  3. UIValueType=TextBox Is Rendered As CheckedListBox When Values Are Defined
UIValueType=TextBox is rendered as CheckedListBox when Values are defined
By Matt_Plumer , 6 November, 2026
I have noticed what seems to be an inconsistency in GXDLMSDirector 9.0.2508.2701.
I have a Data object attribute configured with:
"<Type>UInt8</Type>
<UIType>UInt8</UIType>
<UIValueType>0</UIValueType>"
and a collection of GXObisValueItem entries under Values.
In the OBIS Code editor, UIValueType=0 is correctly shown as: TextBox
However, when the Data object is displayed in GXDLMSDirector, the Value field is actually rendered as a CheckedListBox containing all GXObisValueItem entries.
Therefore, there seems to be a mismatch:
Configured:
UIValueType = TextBox
Actual control:
CheckedListBox
My expectation is that explicitly selecting UIValueType=TextBox should keep the field rendered as a TextBox, even if Values are defined.
Could you please confirm whether overriding TextBox with CheckedListBox in this situation is intentional?
If it is intentional, what is the purpose of explicitly selecting UIValueType=TextBox when Values are present?
Thank you in advance.
1 week 5 days ago
Hi, Use CheckedListBox when…
Use CheckedListBox when multiple enum values can be selected.
CheckedListBox is used when multiple enum values can be selected.
It shows all possible values in Checked list box.
Matt_Plumer
1 week 5 days ago
Hi, the problem is: I choose…
the problem is:
I choose UIValue "TextBox", I got list with all visible vaules and checkboxes, as shown in diffrent topic.
I choose UIValue "CompoBox", I got list which I can expand and see all possible values.
I choose UIValue "ListBox", I got blank white space in object.
I choose UIValue "CheckedListBox", I again got list with all visible vaules and checkboxes, as shown in diffrent topic. (the same as TextBox).
Matt
3 days 8 hours ago
HI Matt, The new Gurux.DLMS…
HI Matt,
The new Gurux.DLMS.Director is released in December. This is fixed for that.
