  3. Is There Source Code For Xmltopdu or Pdutoxml(GuruxDLMSTranslator To XML or To PDU)
is there source code for xmltopdu or pdutoxml(GuruxDLMSTranslator To XML or To PDU)
By pangda , 13 November, 2019
is there source code for xmltopdu or pdutoxml(GuruxDLMSTranslator To XML or To PDU)?
i want to use pdutoxml to analysis the response data.
6 years 8 months ago
What programming language you want to use?
If you want convert received frames you can use MessageToXml method.
pangda
thanks your reply. i use ANSI
thanks your reply. i use ANSI C language.
XML supported is not added to ANSI C because of lack of memory.
Can you use ANSI C?
pangda
i knows XML is not added to
i knows XML is not added to ANSI C code, now i want use PDUtoXML or messagetoXML source code by using ANSI C language.
That is not possible. You need to use ANSI C++.
  • Duaneduh
  • ClaytonPap
  • sAYgntkdaTjhgpvfz
  • HenryEneno
  • ScottCab
