  2. Convert String To Octate String
Convert string to octate string
By Bhaumik , 27 November, 2025
I have to write the following array in the meter.
<Array Qty="01">
<Array Qty="02">
<Structure Qty="02">
<OctetString Value="070000FF"/>
<OctetString Value="060000FF"/>
</Structure>
<OctetString Value="080000FF"/>
<OctetString Value="090000FF"/>
</Structure>
</Array >
</Array>
Can you please provide c# code for the same
As I got below from my code. where second node coming as structure instead of Array.
<Array Qty="01">
</Structure>
</Structure>
</Structure>
</Array>
Bhaumik
6 months 2 weeks ago
Can you please provide…
Can you please provide update on this?
6 months 1 week ago
Hi, You can do it like this:…
GXArray arr1 = new GXArray();
GXArray arr2 = new GXArray();
GXStructure s1= new GXStructure();
GXStructure s2 = new GXStructure();
arr1.Add(arr2);
arr2.Add(s1);
arr2.Add(s2);
s1.Add(GXDLMSTranslator.HexToBytes("070000FF"));
s1.Add(GXDLMSTranslator.HexToBytes("060000FF"));
s2.Add(GXDLMSTranslator.HexToBytes("080000FF"));
s2.Add(GXDLMSTranslator.HexToBytes("090000FF"));
Bhaumik
6 months 1 week ago
Hi Mikko, Thanks for the…
Thanks for the update.
I have multiple entires in the array.
with this code still second node coming as Structure. By default it takes structure, Can you please suggest what to update in code to get as array.
<Array Qty="02" >
<Structure Qty="02" >
# 07:00:*
<OctetString Value="0700FFFF" />
# 06:00:*
<OctetString Value="0600FFFF" />
</Structure>
# 08:00:*
<OctetString Value="0800FFFF" />
# 08:00:*
</Structure>
</Structure>
# 05:00:*
<OctetString Value="0500FFFF" />
# 06:00:*
</Structure>
# 07:00:*
# 07:00:*
</Structure>
</Structure>
</Array>
I want output as below
<Array Qty="03" >
<Array Qty="02" >
# 07:00:*
# 06:00:*
</Structure>
# 08:00:*
# 08:00:*
</Structure>
</Array>
<Array Qty="02" >
# 05:00:*
# 06:00:*
</Structure>
# 07:00:*
# 07:00:*
</Structure>
</Array >
</Array>
my c# code is as below
GXArray gXSchedulerArray = new GXArray();
foreach (Month month in SchedulerMonth)
GXArray gXMonthArray = new GXArray();
// -------- Quarter 1 ---------
GXStructure gxStructQtr1 = new GXStructure();
GXTime gXTimeQtr1On = new GXTime(month.Quater1.RelayOnTime);
GXTime gXTimeQtr1Off = new GXTime(month.Quater1.RelayOFFTime);
gxStructQtr1.Add(GXDLMSTranslator.HexToBytes(gXTimeQtr1On.ToHex(false, true))); // Add GXTime object
gxStructQtr1.Add(GXDLMSTranslator.HexToBytes(gXTimeQtr1Off.ToHex(false, false))); // Add GXTime object
// -------- Quarter 2 ---------
GXStructure gxStructQtr2 = new GXStructure();
GXTime gXTimeQtr2On = new GXTime(month.Quater2.RelayOnTime);
GXTime gXTimeQtr2Off = new GXTime(month.Quater2.RelayOFFTime);
gxStructQtr2.Add(GXDLMSTranslator.HexToBytes(gXTimeQtr2On.ToHex(false,true))); // Add GXTime object
gxStructQtr2.Add(GXDLMSTranslator.HexToBytes(gXTimeQtr2On.ToHex(false, true))); // Add GXTime objec
// Add both structures into month array
gXMonthArray.Add(gxStructQtr1);
gXMonthArray.Add(gxStructQtr2);
gXSchedulerArray.Add(gXMonthArray);
6 months 1 week ago
Hi, Use the code that I…
Use the code that I shared as a template. It will generate the correct structure.
Bhaumik
6 months ago
Hi Mikko, I have used the…
I have used the same structure, but still not generating the expected structure.
Please check and give me the updated code template.
<SetRequest>
<SetRequestNormal>
# Priority: High, ServiceClass: Confirmed, Invoke ID: 1
<AttributeDescriptor>
# Data
<ClassId Value="0001" />
# 1.0.128.8.128.255
<InstanceId Value="0100800880FF" />
# Value
<AttributeId Value="02" />
</AttributeDescriptor>
<Value>
<Array Qty="03" >
<Structure Qty="02" > <== This should come as array instead of Structure
# 07:00:*
# 06:00:*
</Structure>
# 08:00:*
# 08:00:*
</Structure>
</Structure>
# 05:00:*
# 06:00:*
</Structure>
# 07:00:*
# 07:00:*
</Structure>
</Structure>
# 05:00:*
# 06:00:*
</Structure>
# 07:00:*
# 07:00:*
</Structure>
</Structure>
</Structure>
</Array>
</Value>
</SetRequestNormal>
</SetRequest>
I want as below
<SetRequest>
<SetRequestNormal>
# Data
# 1.0.128.8.128.255
# Value
<Value>
<Array Qty="03" >
<Array Qty="02" >
# 07:00:*
# 06:00:*
</Structure>
# 08:00:*
# 08:00:*
</Structure>
</Array >
<Array Qty="02" >
# 05:00:*
# 06:00:*
</Structure>
# 07:00:*
# 07:00:*
</Structure>
</Array >
<Array Qty="02" >
# 05:00:*
# 06:00:*
</Structure>
# 07:00:*
# 07:00:*
</Structure>
</Array >
</Array>
</Value>
</SetRequestNormal>
</SetRequest>
Bhaumik
6 months ago
Hi Mikko, I have used same…
I have used same template as you have provided. From that also I am getting structure elements instead of Array element (second node)
Please check and provide updated template.
0001003000010040d13e3000000004483c2ceb395d0462ef5b0ff28ae7187c807674f75f36b24ee2cee3534223a5e332584c5cc2ef388702bd711c1ae0b3ab9457fbee49c7d9526c
BlockCipher key: 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32
Authentication Key:32 32 32 32 32 32 32 32 32 32 32 32 32 32 32 32
1: 00 01 00 30 00 01 00 40 D1 3E 30 00 00 00 04 48 3C 2C EB 39 5D 04 62 EF 5B 0F F2 8A E7 18 7C 80 76 74 F7 5F 36 B2 4E E2 CE E3 53 42 23 A5 E3 32 58 4C 5C C2 EF 38 87 02 BD 71 1C 1A E0 B3 AB 94 57 FB EE 49 C7 D9 52 6C
<WRAPPER len="40" >
<SourceAddress Value="30" />
<TargetAddress Value="1" />
<PDU>
<!-- Invocation Counter: 4 -->
<!-- Decrypt data: C1 01 C1 00 01 01 00 80 08 80 FF 02 00 01 01 02 02 02 02 09 04 07 00 00 FF 09 04 06 00 00 FF 02 02 09 04 08 00 00 FF 09 04 09 00 00 FF
<SetRequest>
<SetRequestNormal>
# Data
# 1.0.128.8.128.255
# Value
<Value>
<Array Qty="01" >
<Structure Qty="02" > ==============> This should come as array
# 07:00:00
<OctetString Value="070000FF" />
# 06:00:00
<OctetString Value="060000FF" />
</Structure>
# 08:00:00
<OctetString Value="080000FF" />
# 09:00:00
<OctetString Value="090000FF" />
</Structure>
</Structure>
</Array>
</Value>
</SetRequestNormal>
</SetRequest>
<ded_SetRequest Value="3000000004483C2CEB395D0462EF5B0FF28AE7187C807674F75F36B24EE2CEE3534223A5E332584C5CC2EF388702BD711C1AE0B3AB9457FBEE49C7D9526C" />
</PDU>
</WRAPPER>
Bhaumik
6 months ago
Can you please provide an…
Can you please provide an update ?
6 months ago
Hi, I checked the code you…
I checked the code you shared. It generates the correct data.
Check your code. The generated frame is below.
https://www.gurux.fi/GuruxDLMSTranslator?translate=7EA0780002625B031077…
