  3. Regarding The Dlms Android Project
Regarding the dlms android project
By atuldd , 27 October, 2025
Gurux DLMS for Android
I am working in a project where need to communicate with NON DLMS meters that use the IEC 62056-21
Is it possible if Gurux serial can be used to handle the communication
1 year ago
Hi, Yes, you can use Gurux…
Yes, you can use Gurux Serial. You just need to set the correct serial port settings.
atuldd
12 months ago
Hi Mikko, Can we use…
Can we use GXDLMSDirector or Gurux DLMS library to communicate with non-DLMS meters that follow the IEC 62056-21 protocol?
The reason I ask is that the request and response format in non-DLMS IEC 62056-21 meters is different from DLMS meters.
Also, is it possible to communicate with such non-DLMS meters from an Android application using Gurux libraries?
12 months ago
Hi, No, you can't. DLMS and …
No, you can't. DLMS and IEC 62056-21 are two totally different protocols.
You can get more information by reading: IEC 62056-21 is not DLMS/COSEM:
https://gurux.fi/DLMSCOSEMFAQ
