  3. How To Setup High Level Authentication With Gurux.DLMS.c
How to setup High level authentication with Gurux.DLMS.c
By stanQ , 26 November, 2018
I must say you guys at GURUX are doing a great work.
I am currently working a smart meter project and which to implement the GURUX DLMS protocol.
The server and client component works well and I'm able to read the server with the client application.
Now I want to write to the server. I observed I would need to use DLMS_AUTHENTICATION_HIGH and I guess a password. I'm not exactly sure now to do this on the client and server side.
On the client side, I initialized the client with
cl_init(&meterSettings, 1, 16, 1, DLMS_AUTHENTICATION_HIGH, password, DLMS_INTERFACE_TYPE_HDLC);
where password is a pointer to the password.
On the server side, I attempted to create same password with
bb_addString(&settings.base.password,password);
before initializing the server with
svr_init(&settings, 1, DLMS_INTERFACE_TYPE_HDLC, HDLC_BUFFER_SIZE, PDU_BUFFER_SIZE, frame, HDLC_BUFFER_SIZE, pdu, PDU_BUFFER_SIZE);
with these settings the server returns DLMS_ERROR_CODE_AUTHENTICATION_FAILURE.
How do I enable client connection with DLMS_AUTHENTICATION_HIGH?
Pointers and/or code snippets would be appreciated.
I'm quite new to GURUX DLMS and would require help.
Thanks.
stanQ
7 years 11 months ago
Positive feedback is always nice to get.
In DLMS Low-level password is set as you have done. If you want to set a high-level password it is set for as a secret for gxAssociationLogicalName object.
Like this:
bb_addString(&association.secret, password);
In our example it's set as "Gurux".
stanQ
In reply to How to setup High level authentication with Gurux.DLMS.c by Kurumi
stanQ
Thanks Kurumi, you're the best. Didn't expect the quick response.
Its working now.
KUDOS on your product and service.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
