By craqdi , 14 July, 2026 Forums General discussion I want to put a simulator in clou format how should it be done? Hi, You need to read the… Hi, You need to read the Clou meter with GXDLMSDirector. Select the meter and you can see the "Command line parameters". Set those parameters after Gurux.DLMS.Simulator.Net.exe. Something like this: Gurux.DLMS.Simulator.Net.exe -S COM8 -o simulator_template.xml -t Verbose See detailed instructions from here: https://github.com/Gurux/Gurux.DLMS.Net/tree/master/Gurux.DLMS.Simulato… Regards, Mikko
