  3. Authentication
Authentication
Profile picture for user gzpmanish
By gzpmanish , 4 March, 2020
Gurux.Serial
I am using Sumeru verde energy meter.
I am used Gurux.DLMS.Python to read the value of energy meter.
Where I can enter high level authentication key in the code ?
6 years 5 months ago
Hi.
Hi.
You need to change the client address also.
client = GXDLMSClient(True, 0x30, 0x1, Authentication.HIGH, bytes("Password"), InterfaceType.HDLC)
gzpmanish
In reply to Hi. by Kurumi
Sir, I am not understand
Sir, I am not understand which python file change these setting.
I am run the main.py file.
Add parameters -a High -P "PASSWORD".
Client examples are supporting only ASCII password. If you want to use HEX, you need to hardcode it.
gzpmanish
Sir, My meter password is
Sir, My meter password is 2222222222222222 in decimal.
I am write a python main.py -S /dev/ttyUSB0 -a High -P "7E5196E2AE38E" in the terminal, its gives the error. It shown the below.
Authentication: Authentication.HIGH
ClientAddress: 0x10
File "main.py", line 69, in main
reader.readAll()
File "/home/pi/dlms/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 485, in readAll
self.initializeConnection()
File "/home/pi/dlms/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 303, in initializeConnection
self.client.parseAareResponse(reply.data)
File "/home/pi/.local/lib/python2.7/site-packages/gurux_dlms/GXDLMSClient.py", line 522, in parseAareResponse
self.isAuthenticationRequired = _GXAPDU.parsePDU(self.settings, self.settings.cipher, reply, None) == SourceDiagnostic.AUTHENTICATION_REQUIRED
File "/home/pi/.local/lib/python2.7/site-packages/gurux_dlms/_GXAPDU.py", line 641, in parsePDU
ret = _GXAPDU.parsePDU2(settings, cipher, buff, xml)
File "/home/pi/.local/lib/python2.7/site-packages/gurux_dlms/_GXAPDU.py", line 807, in parsePDU2
raise GXDLMSException(resultComponent, resultDiagnosticValue)
GXDLMSException: Access Error : Device reports a hardware fault.
That is a hex string. You need to hard code it. You can try to give it as hex value:
0x22 equals " in ASCII
gzpmanish
Its gives a error(python main
Its gives a error(python main.py -S /dev/ttyUSB0 -a High -P """""""" )
ClientAddress: 0x10
reader.readAll()
Can you run this with -t Verbose parameter?
gzpmanish
Its gives this error(python
Its gives this error(python main.py -S /dev/ttyUSB0 -a High -P """""""" -t Verbose).
ClientAddress: 0x10
TX: 16:38:23 7E A0 07 03 21 93 0F 01 7E
RX: 16:38:23 7E A0 1E 21 03 73 C3 7A 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 16:38:23 7E A0 4C 03 21 10 3E 61 E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 80 F4 1E 41 C2 2B EC 1D 96 AE A6 D1 6F 9A D1 27 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF 50 79 7E
RX: 16:38:23 7E A0 37 21 03 30 6C 7C E6 E7 00 61 29 A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 01 A3 05 A1 03 02 01 0D BE 10 04 0E 08 00 06 5F 1F 04 00 00 00 10 02 00 00 07 0F 53 7E
TX: 16:38:23 7E A0 07 03 21 53 03 C7 7E
reader.readAll()
Your client address is wrong.It should be 48 (0x30). Try to add parameter -c 48
gzpmanish
Again its gives a error
Again its gives a error(python main.py -S /dev/ttyUSB0 -a High -P """""""" -c 48 -t Verbose).
ClientAddress: 0x30
TX: 22:36:55 7E A0 07 03 61 93 69 47 7E
RX: 22:36:56 7E A0 1E 61 03 73 B5 7C 81 80 12 05 01 80 06 01 80 07 04 00 00 00 01 08 04 00 00 00 01 53 3B 7E
TX: 22:36:56 7E A0 4C 03 61 10 58 27 E6 E6 00 60 3E A1 09 06 07 60 85 74 05 08 01 01 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 29 0E 8D 7D 51 D3 AC 66 32 FF 4F 28 77 E3 33 13 BE 10 04 0E 01 00 00 00 06 5F 1F 04 00 00 1E 1D FF FF FC 78 7E
RX: 22:36:56 7E A0 58 61 03 30 07 51 E6 E7 00 61 4A A1 09 06 07 60 85 74 05 08 01 01 A2 03 02 01 00 A3 05 A1 03 02 01 0E 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 31 32 33 34 35 36 37 38 39 30 41 42 43 44 45 46 BE 10 04 0E 08 00 06 5F 1F 04 00 00 18 1D 02 00 00 07 93 D9 7E
TX: 22:36:56 7E A0 07 03 61 53 65 81 7E
reader.readAll()
File "/home/pi/dlms/Gurux.DLMS.Python/Gurux.DLMS.Client.Example.python/GXDLMSReader.py", line 306, in initializeConnection
for it in self.client.getApplicationAssociationRequest():
File "/home/pi/.local/lib/python2.7/site-packages/gurux_dlms/GXDLMSClient.py", line 539, in getApplicationAssociationRequest
raise ValueError("Password is invalid.")
ValueError: Password is invalid.
Hi Manish,
Hi Manish,
You need to change password to the client example. Our locale settings are different and the password is not recognized for ASCII string.
  • brsRKNujhfnXWm…
  • TmncVuWXpMBjtlVn
  • suMPQCGuZJqlCP…
  • mohanad
  • LOYmPGKtLNYdKy…
