  3. HPL Smart Meter To Communicate Through DLMS
HPL smart meter to communicate through DLMS
By manojit , 30 January, 2017
Gurux.Net
I have received a HPL smart meter to communicate through DLMS. I am trying with following code
GXNet cl = new GXNet();
cl.HostName = "XX.XXX.XX.XX"; // I am using IP of the meter
cl.Port = 8000;
cl.Protocol = NetworkType.Tcp;
cl.Open();
However the Open() method throwing me following exception.
A request to send or receive data was disallowed because the socket is not connected and (when sending on a datagram socket using a sendto call) no address was supplied"
Can anybody help me on this?
Manojit
9 years 9 months ago
Your IP or port is wrong.
manojit
9 years 8 months ago
In reply to HPL smart meter to communicate through DLMS by Kurumi
I have a public IP and Port. I have configured my Meter's Modem to use this IP and Port. I am getting the above error after that only. Do I need anything else?
Please suggest.
Manojit
HPL smart meter to communicate through DLMS Primary tabs
One question. Is your meter starting connection or do you try to read your meter?
manojit
In reply to HPL smart meter to communicate through DLMS Primary tabs by Kurumi
Basically I am trying to read
Basically I am trying to read meter in this case.
Manojit
You are using modem in GPRS mode. Do you have static IP?
manojit
Yes, My PC have a static
Yes, My PC have a static Public IP. Modem is also configured to use these IP details.
Manojit
Usually problem is that client can't access private network from given IP address or port number is wrong.
Do this.
1. Move SIM card to the phone and check that is't working. You can test this checking if you can access web page.
2. Verify IP and port.
3. Verify that you can access APN from your ipaddress.
manojit
I will try that. However If I execute the GuruX server application it is displaying a client connecting successfully. It is giving me a idea that the Meter is connecting to my IP. Anyway I will check SIM also.
manojit
In reply to Hi, by manojit
I have tried the SIM as you suggested. That is working perfectly. What else I can verify? Am I doing correct by using the Public IP and Port in client code which I have configured in modem?
Your PC has own IP and meter has own IP. It seems that you try to connect to your PC. You need to ask what is SIM's IP address and connect to that.
manojit
As I understand the SIM uses
As I understand the SIM uses dynamic IPs and port as assigned by the Service Provider. Not sure how can I get that from my application. I was in a impression that my meter will connect to the DLMS Server running on my PC and I will connect to that server using my client application to read the meter.
Please suggest if I am thinking on wrong direction.
Manojit
If you want to use client app your SIM card needs static IP. Without that you can't access your meter.
You must ask static IP address from your mobile phone operator.
If your meter can make connection and <b>operate as a client<b> then you need to start GXDLMSServer example. Then your meter can make connection and you must modify example so it can ask data from the meter.
manojit
Thanks, now I understand the scenario. Can you please suggest where can I get some C# example to modify the server to ask data from meter?
Manojit
First you should check from the manufacturer can you ask anything from the meter or is meter sending only Push Message. Send data what meter sends to me by email. I can try to check it.
  • BlessyAnn
  • sravya.thota@m…
  • Diwakar
  • williamorussell
