:07:24 7E A0 14 02 23 03 DC BD 0D E6 E6 00 C0 02 C1 00 00 00 15 F4 E8 7E
RX: 10:07:25 7E A0 FE 03 00 02 00 23 FC A2 EE E6 E7 00 C4 02 C1 00 00 00 00 16 00 81 E4 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 02 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 02 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 02 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 02 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 1B 81 7E
TX: 10:07:25 7E A0 14 02 23 03 FE AD 0F E6 E6 00 C0 02 C1 00 00 00 16 6F DA 7E
RX: 10:07:25 7E A0 FE 03 00 02 00 23 1E BE 2A E6 E7 00 C4 02 C1 00 00 00 00 17 00 81 E4 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 03 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 03 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 03 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 03 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 FD 2D 7E
TX: 10:07:25 7E A0 14 02 23 03 10 DD 01 E6 E6 00 C0 02 C1 00 00 00 17 E6 CB 7E
RX: 10:07:26 7E A0 FE 03 00 02 00 23 30 C2 E2 E6 E7 00 C4 02 C1 00 00 00 00 18 00 81 E4 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 03 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 04 06 00 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 04 06 01 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 04 06 02 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 D5 E1 7E
TX: 10:07:26 7E A0 14 02 23 03 32 CD 03 E6 E6 00 C0 02 C1 00 00 00 18 11 33 7E
RX: 10:07:26 7E A0 FE 03 00 02 00 23 52 D6 A2 E6 E7 00 C4 02 C1 00 00 00 00 19 00 81 E4 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 04 06 03 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 04 11 00 09 06 01 00 04 06 04 FF 02 02 01 05 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0F 02 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0F 02 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0F 02 02 F0 2A 7E
TX: 10:07:26 7E A0 14 02 23 03 54 FD 05 E6 E6 00 C0 02 C1 00 00 00 19 98 22 7E
RX: 10:07:26 7E A0 FE 03 00 02 00 23 74 E2 E6 E6 E7 00 C4 02 C1 00 00 00 00 1A 00 81 E4 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0F 02 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0F 02 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 01 02 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 01 02 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 01 02 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 1D 5B 7E
TX: 10:07:26 7E A0 14 02 23 03 76 ED 07 E6 E6 00 C0 02 C1 00 00 00 1A 03 10 7E
RX: 10:07:27 7E A0 FE 03 00 02 00 23 96 FE 22 E6 E7 00 C4 02 C1 00 00 00 00 1B 00 81 E4 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 01 02 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 01 02 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 02 02 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 02 02 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 02 02 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 EB 70 7E
TX: 10:07:27 7E A0 14 02 23 03 98 9D 09 E6 E6 00 C0 02 C1 00 00 00 1B 8A 01 7E
RX: 10:07:27 7E A0 FE 03 00 02 00 23 B8 82 EA E6 E7 00 C4 02 C1 00 00 00 00 1C 00 81 E4 06 01 00 02 02 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 02 02 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 03 02 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 03 02 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 03 02 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 03 02 03 FF 02 02 01 03 02 03 0F 01 16 01 00 D9 54 7E
TX: 10:07:27 7E A0 14 02 23 03 BA 8D 0B E6 E6 00 C0 02 C1 00 00 00 1C 35 75 7E
RX: 10:07:28 7E A0 FE 03 00 02 00 23 DA 96 AA E6 E7 00 C4 02 C1 00 00 00 00 1D 00 81 E4 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 03 02 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 04 02 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 04 02 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 04 02 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 04 02 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 24 FF 7E
TX: 10:07:28 7E A0 14 02 23 03 DC BD 0D E6 E6 00 C0 02 C1 00 00 00 1D BC 64 7E
RX: 10:07:28 7E A0 FE 03 00 02 00 23 FC A2 EE E6 E7 00 C4 02 C1 00 00 00 00 1E 00 81 E4 12 00 03 11 00 09 06 01 00 04 02 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0F 08 04 FF 02 02 01 03 02 D0 54 7E
TX: 10:07:28 7E A0 14 02 23 03 FE AD 0F E6 E6 00 C0 02 C1 00 00 00 1E 27 56 7E
RX: 10:07:28 7E A0 FE 03 00 02 00 23 1E BE 2A E6 E7 00 C4 02 C1 00 00 00 00 1F 00 81 E4 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 10 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 10 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 10 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 10 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 10 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 4D E3 7E
TX: 10:07:28 7E A0 14 02 23 03 10 DD 01 E6 E6 00 C0 02 C1 00 00 00 1F AE 47 7E
RX: 10:07:29 7E A0 FE 03 00 02 00 23 30 C2 E2 E6 E7 00 C4 02 C1 00 00 00 00 20 00 81 E4 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 01 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 01 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 01 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 01 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 01 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 02 08 00 DF 95 7E
TX: 10:07:29 7E A0 14 02 23 03 32 CD 03 E6 E6 00 C0 02 C1 00 00 00 20 DA 8E 7E
RX: 10:07:29 7E A0 FE 03 00 02 00 23 52 D6 A2 E6 E7 00 C4 02 C1 00 00 00 00 21 00 81 E4 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 02 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 02 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 02 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 02 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 80 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 7A 57 7E
TX: 10:07:29 7E A0 14 02 23 03 54 FD 05 E6 E6 00 C0 02 C1 00 00 00 21 53 9F 7E
RX: 10:07:30 7E A0 FE 03 00 02 00 23 74 E2 E6 E6 E7 00 C4 02 C1 00 00 00 00 22 00 81 E4 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 80 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 80 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 80 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 80 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 81 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 67 34 7E
TX: 10:07:30 7E A0 14 02 23 03 76 ED 07 E6 E6 00 C0 02 C1 00 00 00 22 C8 AD 7E
RX: 10:07:30 7E A0 FE 03 00 02 00 23 96 FE 22 E6 E7 00 C4 02 C1 00 00 00 00 23 00 81 E4 06 01 00 81 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 81 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 81 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 81 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 03 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 03 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 CC C8 7E
TX: 10:07:30 7E A0 14 02 23 03 98 9D 09 E6 E6 00 C0 02 C1 00 00 00 23 41 BC 7E
RX: 10:07:30 7E A0 FE 03 00 02 00 23 B8 82 EA E6 E7 00 C4 02 C1 00 00 00 00 24 00 81 E4 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 03 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 03 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 03 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 04 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 04 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 54 6B 7E
TX: 10:07:30 7E A0 14 02 23 03 BA 8D 0B E6 E6 00 C0 02 C1 00 00 00 24 FE C8 7E
RX: 10:07:31 7E A0 FE 03 00 02 00 23 DA 96 AA E6 E7 00 C4 02 C1 00 00 00 00 25 00 81 E4 12 00 03 11 00 09 06 01 00 04 08 02 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 04 08 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 04 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 46 11 00 09 06 00 00 60 03 0A FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 03 00 01 02 02 02 0F 01 03 01 02 02 0F 02 03 01 02 04 12 00 03 11 00 09 06 01 00 01 23 00 00 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 E3 83 7E
TX: 10:07:31 7E A0 14 02 23 03 DC BD 0D E6 E6 00 C0 02 C1 00 00 00 25 77 D9 7E
RX: 10:07:31 7E A0 FE 03 00 02 00 23 FC A2 EE E6 E7 00 C4 02 C1 00 00 00 00 26 00 81 E4 04 12 00 03 11 00 09 06 01 00 02 23 00 00 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0B 23 00 00 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0B 23 00 01 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0B 23 00 02 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0B 2C 00 00 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0B 2C 00 01 02 02 01 03 F6 3B 7E
TX: 10:07:31 7E A0 14 02 23 03 FE AD 0F E6 E6 00 C0 02 C1 00 00 00 26 EC EB 7E
RX: 10:07:32 7E A0 FE 03 00 02 00 23 1E BE 2A E6 E7 00 C4 02 C1 00 00 00 00 27 00 81 E4 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0B 2C 00 02 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0C 1F 00 01 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0C 2B 00 01 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0C 23 00 01 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0C 2C 00 01 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 34 1E 7E
TX: 10:07:32 7E A0 14 02 23 03 10 DD 01 E6 E6 00 C0 02 C1 00 00 00 27 65 FA 7E
RX: 10:07:32 7E A0 FE 03 00 02 00 23 30 C2 E2 E6 E7 00 C4 02 C1 00 00 00 00 28 00 81 E4 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0C 23 00 02 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0C 2C 00 02 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 0B 2C 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 91 2C 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 93 2C 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 93 2D 14 94 7E
TX: 10:07:32 7E A0 14 02 23 03 32 CD 03 E6 E6 00 C0 02 C1 00 00 00 28 92 02 7E
RX: 10:07:32 7E A0 FE 03 00 02 00 23 52 D6 A2 E6 E7 00 C4 02 C1 00 00 00 00 29 00 81 E4 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 03 11 00 09 06 01 00 93 2E 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 00 00 60 06 03 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 00 00 60 07 14 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0A 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 07 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 71 89 7E
TX: 10:07:32 7E A0 14 02 23 03 54 FD 05 E6 E6 00 C0 02 C1 00 00 00 29 1B 13 7E
RX: 10:07:33 7E A0 FE 03 00 02 00 23 74 E2 E6 E6 E7 00 C4 02 C1 00 00 00 00 2A 00 81 E4 00 60 07 0A FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 03 11 00 09 06 00 00 60 3C 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 00 00 60 3C 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 47 12 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 48 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0E 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 00 00 60 0E 01 52 27 7E
TX: 10:07:33 7E A0 14 02 23 03 76 ED 07 E6 E6 00 C0 02 C1 00 00 00 2A 80 21 7E
RX: 10:07:33 7E A0 FE 03 00 02 00 23 96 FE 22 E6 E7 00 C4 02 C1 00 00 00 00 2B 00 81 E4 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 00 08 00 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 00 08 01 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 00 08 04 FF 02 02 01 03 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 01 00 02 04 12 00 03 11 00 09 06 01 00 00 08 06 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 01 02 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 4F D3 7E
TX: 10:07:33 7E A0 14 02 23 03 98 9D 09 E6 E6 00 C0 02 C1 00 00 00 2B 09 30 7E
RX: 10:07:34 7E A0 FE 03 00 02 00 23 B8 82 EA E6 E7 00 C4 02 C1 00 00 00 00 2C 00 81 E4 00 01 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 01 11 00 09 06 01 00 00 01 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 00 02 04 12 00 14 11 00 09 06 00 00 0D 00 00 FF 02 02 01 0A 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 02 03 0F 03 16 01 00 02 03 0F 04 16 03 00 02 03 0F 05 16 03 00 02 03 0F 06 16 03 00 02 03 0F 07 16 01 00 02 03 0F 08 16 03 00 02 03 0F 09 16 03 00 02 03 0F 0A 16 03 00 01 01 02 02 0F 01 03 01 02 04 12 00 0B 11 00 09 06 00 00 0B 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 01 02 02 0F 01 03 01 02 04 12 00 16 11 00 09 06 00 00 0F 00 00 FF 02 02 01 04 02 03 0F 01 16 01 00 02 03 0F 02 16 39 58 7E
TX: 10:07:34 7E A0 14 02 23 03 BA 8D 0B E6 E6 00 C0 02 C1 00 00 00 2C B6 44 7E
RX: 10:07:34 7E A0 FE 03 00 02 00 23 DA 96 AA E6 E7 00 C4 02 C1 00 00 00 00 2D 00 81 E4 03 00 02 03 0F 03 16 03 00 02 03 0F 04 16 03 00 01 00 02 04 12 00 09 11 00 09 06 00 00 0A 00 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 01 02 02 0F 01 03 01 02 04 12 00 09 11 00 09 06 00 00 0A 00 00 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 07 11 01 09 06 00 00 63 62 07 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 07 11 01 09 06 00 00 63 62 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 16 5B 7E
TX: 10:07:34 7E A0 14 02 23 03 DC BD 0D E6 E6 00 C0 02 C1 00 00 00 2D 3F 55 7E
RX: 10:07:34 7E A0 FE 03 00 02 00 23 FC A2 EE E6 E7 00 C4 02 C1 00 00 00 00 2E 00 81 E4 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 07 11 01 09 06 00 00 63 62 08 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 07 11 01 09 06 00 00 63 62 01 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 07 11 01 09 06 00 00 63 62 06 FF 02 02 01 08 02 03 0F 01 16 DA 30 7E
TX: 10:07:34 7E A0 14 02 23 03 FE AD 0F E6 E6 00 C0 02 C1 00 00 00 2E A4 67 7E
RX: 10:07:35 7E A0 FE 03 00 02 00 23 1E BE 2A E6 E7 00 C4 02 C1 00 00 00 00 2F 00 81 E4 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 07 11 01 09 06 00 00 63 62 02 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 07 11 01 09 06 00 00 63 62 03 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 94 86 7E
TX: 10:07:35 7E A0 14 02 23 03 10 DD 01 E6 E6 00 C0 02 C1 00 00 00 2F 2D 76 7E
RX: 10:07:35 7E A0 FE 03 00 02 00 23 30 C2 E2 E6 E7 00 C4 02 C1 00 00 00 00 30 00 81 E4 00 07 11 01 09 06 00 00 63 62 04 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 07 11 01 09 06 00 00 63 62 0B FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 07 11 01 09 06 00 00 63 62 0A FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 54 23 7E
TX: 10:07:35 7E A0 14 02 23 03 32 CD 03 E6 E6 00 C0 02 C1 00 00 00 30 5B 9E 7E
RX: 10:07:36 7E A0 FE 03 00 02 00 23 52 D6 A2 E6 E7 00 C4 02 C1 00 00 00 00 31 00 81 E4 16 01 00 02 03 0F 08 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 07 11 01 09 06 00 00 63 62 09 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 07 11 01 09 06 00 00 63 62 05 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 01 02 02 0F 01 03 01 02 04 12 00 07 11 01 09 06 01 00 63 01 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 10 5D 7E
TX: 10:07:36 7E A0 14 02 23 03 54 FD 05 E6 E6 00 C0 02 C1 00 00 00 31 D2 8F 7E
RX: 10:07:36 7E A0 FE 03 00 02 00 23 74 E2 E6 E6 E7 00 C4 02 C1 00 00 00 00 32 00 81 E4 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 01 02 02 0F 02 03 01 02 04 12 00 07 11 01 09 06 01 00 62 01 00 FF 02 02 01 08 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 01 00 02 03 0F 07 16 01 00 02 03 0F 08 16 01 00 01 02 02 02 0F 01 03 01 02 02 0F 02 03 01 02 04 12 00 01 11 00 09 06 00 00 2B 01 01 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 12 11 00 09 06 00 00 2C 00 00 FF 02 02 01 07 02 03 0F 01 16 01 00 02 03 0F 02 16 01 00 02 03 0F 03 16 01 00 02 03 0F 04 16 01 00 02 03 0F 05 16 01 00 02 03 0F 06 16 5C C1 7E
TX: 10:07:36 7E A0 14 02 23 03 76 ED 07 E6 E6 00 C0 02 C1 00 00 00 32 49 BD 7E
RX: 10:07:36 7E A0 FE 03 00 02 00 23 96 FE 22 E6 E7 00 C4 02 C1 00 00 00 00 33 00 81 E4 01 00 02 03 0F 07 16 01 00 01 04 02 02 0F 01 03 01 02 02 0F 02 03 01 02 02 0F 03 03 01 02 02 0F 04 03 01 02 04 12 00 01 11 00 09 06 01 00 00 02 08 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 47 08 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 47 09 FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 47 0A FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 01 11 00 09 06 01 00 60 47 0B FF 02 02 01 02 02 03 0F 01 16 01 00 02 03 0F 02 16 03 00 01 00 02 04 12 00 03 11 00 09 06 01 00 00 03 03 FF 02 02 01 21 78 7E
File "main.py", line 102, in main
File "GXDLMSReader.py", line 326, in read
File "GXDLMSReader.py", line 183, in readDataBlock
File "GXDLMSReader.py", line 119, in readDLMSPacket
File "GXDLMSReader.py", line 171, in readDLMSPacket2
raise e
File "GXDLMSReader.py", line 149, in readDLMSPacket2
raise ex
if index is None:
TX: 10:07:38 7E A0 08 02 23 03 53 32 B2 7E
RX: 10:07:38 7E A0 0A 03 00 02 00 23 73 7A 6A 7E
Hi Mauricio ,
Hi Mauricio ,
Thank you for this info. I created an issue from this:
https://www.gurux.fi/node/15809
This is not fixed and new version is released.
Run this and update to the newest version (1.0.74):
pip install --upgrade gurux-dlms
  • Suria
  • pespinosaferrer777
  • Gabice William
  • ngewe
  • jojon15
