  3. Clock Write
clock write
By atulsawant , 23 March, 2017
Dear sir,
I am trying to write clock object (0.0.1.0.0.255) using GURUX DLMSdirector.
Reading of clock object is right. when reading the tool shows accurate reading i.e. today's date-time.
but when i am trying to write object then it shows the error String was not recognized as a valid DateTime. .
why this happen? how to overcome this error?
is there any other procedure or setting required to write the clock object?
setting in tool menu is Attribute: 2.Type:OctecString.UIType:DateTime.
12:25:55 Read object type Clock index: 2
7E A0 1C 00 02 0E D3 41 98 EC 65 E6 E6 00 C0 01 C1 00 08 00 00 01 00 00 FF 02 00 60 1A 7E
12:25:55 Received data
7E A0 20 41 00 02 0E D3 98 E7 DF E6 E7 00 C4 01 C1 00 1B 07 E1 03 16 06 0C 19 3A FF FF FF FF 24 5B 7E
9 years 8 months ago
clock write
Dear sir,
Usually there is date and time in clock. In your clock there is only time part. Can you send trace from write message, so we can check that also.
  • Toko Bangunan Mahkota Jaya | WA 083148835648
