  3. GXDLMSTranslator Python
By Aashikms , 28 February, 2020
I am trying to decrypt and analyse a wrapper push message sent from the Smart meter.
I used GXDLMS translator application in your website, after providing message and cipher key message was translated and able to read the message in XML format.
So to automate it i am planning to use your Python gurux_dlms libraries. Found GXDLMSTranslator object and in that when i passed the data to function messagetoXML i am getting following error.
below is the sample code.
code:
from gurux_dlms import *
data = "wrapper message"
t = GXDLMSTranslator(TranslatorOutputType.SIMPLE_XML)
t.security = enums.Security.AUTHENTICATION_ENCRYPTION
t.blockCipherKey =GXByteBuffer.hexToBytes("my 16 byte key")
xml = t.messageToXml(GXByteBuffer.hexToBytes(data))
print(xml)
error:
'NoneType' object has no attribute 'sourceSystemTitle'
File "<stdin>", line 1, in <module>
File "C:\Users\104714\AppData\Local\Programs\Python\Python38-32\lib\site-packages\gurux_dlms\GXDLMSTranslator.py", line 454, in messageToXml
raise ValueError("Invalid DLMS framing.")
ValueError: Invalid DLMS framing.
PS: the same message is getting decrypted in translator application message to xml window.
Aashikms
6 years 5 months ago
Please someone help me with this.
Below is the sample message i am decrypting.
000100010040007FDB085A454E4E30303032743000000167F751D9FDB255D234749EE29680A725090CC4D536516FF047D82A5066D7793AC798178384BC49DE85B725C8B0B10F6DFFAF0DFAD3FDA65B2B061F7108075AA47E58B8707D051E1A163CE3A00B77E7BDDD773742BF2E731AA47D850036816FAA410142B3B606B351FA35DF57E752464B
And below is the screenshot of the DLMS translator application:
We have fixed this to the Python and try to release a new version today after the tests are over.
Aashikms
6 years 4 months ago
I have updated python package and ran above example and i am getting below error.
Error:
'GXDLMSSettings' object has no attribute 'setClientAddress'
File "server.py", line 33, in <module>
Am i missing something or this is a bug.
Hi Aashik,
Hi Aashik,
Thank you for this info. This is now fixed and the new version is released (1.0.52).
Aashikms
Thanks for the fix, Now i am able to get the XML data in ciphered format. Even after providing Block ciphered key i am getting only XML output as below.
Output:
<WRAPPER len="0" >
<TargetAddress Value="0" />
<SourceAddress Value="0" />
<PDU>
<GeneralGloCiphering>
<SystemTitle Value="5A454E4E30303032" />
<CipheredService Value="3000000167F751D9FDB255D234749EE29680A725090CC4D536516FF047D82A5066D7793AC798178384BC49DE85B725C8B0B10F6DFFAF0DFAD3FDA65B2B061F7108075AA47E58B8707D051E1A163CE3A00B77E7BDDD773742BF2E731AA47D850036816FAA410142B3B606B351FA35DF57E752464B" />
</GeneralGloCiphering>
</PDU>
</WRAPPER>
Check your block cipher key. I believe that it's not correct.
Aashikms
Block Cypher key is correct as the same worked properly when i checked with DLMS translator application.
And also in XML output of python script Wrapper length, source and destination address is showing as 0.
We improved this. You need to set security and comments before data is shown.
http://www.gurux.fi/node/15061
Get the latest version and add comments.
t = GXDLMSTranslator()
t.comments = True
Aashikms
Thanks for quick reply, But still XML message is not complete below is the output i am getting after adding comment and security.
<WRAPPER len="87" >
<TargetAddress Value="1" />
<SourceAddress Value="40" />
<PDU>
-->ial number: 3158066ector extension, Load Management extension
</PDU>
</WRAPPER>
Have you updated to version 1.0.53 and your code looks like this?
t.comments = True
print(xml)
Aashikms
Yes i have updated the package to 1.0.53 and Code is same as above.
Have you also set block cipher key? All lines are something like this.
GXDLMSTranslator t = new GXDLMSTranslator(TranslatorOutputType.SIMPLE_XML);
t.setComments(true);
t.setSystemTitle("Client system title");
t.setBlockCipherKey("YOUR BLOCK CIPHER KEY");
t.setServerSystemTitle("Server system title");
t.messageToXml(data);
Aashikms
Yes i have set block ciphered key and comments. also i have added system title also to check.
But getting the same output.
If you check the output we are getting the comment but the decrypted message in the comment is not complete.
Decrypted output in Python SDK:
<PDU>
Decrypted output in Translator application:
IDIS system title:
Manufacturer Code: ZEN
Function type: Disconnector extension, Load Management extension
Serial number: 3158066
<!--Decrypt data: 0F D0 00 00 6A 0C 07 E4 02 0B 02 0D 00 02 FF 01 4A 00 02 0D 0A 0A 5A 45 4E 5A 45 4E 30 30 30 32 09 06 00 00 19 09 00 FF 09 0C 07 E4 02 0B 02 0D 00 02 FF 01 4A 00 17 43 6E FD 71 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 17 00 00 00 00 12 00 09 06 00 00 00 00 17 00 00 00 00 03 01 06 00 00 43 80
<DataNotification>
<LongInvokeIdAndPriority Value="D000006A" />
<!--12-02-2020 12:00:02 AM-->
<DateTime Value="07E4020B020D0002FF014A00" />
<NotificationBody>
<DataValue>
<Structure Qty="0D" >
<String Value="ZENZEN0002" />
<!--0.0.25.9.0.255-->
<OctetString Value="0000190900FF" />
<OctetString Value="07E4020B020D0002FF014A00" />
<!--238.99-->
<Float32 Value="436EFD71" />
<!--0-->
<Float32 Value="00000000" />
<!--0-->
<!--0-->
<!--0-->
<UInt16 Value="0009" />
<UInt32 Value="00000000" />
<!--0-->
<Boolean Value="true" />
<UInt32 Value="00004380" />
</Structure>
</DataValue>
</NotificationBody>
</DataNotification>
So the above comments which has to be shown is not properly showing in Python SDK.
That is data what meter returns. If you want something else, you need to configure the meter to send it.
Aashikms
But the same message is properly decoding in the Translator application but not in Python sdk.
Update to the latest version:
pip install --upgrade gurux-dlms
Try with this. Then update your authentication and block cipher keys and try with your data.
from gurux_dlms import GXDLMSTranslator
from gurux_dlms import GXByteBuffer
data = "00 01 00 01 00 10 00 58 DB 08 41 42 43 44 45 46 47 48 4D 30 00 00 00 00 11 98 4B 30 35 F0 35 51 06 72 DA 54 93 70 8E 70 9B 3D BD 31 02 14 CE 10 A9 89 81 92 53 80 42 A9 19 D7 52 62 7B E6 70 B3 13 30 E1 53 B6 9D 0B 6D 14 8D 86 F9 D4 6F 6B C3 09 24 A8 4C 50 03 82 FF 05 77 A5 9B F1 1F CD 78"
t.comments = True
t.systemTitle = "ABCDEFGH".encode()
t.blockCipherKey = bytearray((0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0A, 0x0B, 0x0C, 0x0D, 0x0E, 0x0F))
t.authenticationKey = bytearray((0xD0, 0xD1, 0xD2, 0xD3, 0xD4, 0xD5, 0xD6, 0xD7, 0xD8, 0xD9, 0xDA, 0xDB, 0xDC, 0xDD, 0xDE, 0xDF))
t.serverSystemTitle = GXByteBuffer.hexToBytes("4142434445464748")
print(t.messageToXml(data))
Aashikms
Thanks now i am getting the output.
rudreshmr@gmail.com
4 years 12 months ago
Hi Mikko Kurunsaari,
Why this <DataNotification> is commented in GXDLMSTranslator XMLResponse and its added in comment section? is there any other API which gives decrypted hex.
Rudresh
In reply to Hi Mikko Kurunsaari, by rudreshmr@gmail.com
Hi Rudresh,
Hi Rudresh,
Please, create a new topic if you have a new question. Add also what programming language you are using.
ravichandra99
4 years 1 month ago
Hi Mikko
Hi Mikko
I was able to get encrypted data and Im using the above code to decrypt data
and using xml = t.messageToXml(GXByteBuffer.hexToBytes(data)) before last line.. im still getting encrypted data
what is serverSystemTitle? is it same as systemTitle?
ravichandra99
4 years 1 month ago
In reply to Hi Mikko by ravichandra99
this is data output i got in
this is data output i got in xml file .. https://pastebin.com/W2XtWtR4
4 years 1 month ago
In reply to this is data output i got in by ravichandra99
Hi Ravi ,
Hi Ravi ,
Please, create a new topic if you have a new question. I'll answer for your question there.
  • ScottCab
  • prmjPfWJENeYCh…
  • Tyronesok
  • Dawley07
  • nostra
