  3. Dlms Support Library
Dlms support library
By sreenath , 14 February, 2019
I am new to dlms protocol, i have no idea how to start the coding of the protocol , no idea about the libraries. i downloaded a sample code which contain the code for arduino ide and i opened it in the ide and tried to run and its howed an error library not found in the directory. i tried to add but still the same error. can anyone help with it?
7 years 5 months ago
Dlms
What Arduino you are using? DLMS is not a very easy protocol and you must have enough memory. 32 KB is not enough. First check amount of the memory.
sreenath
dlms arduino
Thanks for the response. I am using an arduino due
96 KB is enough. Have you open Arduino_Ide project? There are no external libraries.
What kind of error you are receiving?
sreenath
dlms arduino
This is the error message -
server:35:34: error: include/dlmssettings.h: No such file or directory
compilation terminated.
exit status 1
Thank you
dlms arduino
You need to copy src and include from development forder under this folder.
sreenath
I have done the same and it resolved that issue. But now new issues came into picture
Like multiple libraries were found.
svr _ initialize not declared etc...
Thnk you
Thank you
Are you making a client app or meter?
sreenath
We are developing a dlms based meter.
Best Regards,
Sreenath
sreenath
dlms
Can we use 2 PCs to act as 2 dlms compatible device. So that we can communicate using the dlms protocol by sending and receiving data?
Hope u respond as soon as possible
Regards
Sreenath
If you have 2 PC, one must act like a client and other as a meter. It seems that you have multiple versions from the same files under development folder. Make sure that you have copy files only once.
sreenath
So can it be done as a demo to test the dlms protocol?
Regards
sreenath
We intend to develop a dlms based water meter which runs for 10 years with irreplaceable , we plan to use a low power low data rate LoRa based communication technology, so i need to know
1) Whether it is possible to send the dlms frames via LoRa technology?
2) Will there be increase in power consumption if we use DLMS protocol?
Regards
Sreenath
You can do a demo. I have answer for you questions here:
http://www.gurux.fi/node/13242
  • SkyCrown
  • AllenGaugh
  • Kennetharrem
  • Brandonitaro
  • dermida
