  3. Generic Profile- GxGet With Selector=2: Different Behaviour On Cpp and Cimplementation
Generic Profile- gxGet with selector=2: different behaviour on cpp and cimplementation
By andale8592 , 20 January, 2026
Gurux DLMS for ANSI C
i see that the getting Generic Profile value using ReadRoiwbyEntry has different encoding parameters on cpp and c implementation, i am addressing to:
In cpp: https://github.com/Gurux/Gurux.DLMS.cpp/blob/master/development/src/GXD… it encodes the start index and count as UINT32.
Instead on the c implementation it expect thsoe values as UINT16: https://github.com/Gurux/GuruxDLMS.c/blob/8c4b2731ccad26af9b8cd6b5f486e…
I am missing something? Why that different behaviour?
Alessandro
9 months 2 weeks ago
Hi Alessandro, In Ansi C…
Hi Alessandro,
In Ansi C code you shared, the column start and count indexes are read, not the row index and count. The row index and count are read earlier and saved to transactionStartIndex and transactionEndIndex.
andale8592
Thanks, for detailed…
Thanks, for detailed response. Can you point where (in ansi-c) transactionStartIndex and transactionEndIndex are read?
andale8592
Maybe there ? https://github…
Maybe there ? https://github.com/Gurux/GuruxDLMS.c/blob/8c4b2731ccad26af9b8cd6b5f486e…
Hi, Yes, that is the…
Yes, that is the location where transactionStartIndex and transactionEndIndex are read.
