  3. Problem With Dedicated Key On Release Request
Problem with Dedicated key on Release request
By zon7 , 24 March, 2026
Gurux DLMS for ANSI C++
After updating to the latest version of gurux.cpp (I had a very old version), i'm having problems debuging because an assert.
The problem is that after AARQ, the m_DedicatedKey stored in the GXCipher has position advanced.
Then in GXAPDU:233->GXByteBuffer:406, when trying to set the dedicated key, an assert throws because pos is already it's max size.
I'm able to reproduce this behaviour every time. Can you fix it?
7 months 2 weeks ago
Hi, Our customers are using…
Our customers are using the dedicated key all the time. Can you add a hex trace from AARQ and AARE so I can check what is happening?
  • BCA KCP Taman Permata Buana Tlpon:(0851)-5236-1070
  • BCA KCP CBD Pluit Tlpon:(0851)-5236-1070
  • Inilah BCA KCU KELAPA GADING Tlpon:(0851)-5236-1070
  • BCA KCP Prima Sunter Tlpon:(0851)-5236-1070
  • BCA KCP Gunung Sahari Tlpon:(0851)-5236-1070
