  3. Authentication Key
Authentication Key
Profile picture for user mahsen
By mahsen , 14 January, 2020
i am using c library gurux,
i need to know how to change 'settings->cipher->authenticationKey' by 'GXDLMSDirector.exe'
may i ask you some examples which is showing how to change 'cipher' by method 'action' through programming code and 'GXDLMSDirector.exe' ?
thanks a lot
6 years 6 months ago
You can change the ciphering key from GXDLMSDirector selecting "Security Setup". and "Update key".
Select the key that you want to update.
You need to know the correct Master Key (KEK) to update the key.
After the key is updated to the meter. Close connection. Update the new key to the GXDLMSDirector device settings and make a new connection.
We are improving the server examples so keys are shown on the console after they are updated.
mahsen
regretfully, I do not know
regretfully, I do not know how to get 'data' in 'Security_Setup-> global_key_transfer-> e.parameters' programming c code,
for this reason i some how, need code example.
Gurux DLMS for ANSI C is updated. Get the latest version.
When you update new keys console output is written.
You can get new keys in postaction.
mahsen
Thank you, my problem was
Thank you, my problem was solved.
  • sAYgntkdaTjhgpvfz
  • HenryEneno
  • ScottCab
  • prmjPfWJENeYCh…
  • Tyronesok
