  3. Elster Metering - A1140 Support?
Elster Metering - A1140 support?
By drinkins , 4 October, 2016
Do you have been read data from A1140 by GXDLMSDirector? Can you help me config GXDLMSDirector to read data from A1140, please? Thanks
9 years 11 months ago
Elster A1140
Elster is using IEC 62056-21 protocol. That is ASCII protocol and GXDLMSDirector is not supporting it.
drinkins
How to connect to elster via
How to connect to elster via gurux client?
drinkins
As I know, I should send "/?"
As I know, I should send "/?" + deviceSerialNumber + "!\r\n", but i don`t know? what is "deviceSerialnumber"?
Elster A1140
You can skip serial number if you have only one meter. Serial number is needed if there are several meters that are sharing same connection. Example RS-485.
drinkins
Thanks for answer. According
Thanks for answer. According to IEC IEC62056-21 protocol handshake. I send command "/?!\r\n" and meter should answered, that is right? Because i use example, and meter do not answered.Please, help.
9 years 10 months ago
EC IEC62056-21
This is correct. Your serial port settings should be.
Baudrate: 9600
Stop bits: 1.
Parity: Even.
  • avadhesh.p
  • Peter Mudenda
  • Sudhanshu Yadav
  • Shivakumar
  • Spawin
