  3. GXServerExample
GXServerExample
By johnc , 11 April, 2016
Hey,
What's generating the events "Client read from x" on the example server.
John
Edit: The object generating the events it the GXDLMSProfileGeneric.
e.g.: Client Read value from 0.0.1.0.0.255 attribute: 2.
Client Read value from 1.1.21.25.0.255 attribute: 2.
But there's no client. When the profile generic reads it says the client read.
John
10 years 7 months ago
GXServerExample
There is a timer on profile generic that read values and makes new row from read values.
This timer calls server's read method.
johnc
In reply to GXServerExample by Kurumi
Hey,
Hey,
Yeah just found out that, but since is not the server shouldn't it call another method?
John
GXServerExample
Long time ago there was two methods, but we notest that there was two identical methods.
Do you have some special needs for separating them or is this from design?
johnc
Hey,
Hey,
Mostly for design.
John
johnc
I was implementing a separate
I was implementing a separate server based on the example.
Do you know why I get this error "Destinations addresses do not match. It is 0, it should be 16"
John
GXServerExample
Are you using Java or C# version?
johnc
Hey,
Hey,
I'm using Java version.
John
johnc
Hey,
Hey,
I was using an earlier version of the dlms library. This one isn't causing the error anymore.
Now I'm getting "Frame ID do not match.". Do you know where this comes from?
We have fixed that. It is removed on next release.
Get new version from GitHub.
