  2. Help Needed: Interfacing Saral 100 Energy Meter With Microcontroller Via RS232
Help Needed: Interfacing Saral 100 Energy Meter with Microcontroller via RS232
By Naman_Shandilya , 23 July, 2026
Gurux.Serial
Hi everyone,
I am new to the DLMS and energy meter domain. I am working on interfacing a Saral 100 energy meter (Secure Meters) with my microcontroller over the RS232 protocol. I’ve received some initial details from the vendor, but I want to confirm what exact parameters and values are required from the manufacturer to ensure proper communication and data reading.
Here’s what I have so far:
Voltage Levels – RS232 standard voltage levels (3–5 V depending on signal type).
Serial Communication Settings – Baud rate: 9600 bps, Parity: None, Stop bits: 1.
Authentication – KDF04 required.
Encryption/Security Keys – HLS keys.
Client and Server Addresses – Need confirmation of exact values.
Supported OBIS Codes – As per IS 15959 and manufacturer‑specific codes.
Sample Request‑Response Logs – One sample already received.
Communication Protocol – IS 15959.
My Question:
Could you please guide me on what additional parameters or values I should request from the meter vendor/manufacturer to successfully interface the Saral 100 with my microcontroller and read all required data?
Any advice, examples, or best practices from your experience with Secure meters and DLMS would be greatly appreciated.
Thanks in advance!
2 days 20 hours ago
Hi, I suggest that you…
I suggest that you download GXDLMSDirector and read your meter with it first. It will help you to understand DLMS and objects.
You can check the Arduino client example:
Secure meters use the Indian standard, so select the Indian standard as the manufacturer.
