  3. OBIS Codes File For CEWE Promoter 100 Meter
OBIS codes file for CEWE Promoter 100 meter
By andrewje , 4 March, 2016
HI,
I am looking for the obis obx file for the CEWE Prometer 100 meter. Anyone know were I can find it?
10 years 6 months ago
We have not read CEWE Promoter meter before.
This is a big problem because every meter manufacturer is using different settings.
You can try to select Landis+Gyr in GXDLMSDirector and then read your meter.
If you do not receive reply, change starting protocol from IEC to DLMS.
Let me know what happened.
andrewje
I tried using the settings from the Landis+Gyr meter but it doesn't seem to respond once switching from IEC mode.
Here is the log file sample.
10:20:02 Initializing serial connection.
10:20:02 HDLC sending:/?!<CR><LF>
10:20:02 HDLC received: /CWI5\2<CR><LF>
10:20:02 BaudRate is : 9600
10:20:02 Moving to mode E.
06 32 35 32 0D 0A
10:20:04 Send SNRM request.
7E A0 08 02 01 23 93 8E E1 7E
10:20:09 Failed to receive reply from the device in given time.
10 years 5 months ago
We sent a inquery from your meter settings to the manufacturer two weeks ago.
They have not answered anything.
Is there DLMS label on the cover of the meter?
