  3. Access Error : Device Reports a Unavailable Object.
Access Error : Device reports a unavailable object.
By Bhaumik , 5 December, 2019
Gurux.Serial
Initially, I have connect meter using high-level security. Then set the secret from Association 0.0.40.0.5.255. Now I am trying to connect a meter with updated secret but not able to connect.
Can you please check the following logs and provide an update.
Let me know if you require more information about the same.
16:46:25 Initializing serial connection.
04:46:26 PM Send SNRM request.
7E A0 07 03 61 93 69 47 7E
<HDLC len="9" >
<TargetAddress Value="1" />
<SourceAddress Value="30" />
<FrameType Value="93" />
<Snrm>
</Snrm>
</HDLC>
04:46:26 PM
7E A0 20 61 03 73 05 9E 81 80 14 05 02 00 FA 06 02 00 FA 07 04 00 00 00 01 08 04 00 00 00 01 1C 5A 7E
<HDLC len="1F" >
<TargetAddress Value="30" />
<SourceAddress Value="1" />
<FrameType Value="73" />
<PDU>
<Ua>
<MaxInfoTX Value="250" />
<MaxInfoRX Value="250" />
<WindowSizeTX Value="1" />
<WindowSizeRX Value="1" />
</Ua>
</PDU>
</HDLC>
Duration: 100
16:46:26 Parsing UA reply succeeded.
04:46:26 PM Send AARQ request.
7E A0 6B 03 61 10 2A FF E6 E6 00 60 5D A1 09 06 07 60 85 74 05 08 01 03 A6 0A 04 08 5A 45 4E 30 30 30 37 35 8A 02 07 80 8B 07 60 85 74 05 08 02 02 AC 12 80 10 39 57 42 1E 11 6C 66 12 04 3A 0C 10 16 61 49 0D BE 23 04 21 21 1F 30 00 00 00 05 82 EF 02 F7 05 F8 53 2F 6E 98 4E 8F 42 0D 44 23 BB 88 08 C1 28 49 2E DA 80 48 BD 74 7E
<HDLC len="6A" >
<FrameType Value="10" />
<PDU>
<AssociationRequest>
<CallingAPTitle Value="5A454E3030303735" />
<MechanismName Value="High" />
<CallingAuthentication Value="3957421E116C6612043A0C101661490D" />
<glo_InitiateRequest Value="300000000582EF02F705F8532F6E984E8F420D4423BB8808C128492EDA8048" />
</AssociationRequest>
</PDU>
</HDLC>
04:46:26 PM
7E A0 77 61 03 30 AD 6C E6 E7 00 61 69 A1 09 06 07 60 85 74 05 08 01 03 A2 03 02 01 00 A3 05 A1 03 02 01 0E A4 0A 04 08 5A 45 4E 30 30 30 37 35 88 02 07 80 89 07 60 85 74 05 08 02 02 AA 12 80 10 F3 17 9C F8 CB 37 12 E7 45 E9 4D C2 BD E9 6D 7F BE 23 04 21 28 1F 30 00 00 79 89 A3 6A F2 FF 87 E8 2C BD 71 B4 A5 9C 40 4E 11 0D 6D 1F 1D AC 2C 2E 36 DD D5 5D 45 14 7E
<HDLC len="76" >
<FrameType Value="30" />
<PDU>
<AssociationResponse>
<AssociationResult Value="00" />
<ResultSourceDiagnostic>
<ACSEServiceUser Value="0E" />
</ResultSourceDiagnostic>
<RespondingAPTitle Value="5A454E3030303735" />
<RespondingAuthentication Value="F3179CF8CB3712E745E94DC2BDE96D7F" />
<glo_InitiateResponse Value="3000007989A36AF2FF87E82CBD71B4A59C404E110D6D1F1DAC2C2E36DDD55D" />
</AssociationResponse>
</PDU>
</HDLC>
Duration: 338
16:46:26 Parsing AARE reply succeeded.
04:46:26 PM Authenticating.
7E A0 3E 03 61 32 7B 46 E6 E6 00 CB 30 30 00 00 00 06 AD 4F F1 83 D0 69 57 63 E0 D9 1D D3 E4 54 26 F0 48 06 26 49 20 7B 6F 5A ED 8E 20 67 EE F4 8C 32 A6 77 85 F0 93 06 4E 0F B4 58 FF 24 BD 7E
<HDLC len="3D" >
<FrameType Value="32" />
<PDU>
<glo_ActionRequest Value="3000000006AD4FF183D0695763E0D91DD3E45426F048062649207B6F5AED8E2067EEF48C32A67785F093064E0FB458FF" />
</PDU>
</HDLC>
04:46:26 PM
7E A0 24 61 03 52 62 DC E6 E7 00 CF 16 30 00 00 79 8A A6 03 61 DD E1 F0 D5 1F C4 44 6C 35 DC 26 8F E9 D7 D9 1F 7E
<HDLC len="23" >
<FrameType Value="52" />
<PDU>
<glo_ActionResponse Value="300000798AA60361DDE1F0D51FC4446C35DC268FE9D7" />
</PDU>
</HDLC>
Duration: 200
Gurux.DLMS.GXDLMSException: Access Error : Device reports a unavailable object.
6 years 11 months ago
Make connection to the meter without authentication. Read Association view. There is something like:
Management Frame Counter in data objects. Copy Logican Name (OBIS code) of that data object.
Select "Secured connections" -tab from device settings.
Paste Logical name to "Frame Counter LN".
Now Frame Counter is read and updated automatically.
Bhaumik
The frame counter is updated properly in both MR and US associations.
But after that object list is not downloaded and got the same error as below:
Gurux.DLMS.GXDLMSException: Access Error: Device reports a undefined object.
Is the exception coming in the same place? Check that your keys are correct and the Invocation counter is increased.
Bhaumik
Yup, The issue was due to incorrect password in device properties.
Thanks for the support.
Thanks for this info. It's always nice to know the reason.
  • Suria
  • pespinosaferrer777
  • Gabice William
  • ngewe
  • jojon15
